Timing Cover Leak/Bad Fuel Diagnosis
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mkzcaldwell, Aug 24, 2023.
  1. Aug 24, 2023 at 2:21 PM
    mkzcaldwell
    mkzcaldwell [OP] New Member
    2021 Tacoma TRD 4x4 Off Road
    Looking to get some advice on some issues I've been having on my 42k mile 2021 TRD Off-Road!
    Took it in to get serviced a couple weeks ago and after inspection, they said there was a timing cover seal leak that needed to be replaced. An engine pull was required to complete the replacement, so I got it back after about 2 weeks due to some parts being on backorder and overall labor to get it done but all was covered under warranty. I filled my tank 2 days after picking it up and the following day, started noticing some issues.
    There was some high idling going about 70mph on the highway, and RPMs would stick around 3000. The following day I still felt the same stall when I would accelerate from a stop and it'd jump a but after trying to get past 20mph so it instinctly felt like a transmission/timing belt issue, but it was occurring at lower speeds now. I never had these issues before taking it in.
    The CEL came on so I called the dealership and took it in within the hour – I was initially just thinking that something wasn’t done right when they put the engine back in. When they called me today they said the codes coming back were for misfires, and that it’s likely a bad fuel issue (from when I filled my tank). I’ve been using the same gas station forever with no issues, so I’m wondering if they’re trying to scam me for their mistake or not. Any advice on how I should handle this with the dealership? And/or how I should go about making sure the issue is actually what they say it is?
  2. Aug 24, 2023 at 4:52 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Try and stay as calm as possible first off . They could have let a plug not connected and not saying anything who knows . Take it home and drive it. If it happens again toss it back on there lap. Also if I were you I would tell them your not comfortable now with the situation and you want an extended warranty
    Soonr1 likes this.
  3. Aug 25, 2023 at 10:30 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Did they provide the codes to you? I would be very curious how they are determining bad fuel on a ECU code.
    Chew likes this.
