Tinting Tail lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxcjtxx, May 7, 2010.
  1. May 7, 2010 at 2:14 PM
    xxcjtxx
    xxcjtxx [OP] Member
    CJ
    Cali
    2008 TRD Sport Black on Black
    I have read a couple write ups but i still have some questions.
    Some people say sand/wet sand them then use rubbing compounds and polish and all this stuff and others say just clean them real well and spray a couple coats of nightshade on them.
    Oh and what about paint adhesive? will that work as a substitute for sanding?
    Which is better?
    Also, what is the best way to get that 3rd light done? just tape newspaper around it?
    Making up my list right now about to go to NAPA
    Got VHT nightshade (1 can?)
    Krylon gloss clear coat
    headlight restore kit?
    then if sanding turns out to be the best way ill add
    green scotch pad
    rubbing compound
    plastx
    Thanks
  2. May 7, 2010 at 2:17 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    add 2000 grit sand paper to that list. you want to scuff up the lights before you paint to get the paint to fully bond with the plastic.
    After your spray your clear you will want to wet sand again with 2000, then use the platix to buff out the dull'ness.
    for the 3rd brake light you can take it off, its just a little cover on there. same steps for this as well
    I just did mine but in reverse order, removing old tint from my tails
    here is the complete step by step write up
    http://www.tacomaworld.com/forum/lighting/84694-how-tinting-tail-lights-right-way-pics.html
  3. May 7, 2010 at 3:02 PM
    xxcjtxx
    xxcjtxx [OP] Member
    CJ
    Cali
    alright i will get 2000 grit sandpaper instead of the scotch green pad
    3 coats of shade and 1 of clear coat is perfect right? or more coats for darker?
    and do i need the rubbing compound? what does that even do
  4. May 7, 2010 at 3:03 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    3 coats is a little dark... and more clear coats
  5. May 7, 2010 at 3:06 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  6. May 7, 2010 at 3:09 PM
    xxcjtxx
    xxcjtxx [OP] Member
    CJ
    Cali
    awesome thanks
  7. May 7, 2010 at 3:11 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    No problem!! If you use that method let me know how it turns out. I will probably tint my sets next week sometime. I have everything except for some 800 grit sandpaper.:cool: Watch how many coats you put on of that nightshade stuff too. I know someone that did 2 coats and it came out pretty dark.:eek: I might just do 1 coat and call it good.:rolleyes:
  8. May 7, 2010 at 3:19 PM
    xxcjtxx
    xxcjtxx [OP] Member
    CJ
    Cali
    yea ill take b4 and afters
    no idea how long it'll take.
    drying times the worst...
  9. May 7, 2010 at 3:22 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I think they said around 4 hours or so.:rolleyes: So it will take a bit of time I presume. I am going to tint my 06's first one day then do the 2010's some other day.:cool:
  10. May 7, 2010 at 3:23 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Niteshades, clean em off with alcohol and then spray 3 to 4 coats then add a couple clear coats and be done with it. I did this and have had zero problems with my lights. you dont need to sand.
    Edit: Oh and dont forget the 3rd brakelight:) i noticed it one day walking up to my pickup, it stuck out pretty good.
  11. May 7, 2010 at 3:24 PM
    xxcjtxx
    xxcjtxx [OP] Member
    CJ
    Cali
    you were actually the guy i was talking about when i said some people say no sanding hahah
  12. May 7, 2010 at 3:25 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    How long have you had them tinted for? From the looks of your pics, they dont seem to be to shiny.:cool: But thats good on your truck though cause it matches the color of the truck.
  13. May 7, 2010 at 3:36 PM
    gjbonner
    Guy
    Northern Idaho
    yeah that Nightshades doesnt come out very glossy anyways. but the more clear coat the more glossy it'll be. I never wash the thing so that could be most of the problem:) it gets it about every 6 months or if i'm taking it somewhere special...:eek:Awwwwwww:eek:
    Edit: I'll have to look at my build to see how long...i cant remember. I know one day a guy followed me home to find out how i did them and i gave him the rest of my can and the instructions:)
    Edit: well hell it looks like it has been a full year this month!
  14. May 7, 2010 at 3:54 PM
    xxcjtxx
    xxcjtxx [OP] Member
    CJ
    Cali
    I dont want anyone following me home haha
