Timing chains installation test
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 14, 2021.
  1. Dec 14, 2021 at 8:52 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Other than following the instructions from the manual WHILE DOING IT, is there a method to test the timing chains installation AFTER THE FACT? Like you delegated the task to an employee and now you have to come see he did it right.
    When installing the camshafts, one design flaw that inhibited testing, as I observed, was that, while the dot market on the exhaust camshafts was still visible, the view to the one on the intake side was blocked on the front by the VVT phaser drum and in the back by the first (largest) bearing. So, to verify that whoever did it did it right, you need another testing method, which I am sure must exist.
    I understand the generic advice "do it right when doing it" (or some variation thereof) but being able to test any technical product before committing to the stage where mistakes are costly is an integral part of any quality product lifecycle.
    tacotoe likes this.
  2. Dec 14, 2021 at 7:21 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The only other 2 "verification" methods of timing aside from timing mark alignment would be a cam/crank sensor waveform scope capture compared to a known good or in cylinder pressure waveform both would require the engine to be cranking or running.
    If you put the colored links in the correct positions when you assembled it there's really no way for it to get out of time without jumping teeth.
    foampile[OP] likes this.
  3. Dec 14, 2021 at 8:50 PM
    foampile
    Mid-Atlantic
    Crank:
    Right:
    Left:
    tacotoe likes this.
  4. Dec 14, 2021 at 9:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is there some pids you could see on a scan tool that would show correlation? I've used that on VW/audi.. not sure about toyota
    Other than that or a scope capture all I can think of is just driving it and hoping it doesn't code
    All you have is visual /mechanical reference until everything is reassembled and running
    tcjacado likes this.
  5. Dec 14, 2021 at 9:35 PM
    tcjacado
    tcjacado Well-Known Member
    TnShooter likes this.
  6. Dec 14, 2021 at 9:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  7. Dec 14, 2021 at 9:56 PM
    TnShooter
    Deogee
    STOCK
    FWIW, you don’t show the crank key correlation to the block timing line.
    But your picture looks about right for where the dot should be.
  8. Dec 14, 2021 at 10:11 PM
    Bishop84
    Bishop84 Well-Known Member
    It's good, can't confirm the secondary marks.
    As a back up I always want to see TDC on cylinder #1 to have both valves equally closed. So cam lobes opposed.
    I'm doing a tundra chain right now, I'll snap a pic tomorrow.
  9. Dec 15, 2021 at 12:46 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Looks fine off what I remember on the 1GR
  10. Dec 15, 2021 at 4:29 AM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    From what I recall, it takes like 6-8 full revolutions of the chain to have the color coded links and crank match up.
    When I put everything back together I rotated it to make double sure.
  11. Dec 15, 2021 at 8:31 AM
    foampile
    Mid-Atlantic
    Correct. After the original alignment of the three marked links on the chain and the notches/dots on the crank and cam sprockets, it takes something like what you said (maybe 7) full revolutions of the no. 1 (big) chain (so not just of the crank) to get the same alignment again.
  12. Dec 15, 2021 at 10:04 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If your marks all line up and you installed/torqued everything properly you should be good to go.
    foampile[QUOTED][OP] likes this.
  13. Dec 15, 2021 at 10:08 AM
    foampile
    Mid-Atlantic
    I get that and they are indeed -- I was just wondering about other testing methods.
    Like, for example, since 1GR-FE is an interference engine, would a mistake in timing necessarily always result in an interference, which could be timely and cheaply detected by a stall when turning the crankshaft, i.e. much before firing up the engine? Or is there a scenario where that does not happen but the timing is still wrong?
  14. Dec 15, 2021 at 10:14 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You would have to be quite a few teeth out of time before interference would occur but you would feel it get tight barring the engine over by hand with the plugs removed if something was hitting.
  15. Dec 15, 2021 at 10:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    it can take MANY more turns than that to get colored markings to line up on all 3 chains. Colored markings should only be used as a reference, the end all is the mark on the crank to block then marks on cam gears to head.
  16. Dec 17, 2021 at 4:23 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Are you putting an engine back together by asking each step on a new thread @foampile ? I see lots of separate threads where it seems you are lacking the knowledge and maybe better off taking to a mechanic.
    burrito782 and AllTacosFloat like this.
  17. Dec 17, 2021 at 6:01 AM
    TnShooter
    Deogee
    STOCK
  18. Dec 17, 2021 at 6:13 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Should have just kept one thread going. Could have maybe been an informative timing chain and cam shaft replacement thread.
    Need a general "ask a pro" sticky for each gen.?
    6 gearT444E likes this.
  19. Dec 17, 2021 at 6:20 AM
    TnShooter
    Deogee
    STOCK
    Those “ask a Pro” threads never work out. 90% of the time you’ll get advice from guys that aren’t pro’s.
    50% of the answer is not even relative to the question.
    And No, I’m not a Pro. :rofl:
    tacotoe and SR-71A like this.
  20. Dec 17, 2021 at 6:24 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I agree, I see 3 or 4 threads on what appear to be the same topic and I gave up on answering the smattering of questions that could be combined in one thread.
