Timing cover leak location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kgbrev, Mar 3, 2024.
  1. Mar 3, 2024 at 5:56 PM
    Kgbrev
    Kgbrev [OP] Well-Known Member
    2020trdoffroad
    Diamondback SD cover
    Ok, so I keep hearing about the timing cover leak on 3rd gens. However I've heard it's a common problem for gr series engines in general. Where is the easiest place to see these leaks when they start to appear on the 3.5 v6?
  2. Mar 3, 2024 at 6:00 PM
    lbhsbz
    lbhsbz Well-Known Member
    usually right by the power steering pump where the headgasket seem is.
  3. Mar 3, 2024 at 6:15 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Happens at the junction of the timing cover, block and head. That spot lands right behind the power steering pump. Easiest to lay under the truck and look up.
    BlackTRD4Me likes this.
  4. Mar 3, 2024 at 6:44 PM
    lbhsbz
    Oddly enough...my 2016 is all wet with oil right there where they always leak, but it also loses power steering fluid...lol, so we'll see what it looks like after I reseal the pump and clean everything up. I'm not one to get lucky, but I might. lol
  5. Mar 3, 2024 at 7:02 PM
    Kgbrev
    2020trdoffroad
    Anyone got a. Photo of the area?
  6. Mar 3, 2024 at 7:23 PM
    TuesdayTaco76
    TuesdayTaco76 Well-Known Member
    Moochacho
    California… thanks for leaving
    23 Tacoma TRD OR SB CB (chrome bumper✊)
    Still all in my head… but I’m keeping the chrome bumper!
    That’s a dangerous door to be knocking on…. Don’t look and it won’t be there. Just change your oil at every 5 or 7k and whisper sweet nothings to your rig every day… and again, don’t look.
    Dead-Weight likes this.
  7. Mar 4, 2024 at 8:27 AM
    Sparkle_Tooth
    Sparkle_Tooth Well-Known Member
    East TN
    2020 TRD PRO (Magnetic Gray)
    ICON Stage 9 BFG KO2 285/75R/16
    Agreed it is better to not look, BUT if you want to the best way to see it is to rest your head a little on the back of the passenger front tire, and look straight up. You want to focus right behind and underneath the the power steering pump. Blowback will start spreading onto the block but the dripping if there is any will come from the bottom of the power steering pump.
    It rarely leaks bad enough to lose oil between changes, but it can make things messy over time if you don't clean it. Frankly I am very frustrated that Toyota refuses to address this since it has been happening for a long time and across multiple models.
  8. Mar 4, 2024 at 6:46 PM
    Kgbrev
    2020trdoffroad
    Alright I'll dip my head around that area and check
