Timing chain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fishnhunt, Jan 27, 2011.
  1. Jan 27, 2011 at 9:08 AM
    fishnhunt
    fishnhunt [OP] Member
    Ontario
    05 Taco sport
    3' suspension lift DVD player Toyo mud tires
    Hey folks
    Im new to the site, I live in Ontario and my truck is used for fishing and hunting on a weekend basis. Truck has a 3' lift with Toyo tires that can really huck mud. Truck is awesome
    My 2005 Tacoma has 120 000miles, I bought the truck used and haven't changed the timing chain. Can I wait a couple more months or should I change it immediately. Dealer said to change it at 140 000km. Im nearly 50 000km overdue.
    What do you think?????
  2. Jan 27, 2011 at 9:18 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I think your dealer is pulling your chain. These new engines are not like the old 20/22 series engines where the timing chain will wear the guides and finally wear through the cover.
  3. Jan 27, 2011 at 9:20 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You really dont change timing chain unless its making noise and that does not happen in normally maintained truck before 300k miles :D
    Timing guides may wear sooner (like 200K ) and you going to hear that, believe me. So to answer, keep driving you really have long way to go to even worry about timing chain.
  4. Jan 27, 2011 at 10:02 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    They go until they break, then you just replace the motor or sell the truck outright! LOL But seriously, with regular maintenance and decent fuel quality and not too much abuse, the 2.7 motor should go at least 300k miles. :)
  5. Jan 27, 2011 at 11:22 AM
    fishnhunt
    Ontario
    05 Taco sport
    The trucks a 4.0L, I always thought that changing a timing chain was normal maintenance and used prevent damage when that chain does finally go.
    Thanks folks
  6. Jan 27, 2011 at 11:35 AM
    BlueT
    NorthEast
    I think you mixing with Timing belts which are on some other cars. Timing belts usually need to be replaced around 90K.
    luckly for us Toyota used Timing chain so nothing really to do but drive the truck. :D Stay on top of oil changes and don't even bother thinking about Timing chain until you cross 250k miles
  7. Jan 27, 2011 at 11:38 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Keep up on your oil changes and the chain will outlast the motor.
    The dealership tried to tell me my engine had a timing belt and it needed replace. I had to school the man about timing chains, belts and the difference,, and about being honest.
  8. Jan 27, 2011 at 12:34 PM
    DGXR
    Friend
    Sacramento, CA
    I believe the 4.0 v6 has a timing belt, and it does need periodic replacement (90k or so?) whereas the chain in the 2.7 4cyl will last the life of the engine.
  9. Jan 27, 2011 at 12:40 PM
    98tacoma27
    Ben
    Not Beech Creek
    The 4.0 has a chain. The 3.4 has a belt. The 4.7 has a belt. The 2.4/2.7 has a chain. You should read the entire thread.
  10. Jan 27, 2011 at 12:55 PM
    DGXR
    Friend
    Sacramento, CA
    I did read the entire thread -- nowhere does anyone say "the 4.0 has a timing chain." But at least now I know... it was the 3.4 v6 I was thinking of that has a belt. thanks a lot
  11. Jan 27, 2011 at 12:59 PM
    98tacoma27
    Ben
    Not Beech Creek
    Good point. I can see where the specifics could be misconstrued.
    My apologies.
  12. Jan 27, 2011 at 3:05 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    :headbang:
    Damn, you have a 3' lift! You're badass!!
