Timing? Timing chain? Valve? Bad motor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by maza mike, Mar 24, 2013.
  1. Mar 24, 2013 at 5:46 PM
    maza mike
    maza mike [OP] Member
    1996 Tacoma 2.7 3rz automatic extended cab
  2. Mar 24, 2013 at 5:47 PM
    maza mike
    This is not my vehicle, but mine is a 2.7 3RZ
  3. Mar 24, 2013 at 8:47 PM
    adower
    adower Well-Known Member
    My old ranger had that noise. Ticking that would go up or down with the RPM. Turned out to be a valve. :(
  4. Mar 24, 2013 at 9:54 PM
    joeer77
    joeer77 Active Member
    North Plains OR
    Bilstein 5100s
    How many miles on engine? I had a connecting rod bearing wear out on a rebuilt 22RE engine and it sounded similar. When the rod bearing wears, the piston has more room to move up and hits the valves on the up stroke. The engine lasted another 300 miles after the clacking started. Had to replace motor.
  5. Mar 24, 2013 at 9:57 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Kind of sounds like a connecting rod or wrist pin bearing. But sounds like it's misfiring or the timing is crap. Just my .02
    You can kill spark to cylinders and see what happens. If all the sudden the noise goes away or it doesn't drop in RPMS either that cylinder isn't firing or you've found the cylinder that has the noise problem like a rod knock etc... if it's valves it shouldn't change but you should drop in RPMs.
  6. Mar 24, 2013 at 10:08 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Is the timing chain tensioner functional? How did the guides look?
