Tinny Rattle when in neutral and upon take off V6 6 speed manual 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, May 20, 2014.
  1. May 20, 2014 at 9:45 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Ive had this issue intermittently since ive had the truck since new, but now its almost constant, if I rev alittle while sitting still, or during takeoff I get an annoying tinny kind of rattle, it sounds like an exhaust rattle but im not sure if it is or not, or if exhaust rattles are a common thing with these trucks. And if it helps with anything, on the way home I kinda got on it pretty good in order to get in front of another driver so that I did not miss my exit, so I wonder if this sudden acceleration had attributed to this rattle, truck only has 21k miles on it, thanks for your time and input
  2. May 20, 2014 at 9:58 PM
    Kyle Butler
    Kyle Butler Well-Known Member
    1972 LeBaron
    Green, some brown or rust coloration, a tape deck, some Creedence tapes
    Could be something with the exhaust. I had a rattle/buzz that turned out to be the housing on the driver side catalytic converter. It was a little loose on one side and made a thin metal on metal rattle that was most pronounced at 2000 rpms. I just put a hose clamp around it and that stopped the rattle.
  3. May 20, 2014 at 10:07 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    I really wouldn't be surprised if that was the case, ill try a big hose clamp, see what happens, it wouldn't surprise me because it definitely sounds like its coming from the front and not the rear of the vehicle
  4. May 20, 2014 at 10:16 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Doesn't make any difference if the clutch is depressed or not lol
  5. May 20, 2014 at 10:31 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Plot twist, I just went to go mail a letter and the rattle is not there, back to how the truck usually is, ill take it that I most likely pissed off a cat heat shield with the sudden extreme heat of the random acceleration from before, being that I don't really get on my truck too often... who knows, life is certainly weird.
  6. May 21, 2014 at 1:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is one big ass clamp there! A house clamp!
  7. May 21, 2014 at 10:43 AM
    kyleTRDtaco12
    Kyle
    New Jersey
    Haha **HOSE lmao, gotta love auto correct
  8. May 21, 2014 at 10:46 AM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Had a small rock that was rattling around the same housing Kyle was talking about. Shit drove me crazy.
  9. May 21, 2014 at 11:00 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    had this going on with an old ford ranger i had. it was the cat converter as described above..
  10. May 21, 2014 at 11:49 AM
    reg boulette
    reg boulette Well-Known Member
    Check for loose heat shields on the exhaust system.
  11. May 21, 2014 at 5:54 PM
    photoguy190
    photoguy190 Well-Known Member
    James Goff
    Middle TN
    I'm having a very similar problem most pronounced around 1700 rpms, loudest on acceleration but can still hear it as it comes back down. Now I was surprised that it not noticeable if I run the rpms up in neutral. But will make the noise in 1st with the parking break on, sitting still.
    I'm not seeing anything that looks super lose. Do you have a picture of your fix?
