Timing question: cams and crankshaft marks not matching
Discussion in '1st Gen. Tacomas (1995-2004)' started by white3911, Dec 9, 2016.
  1. Dec 9, 2016 at 7:01 PM
    white3911
    white3911 [OP] Member
    Indianapolis, IN
    1996 XtraCab V6
    Hello TacomaWorld,
    I am currently installing a new timing belt on my 1996 5vz-fe. Used a Contitech timing belt kit. Here are a few pictures of the new belt installed:
    Timing seems to be off. What is throwing me off is the yellow marks on the left camshaft pulley are aligned. In addition to that, I believe this is how the pulleys were before removing the old timing belt. This is the only picture taken before the timing belt was removed:
    Is my timing correct or do I need to adjust the left camshaft?
    Thanks for any advice!
  2. Dec 9, 2016 at 7:06 PM
    white3911
    Indianapolis, IN
    1996 XtraCab V6
    Better picture of the yellow marks:
  3. Dec 10, 2016 at 9:18 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
  4. Dec 10, 2016 at 11:39 AM
    white3911
    Indianapolis, IN
    1996 XtraCab V6
    Any ideas skeezix?
    Input is appreciated!
  5. Dec 10, 2016 at 11:42 AM
    maulcruiser
    maulcruiser Well-Known Member
    Wilmington, NC
    96 Tacoma Xtra Cab 3.4L 5-speed
    OME kit
    I'd say yes, adjust the left. It appears to be one tooth off.
  6. Dec 10, 2016 at 1:21 PM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    You're a tooth off on that one cam wheel.
  7. Dec 10, 2016 at 3:29 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    where's the line on the right cam? or is this after you turned it a few times? the belts should come with indicator marks for lining things up. I do remember having to pry on the belt to get one of the marks to line up correctly but we lined up the top two first.
    Also did you make the yellow marks or were they on there already?
  8. Dec 10, 2016 at 5:56 PM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    Yeah there should be lines for both. The marks should also be as close to the top as possible. Seems off to me too.
  9. Dec 10, 2016 at 6:28 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Install the belt in this order
    Left cam
    Water pump
    Crank
    Idler between L and R cams
    Right cam
    Tensioner
    Once you have the tensioner set rotate the engine by hand and check your timing marks
  10. Dec 10, 2016 at 9:05 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
  11. Dec 11, 2016 at 9:11 AM
    skeezix
    Colorado
    1998 Limited
    No, no ideas. After I installed my belt, the timing marks at the cams were slightly off. Not perfect. Then I rotated the crank, brought the marks back up to the top, and they were still very slightly off. I buttoned everything up and started the engine and it ran okay. Guess I can't expect drafting-board perfection in real life ;)
  12. Dec 11, 2016 at 10:34 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Yes, you can. It will line up perfectly. What a waste of an effort. Your base timing is going to be way off and you ECU is going to have to try to fix it, and it can't long term. You're going to get shitty mileage and power. Sorry to say it.
    Wulf and mechanicjon like this.
  13. Dec 11, 2016 at 12:37 PM
    mlcc
    Oregon
    Agreed. OP you need to get those cams lined up properly, sometimes it helps to have the Left came forward 1 tooth then go over the water pump and crank then reverse the left cam 1 tooth so its lined up again that will make the belt tight from the crank up to the Left cam, you want it to be tight from the crank up to the left cam when installing so its easier to slip it over the tensioner pully.
    TooMuchToDo likes this.
  14. Dec 11, 2016 at 7:38 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Yea. Do over. As long as the lines on the belt are on the correct place on ALL THREE SPROCKETS it doesn't matter whether your in the right place according to the cam marks on the cover(s).(it's just another reference point to check with) You sure the belt is facing the right way?
    You didn't show the crank but you are def. at least 1 tooth off from what I see.
  15. Dec 13, 2016 at 1:19 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Agree one tooth off.
