tip top Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaitlinTacoma84, Sep 9, 2019.
  1. Sep 9, 2019 at 5:51 PM
    KaitlinTacoma84
    KaitlinTacoma84 [OP] Well-Known Member
    north east
    2007 TRD
    I love my Tacoma... What are some ways to make sure it stays tip top? Frequent oil changes of course, but what else? :woot: Thanks in advance, I love getting help from the pros!
    llamasmurf and DavesTaco68 like this.
  2. Sep 9, 2019 at 5:56 PM
    MinookaBlues
    MinookaBlues Well-Known Member
    2022 Super White SR5 Access Cab
    Stock
    Krown or Fluid Film the frame
  3. Sep 9, 2019 at 5:57 PM
    KaitlinTacoma84
    north east
    2007 TRD
    Yes, MinookaBlues, I get it undercoated every year! thanks :)
    llamasmurf and cleats50 like this.
  4. Sep 9, 2019 at 6:04 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    1) Keep up on fluids.
    2) Don’t drive like an asshat.
  5. Sep 11, 2019 at 6:44 PM
    cleats50
    cleats50 Well-Known Member
    chris
    Tacoma 2007 TRD
    air intake push bar running boards
    Keep your engine bay clean. If you take your truck in for any work you will receive better service. It will get noticed by the technicians that you give a shit.
  6. Sep 11, 2019 at 6:47 PM
    cleats50
    chris
    Tacoma 2007 TRD
    Are you talking about a Ziebart type undercoating?
  7. Sep 12, 2019 at 5:10 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Check your fluid levels every few weeks.(Oil,trans,brake,coolant, power steering, etc..) along visually checking undercarriage for oil leaks. Also check tire pressure and tread wear.
  8. Sep 12, 2019 at 5:50 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Keep her clean. In and out. Swap out all fluids at recommended intervals. Drive like you're in a Bentley. Park farther away in parking lots. Park in a garage. Treat it how you would expect your significant other to treat you!
  9. Sep 12, 2019 at 8:14 AM
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    ^ This.
    And I’d add that it’s important to always chase down any CELs as soon as they pop up. Other than that, just keep it clean inside and out, and it’ll still look good many years from now.
  10. Sep 12, 2019 at 9:23 AM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    The folks here know way more than I do and are offering great advice. I see that you are in the North East.
    First and foremost, find a good mechanic or a local place that you trust. Being in NY, this has been a huge challenge for me. I would start there and have them give your vehicle a once over. If you plan on becoming a regular customer they will be more than happy to make suggestions, etc.
    I have posted this before so I apologize if I am annoying people. But I am not super mechanically inclined. I found this article very useful. I converted it to a check list and have nearly completed everything on it (or worked with a mechanic to do it). You may have more skill than I do so you may not need it but good to have as a reference:
    https://jalopnik.com/heres-what-it-cost-to-make-a-cheap-toyota-tacoma-as-rel-1796712352
    Finally, have your tires inspected, rotate them often and check the tire pressure. Be sure to also check the spare and use the jack so that in the event that you need it it is ready.
    Finally, look into undercoating as others have suggested. I am trying to get mine done. I have a 2005 and it had a Toyota frame replacement. Unfortunately, there are no Krown locations near me so I am trying to work that out.
    Hope that helps ... best of luck to you !
  11. Sep 12, 2019 at 9:49 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Here's what I would to if I wanted a vehicle to stay in great shape forever: Keep up with all recommended maintenance, keep it clean inside and out, don't drive on salty roads (it will get into places the undercoating can't protect), don't abuse it, and always run synthetic oils in the engine, gearboxes and differentials. For automatics, use OEM transmission fluid, not aftermarket "one fluid for five manufacturers" type of fluid. Also, don't let anyone else drive it unless you trust them completely.
    jkuniverse likes this.
  12. Sep 12, 2019 at 10:50 AM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Scheduled maintenance, no offroading, live in a warm/dry climate, don’t drive it like a maniac, and keep it in an enclosed garage.
