Tint question - rear window
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fullripbrian, Aug 16, 2019.
  1. Aug 16, 2019 at 1:47 PM
    fullripbrian
    fullripbrian [OP] Well-Known Member
    Seattle sucks now.
    2017 SR Utility
    Truck is currently at the tint shop, just got a text letting me know they couldn’t tint the rear window due to my canopy being in the way.
    While it may be more difficult, I can’t see it being impossible.
    Wasn’t mentioned when I dropped it off and did a walk around with the tech.
    Can anyone with experience chime in on this?
    The truck is an SR with clear factory glass and a solid rear window.
    *Edited to include truck specs*
  2. Aug 16, 2019 at 1:48 PM
    4x4_Angel
    4x4_Angel Perfectly Imperfect Tomboy
    Bree
    2014 Toyota Tundra CM SR5 4x4
    Sounds like they are idiots imo
    02Duck, tinker_troy and TnRedNeck721 like this.
  3. Aug 16, 2019 at 1:52 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Since when do you put tint on the outside of the glass.
    02Duck, CouchlessPotato, Chew and 2 others like this.
  4. Aug 16, 2019 at 1:52 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Why would the canopy be an issue? I thought tint is normally applied on the inside surface...
    4x4_Angel likes this.
  5. Aug 16, 2019 at 1:53 PM
    fullripbrian
    Seattle sucks now.
    2017 SR Utility
    Guy claims his tech likes to use the outside dimss to measure. BS as far as I’m concerned.
  6. Aug 16, 2019 at 1:57 PM
    dub808taco
    dub808taco Well-Known Member
    2017 TRD OR 4x4 MT Super White
    the guy I take all my cars too, uses the outside to measure and cut (nothing super precise or anything), before going on the inside to install. But it shouldn't be a show stopper as that's what the shop is making it sound like
    4x4_Angel and DWD484 like this.
  7. Aug 16, 2019 at 1:59 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    My impression is that the shop isnt very hungry for business. I'd respond with "well if you cant do it, perhaps I can find someone else up the road that can."
  8. Aug 16, 2019 at 2:01 PM
    fullripbrian
    Seattle sucks now.
    2017 SR Utility
    Guy didn’t tell me until the rest of the job was finished...
  9. Aug 16, 2019 at 2:04 PM
    dub808taco
    the shop refuses to measure on the inside and install?
  10. Aug 16, 2019 at 2:04 PM
    coopcooper
    alberta canada
    Ok so they spend a few minutes and slide your canopy back a few inches, unless they are inept and don't know how to do that, or want to charge you an arm and a leg to do it. Either way sounds like a them issue, they should of noted that during the walk around.
  11. Aug 16, 2019 at 2:11 PM
    fullripbrian
    Seattle sucks now.
    2017 SR Utility
    Ok, this sounds reasonable. Would have been less irritating if discussed at drop-off.
    4x4_Angel and DWD484[QUOTED] like this.
  12. Aug 16, 2019 at 2:13 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    weirds
    where did you go, if I may ask?
    I always go to Midnight in Bellevue but, I have never had a canopy or anything to deal with.
  13. Aug 16, 2019 at 2:16 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    go to another shop
  14. Aug 16, 2019 at 2:22 PM
    fullripbrian
    Seattle sucks now.
    2017 SR Utility
    Mr. Detail in Ballard. Walkable from work and seemed to have decent reviews.
    Will likely go to midnight tint to finish the job.
    Edit: Midnight won’t do the job without pulling the canopy either.
    What ever happened to Adapt, Improvise, Overcome?
  15. Aug 16, 2019 at 2:51 PM
    tinker_troy
    T R O Y
    WY/SD
    Bummer
  16. Aug 16, 2019 at 2:59 PM
    edgerat
    edgerat Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    in that area I would use Imperial, no doubt.
  17. Aug 17, 2019 at 5:54 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This too me, is the shitty part. I'm guessing had you been told, you'd have to take it to another shop, and be down another day, you would have not used them. I wouldn't have.
  18. Aug 17, 2019 at 5:55 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Any tint shop worth a damn is going to cut the tint out with a plotter (time=money), so it should have been a non-issue.
    jwcox72 likes this.
  19. Aug 17, 2019 at 6:12 AM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    The place I had mine does has a precision cutting machine that cuts the tint. Just type in what vehicle the tint is for and it cuts it. Quick and easy. I went in, asked em how busy they were, they said they could have me finished in 45 minutes. In and out quickly!
  20. Aug 17, 2019 at 6:15 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Yup. :thumbsup:
    Time=money
    The more cars you can turn over in a day, means more money. A plotter means no messing around with manually cutting the tint (except the windshield usually).
    fullripbrian[OP] likes this.
