Timing mark confusion over crank pulley
Discussion in '1st Gen. Tacomas (1995-2004)' started by rydethahillz, Jun 6, 2013.
  1. Jun 6, 2013 at 3:59 PM
    rydethahillz
    rydethahillz [OP] Active Member
    Dave
    Phoenix
    03 tacoma 4x4 5spd xtra cab
    Im currently replacing my timing belt, waterpump, thermostat, idler bearings, tensioner and all 3 accessory belts.. Prior to removing the timing belt, i made sure to rotate the crankshaft until the camshaft pulleys lined up at TDC. All 3 marks were aligned perfectly when at TDC (both cam pulley's as well as the marking at 12 o'clock on the crankshaft and oil pump). The crank pulley however was set to "5' rather than "0". Could this be due to the cureent belt being stretched out after 10 years?
    i guess my biggest question is should i reisntall the new belt this way? or should the pulley point at "0" when the cams and crank are all at TDC?
    This is an 03 3.4L 4x4 - 5sp with 38k miles. Im just replacing all of these parts due to age. The belt looked great when i pulled it off last night.
  2. Jul 29, 2013 at 4:03 PM
    Gooiegoogoo
    Gooiegoogoo Well-Known Member
    Gustavo
    Phoenix
    03 TRD SR5
    2" lift
    what was the outcome to this?
  3. Jul 29, 2013 at 10:10 PM
    rydethahillz
    Dave
    Phoenix
    I think those marks may be there to show you how much the belt has stretched? When I installed all the new parts and the new belt, it was set back to "0". Purrrrrs like a mountain goat now.
    Dont quote me on this though, I drank a whole lotta beers.
