Timing Chain
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rusty_but_Trusty, Jul 12, 2019.
  1. Jul 12, 2019 at 9:26 PM
    Rusty_but_Trusty
    Rusty_but_Trusty [OP] Active Member
    Nick
    1996 Toyota Tacoma LX Extended Cab
    2" lift, 31x10.50 A/T tires
    So my '96 Tacoma just hit 200K about a month ago. Is it advised to do any major part replacements prior to failure at this mileage level, i.e. timing chain, etc.?
    Just want to be proactive and not kill my daily driver prematurely. Thanks for any help.
  2. Jul 12, 2019 at 9:57 PM
    eon_blue
    Azusa, CA
    Do you have the v6 or the 4cyl? The 4cyl has a timing chain and doesn't require service unless something's wrong with it. The v6 has a timing belt that is supposed to be replaced every 90-100k.
  3. Jul 13, 2019 at 7:44 AM
    Rusty_but_Trusty
    Nick
    It is a 4 cylinder.
    That's what I thought I just wanted to be sure.
  4. Jul 13, 2019 at 7:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd get the valve clearances checked.
    It's safe to assume you'll check all the other things out such as PCV valve, spark plugs, water pump, LBJ's, any and all bushings in your suspension, etc.
    I'd do the transmission fluid and filter while you're at it.
