TIP: Removing Wax from Trim
Discussion in 'Detailing' started by Snyperx, Sep 27, 2009.
  1. Sep 27, 2009 at 10:05 AM
    Snyperx
    Snyperx [OP] Seniore Marcos
    I am not sure if anyone has posted this, but I have a great way to removing wax from black trim. Try using a mars eraser. I have used this numerous times to remove wax from the black plastic trim on my truck. Works great!!!!
  2. Sep 27, 2009 at 10:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good info!! Thanks :)
  3. Sep 27, 2009 at 10:42 AM
    JKD
    JKD Well-Known Member
    I've used the peanut-butter trick in the past, and it has worked well.
  4. Sep 27, 2009 at 10:56 AM
    Snyperx
    The thing with the peanut butter trick is that you really aren't getting rid of the wax, but just covering it up with the oil in the peanut butter. The peanut oil wets the wax making it blend in with the trim. The mars eraser actually rubs the wax off of the trim.
