Timing Chain
Discussion in 'Technical Chat' started by roylb, Jun 22, 2011.
  1. Jun 22, 2011 at 11:23 AM
    roylb
    roylb [OP] Member
    Roy
    San Antonio,Tx
    2006 Tacoma Double Cab Pre-Runner
    3 inch ReadyLift
    I have a 2006 Tacoma Double Cab V6, 92,000 miles ..when does the timing chain need to be replaced.And what else needs to be done..?
  2. Jul 14, 2011 at 8:53 AM
    roylb
    roylb [OP] Member
    Roy
    San Antonio,Tx
    3 inch ReadyLift
    Thanks Christian
  3. Jul 14, 2011 at 9:05 AM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    dont for get to do the diff's too
  4. Jul 14, 2011 at 1:20 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Only suspect the timing chain when you hear excessive tapping noise from inside the crankcase. You should have no problems with it, as long as you regularly change your oil with the correct grade.
  5. Jul 14, 2011 at 1:24 PM
    rtorella
    rtorella GBear
    Helena, MT
    Tacoma Off Road Package
    Does the 2011 Tacoma V6 have a timing chain or belt. Just replaced timing belt on my '89, and pullies for $940.00. Belt snapped coming up Mtn Pass, not a good situation at all.
  6. Jul 14, 2011 at 1:29 PM
    AK27
    AK27 Well-Known Member
    chain
  7. Jul 14, 2011 at 2:06 PM
    rtorella
    rtorella GBear
    Helena, MT
    Thanks!
