Timing Chain Replacement Necessary ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Dec 17, 2022.
  1. Dec 17, 2022 at 9:10 AM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    I've just rolled over 300,000 recently. Who here is over 300K and still using the original timing chain ??
    I was under the impression timing chain is good for the life of the engine.
  2. Dec 17, 2022 at 12:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You are correct, regular proper oil changes and that timing chain will never give you an issue. I believe it will throw a vvti code if chains stretch too much
    Dm93 and TnShooter like this.
  3. Dec 17, 2022 at 12:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeah. You should get a Cam/Crank Correlation code. P0018 / P0016
    I believe the allowance is 5* CA between the Cam/Crank. (Desired / Actual)
    OP nothing I just posted matters to you.
    @nd4spdbh answered the question quite well.:thumbsup:
