Tiny coolant leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Surfin_Taco, Apr 21, 2022.
  1. Apr 28, 2022 at 1:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pop a zip tie on it.
    That stated, when coolant expands it heads to that tank and its hot, over time it will steam out a smidge and SLOWLY decrease the amount of fluid in the res (there will also be natural evaporation out the top due to general heat under the hood).
    You are fine.
  2. Apr 28, 2022 at 1:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree.
    I had to top mine off once in 7+ years.
    If I remember correctly, it was down to maybe 1/3 way on the reservoir.
    Surfin_Taco[OP] likes this.
  3. Apr 28, 2022 at 1:45 PM
    Surfin_Taco
    Surfin_Taco [OP] Active Member
    I’m glad this is normal! I just wanted to make sure that it’s nothing serious in the long run. Haha.
    thanks!!
    TnShooter[QUOTED] likes this.
  4. Apr 28, 2022 at 1:46 PM
    Surfin_Taco
    Oh ok! Sorry, I don’t know different clamp names… haha.
  5. Apr 28, 2022 at 1:48 PM
    Surfin_Taco
    I might just replace the clamp with another oem one and call it good if it’s normal to seep coolant there.
  6. Apr 28, 2022 at 1:50 PM
    TnShooter
    Deogee
    STOCK
    I wouldn’t say it’s normal for it to seep.
    Mine evaporated out. I didn’t seep out the cap.
    I’d use a band/screw clamp and call it good.
    Williston likes this.
  7. Apr 28, 2022 at 1:59 PM
    Surfin_Taco
    Sorry, that’s what I meant. Haha. It seeps a little then dried out.
  8. Apr 28, 2022 at 2:00 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Mine has had pink crust there for years. Too lazy to fix it, coolant level never really changes or goes down
    TnShooter likes this.
  9. Apr 28, 2022 at 3:54 PM
    Cole2009Taco
    Cole2009Taco Member
    Coleman
    2009 silver Tacoma TRD
    if its fluctuating so much to where you need to put in more and more coolant then your probably loosing some somewhere, if it rises and falls a little bit thats not a bad thing, I deal a lot with dirt bikes and they do the same thing but i dont have to add coolant, my tacoma does this but again i dont have to add any, what does your oil look like? frothy browness? or normal, there are several reasons this can be happening, when you turn your truck on in the morning does blue tinted smoke leave your tail pipe? if any of this is happening you definetely are leaking inside your engine or trans somewhere if not you may be loosing some in a hose somehwere at the end of the day this is more than likely fixable and not a HUGE deal. let us know.
  10. Apr 28, 2022 at 4:48 PM
    Surfin_Taco
    I’m gonna keep my eye on it for now, I bought worm clamps if it gets worse. If not, I’ll order a new oem clamp!
    I took it to the dealer and they inspected the hoses and pressure tested the system. They said it’s most likely from the water portion of the 50/50 oem coolant evaporating. I asked about the drain plug on the reservoir that it has dried up coolant on it, but they told me that’s normal, which sat uneasy with me until some of y’all told me I’m not the only one!
  11. Apr 28, 2022 at 4:50 PM
    Cole2009Taco
    Cole2009Taco Member
    Coleman
    Thats good glad you got it figured it out you may find lots of little things that seem odd or not right and then find out it aint a big deal when i got big into dirt bikes i always got hung up on the smallest things.
  12. Apr 28, 2022 at 5:05 PM
    Surfin_Taco
    I partially blame my job bc I expect a well maintained vehicle/machine. Haha
    Cole2009Taco[QUOTED] likes this.
  13. Apr 28, 2022 at 5:05 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It will do the same thing no matter what clamp you put on it or how many times you add a dab to keep the tank at halfway point between full and low. Just moistness dribbling and drying from expansion and contracting cycles of the coolant from being heated to near boiling and then cooling to ambient temp over and over. That krusty dried stuff will be around the cap seal and the vent hole in it.
    Now if it empties the tank every week then that's when the issue is most likely the water pump growing a pink stalagmite behind the pulley and then it's time to replace the pump. discoloration of coolant and oil and it's head gasket time.
  14. Apr 28, 2022 at 5:11 PM
    Surfin_Taco
    ohhh good to know! If the crustiness is going to be there regardless, I’ll just at least use the new oem clamp so it doesn’t looks rusty. thanks!!
    edit: we are talking about the crustiness on the drain plug on the reservoir, right? Haha. Thanks!
  15. Apr 28, 2022 at 5:13 PM
    #35
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    always had a miniscule leak there since a young auto age. Like you i dont like leaks, it just seems to seep out of the hoses around the tank ever so slowly. Well, i havent done a thing, the white pinkish powdery residue slowly builds around the tank, and once a year i wipe it off and top off, maybe a half range worth.
  16. Apr 28, 2022 at 5:38 PM
    #36
    Surfin_Taco
    Oh gees… fortunately, mines only the drain plug for now… I’m really into attention to detail so I’m sure my local mechanic is going to hate me
  17. Apr 28, 2022 at 5:58 PM
    #37
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  18. Apr 29, 2022 at 5:23 AM
    #38
    Waasheem
    Waasheem
    2007 xrunner
    Fuel line hose clamps are designed better without the slots to dig in and mess up the hose so you can get them tighter.
    I’d stick with the oem rubber part, since it’s designated for coolant, vacuum caps aren’t.
    If you really want it to not leak permanently you can stick the new cap on with some gasket glue.
  19. Apr 29, 2022 at 1:31 PM
    #39
    Surfin_Taco
    Are the fuel line clamps the same as the ones that’s on there now? (For the reservoir tank drain)
  20. Apr 29, 2022 at 3:38 PM
    #40
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    My experience is the coolant level in the overflow tank varies according to conditions, so you have to learn what the average level is both fully cold and completely hot. In the winter there is a lot less in the tank when the coolant is fully heated and the same when it's cold: nearly at the "low" level when the engine is cold. In summer when the engine is hot and the conditions are the same, the level is right at the "full hot" line and about half full when the engine cools. YMMV, but I think it more accurate to check the level cold before starting off. Coolant expands quite a bit when it's hot, and contracts more in the winter than in summer. For me, the "sweet spot" this time of year is about half-full cold, 3/4 full hot. In the summer when it's had a good run and it's in the 90's the level is at the "full" line.
