Timing Cover Removal Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sky59, Jul 11, 2022.
  1. Jul 11, 2022 at 6:01 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    Hey everyone, I have a 1998 Tacoma 2rz I'm currently trying to replace my timing chain but can't get my timing cover off and I've removed the oil pan and removed the oil pick-up tube there are no bolts or accessories attached beside the power steering. I believe just that's mounted on the head. I've read and seen videos of it done without removing the head any suggestions would be helpful, thanks.
  2. Jul 11, 2022 at 6:02 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    Also can take pictures of cover if needed.
  3. Jul 11, 2022 at 6:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I never saw a 2RZ in person does it have the bolt down through the head into the timing cover like the 22Re
    That is most times in a oil puddle.
    *****Yes indeed it does!!! 2 bolts !!!!!!
    Many timing Covers get broken when those bolts are not removed and the BFH is brought out
  4. Jul 11, 2022 at 7:20 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah there's two in top timing cover under valve cover.....
    If your gonna be in there I'd replace with new oil pump and seals (cover and main shaft)...
    and while in there the front main seal on block........
    Harmonic balancers have a limited life, when they go they usally destroy the front seals and sometimes like me....crack inside of timing cover.....might check and/or replace.....
  5. Jul 12, 2022 at 4:06 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    already have removed the 2 head bolts forgot to mention them in the original post and I do have a new timing cover and pump to go in as well. ill look at the harmonic balancers when I get a chance
  6. Jul 12, 2022 at 4:07 PM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    unfortunately, I've already removed them and forgot to mention them in the original post
  7. Jul 12, 2022 at 4:09 PM
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    Have you tried hitting it with your purse?
  8. Jul 12, 2022 at 4:10 PM
    Bivouac
    You might need to being very gentle pry the cover loose .
    It has been on there a few years.
    Good luck!
  9. Jul 13, 2022 at 5:46 AM
    Sky59
    Sky59 [OP] Member
    Sky
    1998 tacoma 2.4 2wd
    good idea bud next time your wife's over ill give that a try
  10. Jul 13, 2022 at 8:21 AM
    Bivouac
    The thing with using your purse is to much gets broken in your purse.
    I tried using a purse to knock something loose She was not happy I broke her net book and phone.
    That was a very expensive lesson Never use a purse .
