Timing cover issue/Barsleaks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foreverdown91, Sep 26, 2017.
  1. Sep 26, 2017 at 1:22 PM
    foreverdown91
    foreverdown91 [OP] Member
    Somar
    Raleigh NC
    2005 yota coma pre
    Yeah the mechanic told me that could happen and all I could think was then why would you advise I do that?haha! Sorry to hear about your truck tho. It's so hard to know what products you can truly trust.
    Pabloeeto[QUOTED] likes this.
  2. Sep 26, 2017 at 1:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Very simple actually. Pop off the belt, unbolt and drop down the power steering pump, clean thoroughly, finger it in.
  3. Sep 26, 2017 at 1:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only drawback is that you'll have to change your oil regularly again, since you won't be constantly filling it back up.
    junkyardyote likes this.
  4. Sep 26, 2017 at 1:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'll be your mechanic. I can give you marginally better advice, for a fraction of the cost. Lol
    lo2hi and randd like this.
  5. Sep 26, 2017 at 1:38 PM
    foreverdown91
    Somar
    Raleigh NC
    2005 yota coma pre
    Thanks man, I appreciate you. Yeah I think I'm just gonna take it apart on my next day off and clean/seal it and let her ride. If this is the worst thing to happen and this mileage then I'm thankful. She owes me nothing at this point.haha!
    randd and Torspd like this.
  6. Sep 26, 2017 at 2:49 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    If you do I would highly recommend (buy a couple of cans) using this: http://www.gunk.com/products/DET_EBGEL.ASP
    Drive your Tacoma to a carwash place (you definitely don't want to do this in your driveway) follow the directions on the can(s) and go at it. You'll probably get a bit wet and dirty (maybe use goggles from having to go underneath) but it will definitely get the job done.
    If directions have been followed accordingly it'll come out looking clean and you'll get a better idea on where to apply sealant to the area(s) where you suspect leakage.
    As for that mechanic's advise, I believe he's giving you "the business" (a.k.a a bunch of BS). So save yourself big $$$ and try what others here have recommended first and take it from there.
    Good luck and hope everything works out for you. Also keep us posted with your results.
  7. Sep 26, 2017 at 2:49 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You're welcome. :thumbsup:
  8. Sep 26, 2017 at 2:51 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The story in the opening post is why so many of us DIY.
  9. Sep 26, 2017 at 2:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Isn't that the truth.
  10. Sep 26, 2017 at 3:11 PM
    foreverdown91
    Somar
    Raleigh NC
    2005 yota coma pre
    It won't hurt the belt or hoses if I get it on it? I actually just bought 2 cans the other day for this purpose, but was to scared to actually spray it down in there. Do I take any precautions?
  11. Sep 26, 2017 at 3:11 PM
    foreverdown91
    Somar
    Raleigh NC
    2005 yota coma pre
    Yeah, that's why I'm trying to navigate my way around DIY projects. I know a bit, but not enough to tear her down:/
  12. Sep 26, 2017 at 3:15 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Looks like @Torspd has you covered. That's the easiest fix and should work great. :thumbsup:
    I actually removed my timing cover and resealed it, but honestly that was an irritating chore lol
    foreverdown91[OP] and Torspd like this.
  13. Sep 26, 2017 at 3:46 PM
    Lester Lugnut
  14. Sep 26, 2017 at 4:43 PM
    Tex-Tac
    TEXAS
    That's O K if it gets on any of the hose's, so no it won't hurt anything. I've used this on my Tacoma and really like'd the results afterwards.
    Of course don't get any in your eyes, while spraying and washing if off, etc. maybe :notsure: use goggles as a precaution, if it makes you feel any better.
    Like I previously mentioned, just "follow the directions on the can" and allow yourself plenty of time, don't rush yourself and you'll be OK and good to go.
