Tint Shade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MachTac, Nov 27, 2014.
  1. Nov 27, 2014 at 7:38 AM
    MachTac
    MachTac [OP] Well-Known Member
    Kody
    MD
    Storm Trooper in boot camp
    2'' Spacer Lift 15% Tint Thrush Turbo Muffler It's All About That Bass STICKERS!
    Just got 15% tint on the front two side doors of my access cab. Its pretty close to matching the access door windows but not quite. Im OCD and want it to match better. What % comes stock on these things from factory and what shade should I add to pull the privacy glass down to 15%?
    Thanks
    Kody
  2. Nov 27, 2014 at 7:42 AM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    Surprised that isn't darker than the privacy tint..
    I have a double cab and matched the front to rears and it was 27%
    I think to get a perfect OCD approved tint match you'll have to take off the front windows, ask the tint people to shoot the back window with the tint reader gun, then reapply a darker. otherwise it'll pretty much always be off a little.
    That's my Opinion, could be other methods though.
  3. Nov 27, 2014 at 8:30 AM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    I was always under the assumption that factory tint was somewhere around 18-20. I got 35 because I'm in Mass, and it's close enough lol
  4. Nov 27, 2014 at 8:51 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You will never truly be able to get an exact match since the OEM glass is smoked and it is a slightly different color from all of the tint films I have used. Also, with light coming in from the wind shield the front side windows will appear lighter.
  5. Nov 27, 2014 at 10:58 AM
    MachTac
    Kody
    MD
    Ok... so what shade of tint should I put on the access doors to bring it closer to the 15% shade i just put on the pass and driver door?
    Im thinking somewhere around 35% will bring the access door factory tint down to 15%?
  6. Nov 27, 2014 at 1:59 PM
    dexterdog
    Oly WA
    2012 F150
    I would talk to the tint shop and tell them what you are looking for.
  7. Nov 27, 2014 at 11:38 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    oem is equivalent 20% smoke black film.
    "what shade should I add to pull the privacy glass down to 15%?"
    so whats the goal? black out the truck or just match the rear to the front 15%?
    i would do 5% on rears and 10% on the fronts. the fact that the rears let in very little light will even out the fronts pretty good and give you privacy and you can still see well out of the fronts. dont forget that the windshield lets alot of light into the truck, so the front windows also are basically 'backlit' like a laptop screen. so you want to kill as much inside light as possible with the back window tint.
    in any case a couple months ago i tinted my windows on my quad cab, i got the film from these folks
    http://www.ebay.com/itm/190850490802?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    film is really good quality, pre-cut, pretty easy install and you can get real 'smoke black film' color to match the oem privacy glass.
    main thing is do the COLOR/SHADE of the front and rear exactly match (even if the darkness does not)? if the color or reflection doesnt match, just scrap the front film and start over. i tinted several of my cars/trucks over the years myself, i may be able to offer some advice.
  8. Nov 27, 2014 at 11:51 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    this is 5% on rears and 10% on fronts with daylight starting to fade at about 5:30pm
    if you just want to match the windows, strip the 15% off front and redo them with 20% smoke black 2 ply or 3 ply film
  9. Nov 28, 2014 at 6:32 AM
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    I did 15 up front and 20 in the back of my double cab and it matches pretty good.
  10. Nov 28, 2014 at 8:01 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Stock Toyota privacy glass is 27% +/- 3%. I have tested this with a tint meter we have at work to confirm it.
    The best most commonly available match for the front windows is 30%.
    This is what I have on and they are consistent with the appearance of the back windows.
    I don't think it works like this, exactly. It has to be proportionate, and there surely is a formula, but, as noted; it's probably best to have a pro tint shop figure it out. I will tell you that when I bought my truck it had 4% tint over the access cab's existing tint, and when I tested the glass with the tint installed it was at 4%, meaning that the underlying factory tint had no bearing on the 4%. I presume this is due to the extreme darkness of the 4% tint, and lighter tints might be different. So, putting 35% on top of the existing 27% tint might actually not bring it down as much as you would think.
    4% by the way, is just too dark. I couldn't see out the windows at night.
  11. Nov 28, 2014 at 9:30 AM
    MachTac
    Kody
    MD
    Scraping the front tint is not an option. And im not trying to match the front with the back, im actually doing the opposite. And im not worried about light coming in.
    I simply want to know which percent shade I should add to the rear windows to match my 15% tint on the front.
  12. Nov 28, 2014 at 9:30 AM
    MachTac
    Kody
    MD
    Please :)
  13. Nov 28, 2014 at 9:36 AM
    1eyedclyde
    1eyedclyde Well-Known Member
    CJ
    New Castle,CO
    15 DCLB Limited, 01 AC V6
    I tint for a living and if you want the rears that are about 26% stock to be at 15% you will need to use a 60% on top of the existing. It should then meter out at about 15.6. You better meter your fronts with film on them. Glass is not 100% clear, it's usually around 79% without any film on it.
  14. Nov 28, 2014 at 7:55 PM
    MachTac
    Kody
    MD
    The highest I can get is 50%. That should bring it down close enough.
    Thanks eyedclyde
