Tip of the day: disconnect your battery if you're sluggish
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd09, Aug 9, 2011.
  1. Aug 9, 2011 at 8:06 AM
    trd09
    trd09 [OP] Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    On the way home from work yesterday (in a humid 90 degree day, AC blasting), I slowed down, then accelerated while turning. The truck barely wanted to downshift. It felt like I had no power whatsoever. No warning lights or anything.
    Monitored for the rest of the commute. Same deal: truck is very slow to downshift and feels like a dog.
    I disconnected the negative terminal for 30 min, reconnected it, then went for a ride around the block and made a highway run. WOW! Truck is noticeably snappier, even before the sluggish issue.
    Interested in seeing an impact on mpg. But performance is noticeably better.
  2. Aug 9, 2011 at 8:12 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    Didn't it used to be that disconnecting the battery for a long period, leaving a car totally without electricity, would clear codes and/or cause the ECU to have to "re-learn" the engine?
  3. Aug 9, 2011 at 8:15 AM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    That's what I was going for.
    My guess is my sluggishness was due to ECU / tranny logic that was thrown off by something.
  4. Aug 9, 2011 at 8:22 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    yeah that's how I got rid of my check engine light on my camry before trading it in a few weeks ago
  5. Aug 9, 2011 at 11:51 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    I do the same thing when my truck starts then stalls right away. Just disconnect negative for 5 mins and starts like a queen. Only been twice but nothing was wrong with fuel,air or spark so ecu is my thought at the moment.
  6. Aug 9, 2011 at 11:56 AM
    jcgarvey
    jcgarvey Well-Known Member
    SFV, Los Angeles, CA
    V6 PreRunner 4x2 TRD Off Road
    Could it also be a bad connection to the battery terminal? Disconnecting from the terminal and reconnecting could have given you better contact resulting in better grounding.
  7. Aug 9, 2011 at 12:50 PM
    RichardTRD
    RichardTRD Well-Known Member
    Richard
    Oregon City Oregon
    2011 Tacoma TRD OFF ROAD 4X4
    If it's a on-going issue there's something wrong I would think.
