Tint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808brian, Jan 17, 2012.
  1. Jan 17, 2012 at 7:07 PM
    808brian
    808brian [OP] Well-Known Member
    Brian
    Maui
    Black z
    I have a black 2010 Tacoma double cab. Anyone suggest a good tint film to match the back factory tint? I had problems with the greenish hue tint color. Don't like how it doesn't match the rear windows.
    Pls post pics and percentage. That would help. I have on solar gard hp supreme 16% all around.
  2. Jan 17, 2012 at 7:28 PM
    jjbsocal
    jjbsocal Well-Known Member
    Jeff
    So☆Cal
    2010 DCLB PreRunner TRD Sport
    Camburg MT; 4.0 Spindles and UCA's, Fox Extended Travel with Resi's all 4 Corners, All Pro Expo Leaf Pack, Method Standard's, BFG AT's, DTLT's, 1st Gen TRD CAI, Magnaflow Pro Offroad Exhaust..
    Maybe because you're in HI its the green, here in Mainland its 20% grey.. 3M matches perfectly.. Try 3M, they seem to have the factory specs on most vehicles.. It is expensive though.
    There's a thread here that shows the factory percentage and hue for all the toyota models, just search for it..
  3. Jan 17, 2012 at 7:38 PM
    matts11
    matts11 Well-Known Member
    TN
    I think you are referring to the greenish hue to the factory glass. I had an issue with this. Tried two different films that matched the back from a light percentage standpoint but both had a slightly greenish hue in direct sunlight when compared with the back. If I were to do it to the 12 I would probably get the rears done darker and then put 15% on the front to match. This should be dark enough to block out the greenish factory hue.
  4. Jan 17, 2012 at 7:49 PM
    808brian
    Brian
    Maui
    Black z
    I have 16% on the two front and 16% over the factor. Still has the green hue. Unless I go 5 % on the front?
  5. Jan 17, 2012 at 9:52 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    dont use windex to clean the inside of your windows with tint, it will turn it to a purple hue, trust me i know this :)
  6. Jan 18, 2012 at 2:14 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    have 15% Llumar, perfect match. Just remember to take your sunglasses off when pulling in a garage.:)
  7. Jan 18, 2012 at 3:57 AM
    ACE808
    ACE808 Well-Known Member
    DDS
    808 State
    TRD Off Road 4x4
    Toytec 3" lift light racing uca moto metals 17" (958) k&n intake Helix throttle body Borla exhaust Nfab step bar All-pro transfer case shield All-pro spindle gussets All-pro sway bar links All-pro E-locker guard All-pro rear differential armor All-pro U-bolt flip kit L.E.D. White/Blue Dash Gauge lighting Full alpine stereo with TV screens Clifford alarm optima red top battery Full wet okole seats auto meter gauges (oil pressure & volt meter) Ebc slotted & dimpled rotor Goodrich braided brake lines Hawks Lts brake pads Rear diff breather relocation
    Go to AL's Tinting. They know.
  8. Jan 18, 2012 at 3:57 AM
    ACE808
    DDS
    808 State
    TRD Off Road 4x4
    Oh Shet u on Maui. My bad.
  9. Jan 18, 2012 at 6:35 AM
    NetDep
    NetDep Well-Known Member
    Tim
    Southern Utah
    2011 Toyota Tacoma Off Road MGM
    Although the State law in Washington is limited to 35% -- the % that matches the facotry back part of the access cab is 20% so that is what I got. The guy that put the tint in told me the potential risk but it looks so darn good!! My sig picture kind of shows it - but I attached another pic. Like others have said - use a NON ammonia based cleaner!! I really like the look of the tint and quality installation is really important!! Enjoy!!
  10. Jan 18, 2012 at 7:13 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I had 20% 3M tint put on and from the outside it appeared to match the rear windows, but from the inside it seemed darker than the rears. So I went with 35%. I'm much happier with it. With the 20% I could barely see my mirrors at night as well. Seemed too dangerous for just looks, plus the darker in the front thing was kind of annoying.
  11. Jan 18, 2012 at 10:09 AM
    matts11
    TN
    It is pretty well documented if you search this site that the factory tint on the back windows is roughly equal to like 27%. There is some "tint" to the front windows that makes it look slightly green that when combined with 35% tint will match the rear from a light transmittance standpoint. Now, on an access cab, the size of the rear windows will make it less noticeable that the darker tint (15 or 20) is actually not a match. But if you put 15% on a double cab front windows it will be darker than the rear and when I had this on my 2011 I found it annoying. My best suggestion is to look at all of the tacos you see with the front tinted and when you see one that looks perfect try to flag them down and ask them where they got it done!
  12. Jan 18, 2012 at 10:22 AM
    speedfreek
    speedfreek Well-Known Member
    David
    Alafreakingbama
    '12 370Z 6MT
    I did 3M tint 30% all the way around and 50% on the front glass. Looks good and keeps it cool in the summer. I have had no issues with visibility at night.
  13. Jan 18, 2012 at 10:51 AM
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    The tint shop my dealer uses applies 15% to the front windows and 50% to the rear and claims it matches. Another tint shop said the same. Both use Llumar ATR. I'm having my truck done in the next couple of weeks and I'll post the results.
  14. Jan 18, 2012 at 1:36 PM
    808brian
    Brian
    Maui
    Black z
    Badwin keep me posted man
  15. Jan 30, 2012 at 8:39 AM
    Badwin45
    OKC
    Had my truck done last Friday with Llumar ATR. 50% on the back and 15% on the front. The front windows are slightly lighter than the back but that doesn't bother me at all.
  16. Jan 30, 2012 at 8:43 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
  17. Jan 30, 2012 at 8:45 AM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    ^^ that 15% in the front looks good, seems like if you look through the side you'll just see a slight shadow of whoever in there right?
  18. Jan 30, 2012 at 10:36 AM
    Badwin45
    OKC
    ^^ Depending on light conditions, yes.
  19. Jan 30, 2012 at 10:48 AM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    So then usually you really can't see in ?
  20. Jan 30, 2012 at 10:52 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    What did everybody pay, if you don't mind me asking? Looking to tint out the front to match the back in the next week or two myself.
