Timing chain
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kevin2.7, May 26, 2016.
  1. May 26, 2016 at 11:09 AM
    Kevin2.7
    Kevin2.7 [OP] Active Member
    Kevin
    1999 Toyota Tacoma 4x4 TRD 2.7
    6" lift
    So I need to do my timing chain is it difficult?? And what timing chain kit should I spend my money in did some research and they all varied from 120$ to 200$ just don't want to end up with some junk anyone with greater experience???
  2. May 26, 2016 at 11:12 AM
    Kevin2.7
    Kevin
    6" lift
    Don't think the 1999 2.7 use a belt
  3. May 26, 2016 at 11:15 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  4. May 26, 2016 at 1:08 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    why do you need to do it? they usually last as long as the motor does.
  5. May 26, 2016 at 1:58 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    My 2rz (3rz's 5 lug little bro) has 263k on the original timing set
  6. May 26, 2016 at 2:32 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    this.
    as I understand it, you don't need to worry about the chain. Belt - different story.
  7. May 26, 2016 at 2:38 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I've never seen a timing chain that needed replacement even when I rebuilt the engine. If the chain is worn out the rest of the engine must not be far behind.
  8. May 26, 2016 at 2:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    When chains of yore stretched the sounds from the front of the motor changed. L6 Chevys, AMCs, Datsuns and V8 Pontiacs and a V6 Mustang I've had all come to mind. But the newest of those was an '86.
    And the rest of the engine in all those was just fine. Chains were considered a wear item, but since the motors were non interferance, and running issues occured before complete breakdown, it was not considered a PM/service item.
    I can't recall of hearing of an issue with a more modern chain set up. I'm sure there is a deflection spec on it. I'd try to find that and determine status before digging in.
  9. May 26, 2016 at 5:24 PM
    Kevin2.7
    Kevin
    6" lift
    Its making a horrible sound at idle bought it like that..... thought it could use the timing chain and a valve adjustment
  10. May 26, 2016 at 10:31 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I wouldn't worry about it, more hassle than it's worth. Timing chains last the life of the engine, at least they're supposed to. If not you got bigger problems to worry about.
  11. May 27, 2016 at 10:15 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    horrible noise is probably more likely to be coming from the water pump or power steering pump or belts
    MrRiverMan likes this.
