Timing Chain Replacement... PULL THE HEAD?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96greengoblin, Jul 6, 2011.
  1. Jul 6, 2011 at 11:11 AM
    96greengoblin
    96greengoblin [OP] Active Member
    Hayden
    Michigan
    96 Extended Cab 4x4
    Billy's on all 4 corners!
    I ordered a timing chain kit for a local shop to install. I trust them as they have worked on family vehicles before. I dropped it off today to have them install everything only to have them tell me the original estimate of 6 hours would turn in 15+ head gasket, oil pan gasket etc etc. bringing to total to about $1400. They didnt know you would have to pull the head and after some research realized there is apparently no other way to do it. What's the deal... true? Its a 96 3rz and he says he hasnt ever seen a motor where you have to actually pull the head to replace the chain. now ive got $200 in parts that will be subject to a restocking fee from rockauto and a finnicky motor with some chain slap. oh, and im a broke high schooler.
  2. Jul 7, 2011 at 3:38 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Yes, it's true. The FSM clearly specifies removing the cylinder head as one of the steps in removing / replacing the timing chain.
  3. Jul 7, 2011 at 8:05 PM
    Buggys3sgte
    Buggys3sgte Well-Known Member
    Psycho state of AZ
    97 BUDGET Taco
    Newly rearranged front end, sick Hurst shifter yo gives it lightning fast shifts, thats it more to come.
    Yeah just pull the head, and do it correctly as any "Rigging" will cost you in the long run. Seems like that shop has there act together and doesn't belive in shortcuts.
  4. Jul 7, 2011 at 8:12 PM
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    (Sold) 99 Tacoma SR5, 2001 4 Runner
    3" lift -(Bilstein 5100 adjustable front with Eibach Coils, Bilstein 5100 rears w/ Deaver aal), B.A.M.F. BPV relocate bracket, Hella 500's with DDM Tuning HID mod, Aero 2525XL muffler "Freakin Sweet!", Custom built Linear Actuated Light Bar w 1-32" LED bar, Custom Rear Bumper with Swing Out Tire Carrier
    Just had mine done on my 99 at the dealership and they only charged $400 for the labor. Why are they askin so much?
  5. Jul 7, 2011 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You have a belt....he has a chain.
  6. Jul 7, 2011 at 8:16 PM
    99nmtaco
    Patrick
    NM / VA
    Ah I missed that my bad.
  7. Jul 7, 2011 at 9:16 PM
    el dudarino
    el dudarino Well-Known Member
    What exactly do you mean by that?
  8. Jul 8, 2011 at 6:26 AM
    itin1200
    itin1200 Member
    Bill
    Pittsburgh, PA
    2004 4x4 TRD XtraCab
    It's his way of trying to be sly with a racist slur.
