Tinting Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scdude37, Jun 9, 2010.
  1. Jun 9, 2010 at 7:20 PM
    scdude37
    scdude37 [OP] Lil Blue
    kendall
    Florence, South carolina
    05 PreRunner SR5 stock now
    tinted windows that are 20%
    i have 20% tint all the way around right now on my access cab tacoma. I was wondering if i put 15% over that how dark would my windows be. I went to a tint place and i said i wanted it close to 5%. So they said 15% would be the way to go. I am not sure. I would like some help on this.
  2. Jun 9, 2010 at 7:23 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    put another layer of 20% on top and you'll be at like 4%
  3. Jun 9, 2010 at 7:27 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Better to scrape off what's currently on there and just get 5%.
  4. Jun 9, 2010 at 7:29 PM
    l_prettyman
    Logan
    06 4x4 SR5
    our front windows have a factory 80% up front, so if the OP did that they would have to put 10% on to equal out to about 6%
  5. Jun 9, 2010 at 11:13 PM
    scdude37
    kendall
    Well i just did 15% over the 20% and it definetly isnt 4% over lower, its more like 8% or higher. Idk maybe just have to give it time to settle in.
  6. Jun 9, 2010 at 11:21 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    See the way to think of this is that the 20% will let only 20% of light through. Putting 15% over the top of that theoretically will only allow 15% of the initial 20% through. Of course there will be a little distortion there... Math says that you should have a 3% tint after that. The fact that tint is not perfect says that you will experience a tint level of probably around 5-7%
  7. Jun 9, 2010 at 11:24 PM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
  8. Jun 10, 2010 at 7:15 PM
    scdude37
    kendall
    Thanks man! i really appreciate that. That does help, i think it looks around 5-8%. I was just wondering b/c it was getting layered over and a friend looked at it and said it was 13%, which is impossible considering it is 15% over 20%.
  9. Jun 10, 2010 at 7:19 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I have 5% tint over the stock tint in the rear doors and back window, and 27% over the stock tint in the front doors. I never had them tint-check it after putting it on.
    Maybe I should :p Don't want to get below the legal limit of 27% here in SC.
  10. Jun 10, 2010 at 8:19 PM
    Rhino8541
    Rhino8541 I like ze best!
    AZ
    2017 QS DCSB OR
    To get a rough estimate, you just multiply the percentages as decimals. As stated before: .15 (15%) multiplied by the current .2 (20%) yields .03 or 3%. Now this isn't perfect at all, but close.
    I have 2 layers of 20% on the front windows, and 20% tint laid over the factory 20% glass, and using a meter my tint is at 3% even though mathematically it should be at 4%.
  11. Jun 11, 2010 at 2:10 PM
    scdude37
    kendall
    O tru. Do u work at the firestation, where they are doing all that construction next to I-95? Also, I figured i would do lower than 27% because, some many people in florence and surrounding areas have it that way. I know just a few that have gotten tickets, but not many. I had 27% on my camaro, and it was decent but i like my tint now, i really like the darkness and how much cooler it stays inside!
