Tink sound from driveshaft area when changing gears
Discussion in 'Technical Chat' started by tr1957, Nov 8, 2017.
  1. Nov 8, 2017 at 1:17 PM
    tr1957
    tr1957 [OP] Well-Known Member
    Alabama
    2011 regular cab 4x4
    Recently my truck started making a metallic tink sound when changing gears.
    The sound appears to be coming form the front u joint to transfer case area and also the back u joint area.The u joints seem good and tight . The truck is a regular cab manual 4x4 . See attached video.Any ideas? How do I attach a video file?
    Thanks
  2. Nov 8, 2017 at 5:39 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I think you have to upload your video to youtube, then provide a link.
  3. Nov 8, 2017 at 6:33 PM
    tr1957
    Alabama
  4. Nov 15, 2017 at 9:40 AM
    tr1957
    Alabama
    Anyone?
  5. Nov 18, 2017 at 2:09 PM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    id take that to the tranny shop buddy. that rear end might be on its way out
    themanbearpig012 likes this.
  6. Nov 19, 2017 at 8:00 AM
    tan4x4
    Rick
    Folsom, CA
    Hopefully its something simple like loose u-bolts in the rear, or leaf-spring related issues.
    I'd get under there and check everything for tightness.
    Not familiar with 2nd gen drivetrains, but in the second half of the video (front DS?) the 'upper' joint
    seems to wobble a bit.
    If you do take it to a shop, go to a drive-line or differential shop. I bet they could give you a pretty good diagnosis just by watching/listening to that video.
  7. May 14, 2018 at 6:30 PM
    tr1957
    Alabama
    Still driving it ,still clinking when changing gears or lurching .I guess eventually the problem will manifest itself.
    Also has the 55 to 60 mph whine from the rear end when under light throttle to coast .
  8. May 14, 2018 at 6:35 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Check your u-joints for tightness and also check the flanges on the axle and tcase for tightness too...if the nut isn’t staked well it can loosen and make noise like that. That clatter is slop in the driveshaft or a driveshaft related component
  9. May 14, 2018 at 6:57 PM
    tr1957
    Alabama
    Thanks I checked the t-case flange nut and it seems tight i did not check the rear diff flange. I will check it .
    The problem was not noticeable during cold weather but now I can hear it every gear change.
  10. Nov 25, 2018 at 9:20 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    U-joint, or maybe slack in the ring and pinion runout(?) setting.
  11. Nov 25, 2018 at 11:35 AM
    tr1957
    Alabama
    Still driving it ,still clinking , 85 k miles . Turned the driveshaft around no difference in the clink but it did stop the rattling grinding sound when letting off the gas at 70 +mph, I read others have done this on a regular cab to stop the rattling sound. I will keep driving it the problem doesn't seem to get any worse.
  12. Nov 25, 2018 at 11:39 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Preload on the pinion bearing is gone !!!
  13. Nov 25, 2018 at 11:49 AM
    tr1957
    Alabama
    maybe ,I have not found anyone that seems to know much about it.
    US Marine likes this.
  14. Nov 25, 2018 at 12:09 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Easy to check !! , just drop driveshaft at rear axle with a socket see if the pinion nut the holds the yoke is tight or finger loose . If loose the crush sleeve or shims on the pinion gear are shot allowing excessive preload and that's the metallic sound you hear
    Jckdnls likes this.
  15. Nov 25, 2018 at 3:30 PM
    tr1957
    Alabama
    I should have checked that when I turned the driveshaft around .
    Thanks I will check it .
  16. Nov 25, 2018 at 3:38 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Another way besides what I mentioned is to drop the driveshaft from the rear axle . Next grab the pinion yoke and pull outwards ,if you can pull on it easy enough and hear a metallic sound the pinion preload is bad
