Timing issue, need some insight
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ironworker84, Dec 24, 2022.
  1. Dec 24, 2022 at 11:21 AM
    Ironworker84
    Ironworker84 [OP] Well-Known Member
    Eric
    2001 White Tacoma 4X4
    Hey,
    Been throwing a camshaft position sensor code for a month now. Everytime I pull the cover of the timing belt. I notice it continuously is of a tooth or two after I set it to TDC. Just now I set the belt back to where it should be. So marks align. Install tensioner, and turn it two full revolutions. Now my crank is at 0° but my cam marks are off 4 or 5 teeth. WTF. This shit is giving me a headache.
  2. Dec 24, 2022 at 11:26 AM
    Bishop84
    Bishop84 Well-Known Member
    So when you set the timing you need the slack, all the slack, on the tensioner side, so its tight along the idlers.
    Are you using a belt with timing marks?
    What I usually do is, no tensioner, no mid top idler. I install the belt, set the timing, rock the gears towards each other, install idler, then lastly the tensioner bearing with tensioner.
    turbodb likes this.
  3. Dec 24, 2022 at 9:54 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Water pump, idler bearing and tensioner bearing in good condition?
  4. Dec 25, 2022 at 12:46 AM
    Ironworker84
    Eric
    The idler pulley bolt doesn't tighten all the way, it just spins when I try and tighten it. Should I tap the idler pulley bolt hole one size up. Does anyone know the size of the idler pulley bolt? Would the timing issue be the cause of my camshaft position sensor CEL P0340?
  5. Dec 25, 2022 at 10:16 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Yes,yes,yes and yes. I'd try to helicoil the stripped out hole.
  6. Dec 25, 2022 at 11:53 AM
    Ironworker84
    Eric
    Helicoil, never heard of it. I've done the timing belt a few times and have never had an issue like this before. Granted it's not a new belt. I'm not replacing it, I just need to correct the timing. I usually line up the crank and then put it in gear. Chalk the tires and E brake it so it absolutely doesn't move off 0°. Anyone know the bolt size for the idler pulley.
  7. Dec 25, 2022 at 11:58 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Time-sert is a lot stronger
    tsab916 likes this.
  8. Dec 25, 2022 at 12:19 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    If the idler pulley bolt is stripped, and the timing is off you might want to check the cam pullies and make sure the dowel pins are present.
