Tips and must haves for beach driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dmwood1984, Apr 4, 2018.
  1. Apr 4, 2018 at 4:54 PM
    Dmwood1984
    Dmwood1984 [OP] Well-Known Member
    New Jersey
    2018 Cement TRD Off-Road Double Cab Long Bed Premium Package with Options
    Never did 4 wheeling on the beach before... Gonna be doing a lot of beach driving this summer for fishing, swimming, taking the dogs out, surfing, etc.. wondering if there are any must have mods, tools or products for it, and also just general tips.. thanks !
  2. Apr 4, 2018 at 5:01 PM
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    Gotta Bury the axles and show off to all the beach go’ers how damn awesome crawl is
    Burns, LivinLoud, Key-Rei and 4 others like this.
  3. Apr 4, 2018 at 5:01 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    http://www.islandbeachnj.org/Recreation/beachdriving.html
    Every state has there own set of rules and regs so you’ll have to check by state, and beach. Since you’re in Jersey i figured that’s where you’d start.
    Basically...
    Air your tires way down (you need a way to do this and a gauge)
    A high lift jack
    Platform to place your jack on
    Straps and or chains
    Spare tire and shovel
    Obviously there’s more in some places. Trash bags, water, fishing gear (some places ONLY allow driving for the purpose of fishing).
    This should get you started.
  4. Apr 4, 2018 at 5:14 PM
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    Find a nice quiet spot without people around and come to a complete stop. Hold the traction control button for ~8 seconds until the TRAC OFF light comes on in the dash. Turn the wheel all the way in either direction. Floor it! Wait for the view to repeat itself at least 4 full times before letting off the gas.
  5. Apr 4, 2018 at 5:23 PM
    YOTA 4X4
    Please don’t do that... things might be a little different in Texas, but on the east coast we’re lucky to have anywhere to drive off pavement. Don’t give the tree huggers any more excuses to restrict access. I realize it’s just sand but trust me any reason they can use to take away access they will.
    Obey speed limits and drive where you are supposed to responsibly and safely, be courteous and help other. Don’t be a jackass off road. On the beach or anywhere it hurts us all.
    Oh and stay off he dunes! And away from nesting birds or turtles, jeez just what we need a national story about some guy in a Tacoma mowing down Plovers that were nesting. Hahahaha
  6. Apr 4, 2018 at 5:30 PM
    eon_blue
    Azusa, CA
    Have good tires and air down...how far you can air down depends on your tire and wheel setup but I'd go to at least 15 psi or lower if you can. I had to go down to 8 psi once to get unstuck but aired back up a bit when I was in a better area. So make sure you have an air compressor too, and a good one (not one of those $20 Wal Mart ones that plug into your cigarette lighter, one that hooks up directly to your truck's battery or better yet...an on-board air compressor.) I have a Viar 88p that I picked up for $60 or so and it works great, albeit not super fast like on-board compressors do.
    Have a recovery strap in case you need to get pulled out of a difficult spot, or find someone that does. NOT a tow strap...a recovery strap. Tow straps usually have those metal hooks on the end which can easily become lethal projectiles, and they don't have any elasticity like recovery straps do.
    4lo or 4hi depends on the situation but usually you want momentum in sand. Keep in mind that it's not easy to steer in sand though the faster you go...especially if there are ruts or tire tracks from other vehicles. Sand wants to pull you in every direction.
    Also, if you're stuck in 2wd make sure your tires are not slipping when you engage 4wd...engaging 4x4 with slipping tires is a great way to break something.
    Biscuits likes this.
  7. Apr 4, 2018 at 5:30 PM
    SouthtownTaco
    San Antonio, TX
    2016 TRD Offroad
    I agree! Never put down tracks where there aren't any already. Be cool and be safe. And have fun when possible.
    xxTacocaTxx likes this.
  8. Apr 4, 2018 at 5:32 PM
    eon_blue
    Azusa, CA
    I agree, however we have OHV areas here in CA that are basically sand dune parks without any specifically marked "trails", just border lines indicating how far you can go. But if you're on a designated trail, always stay on the designated trail.
  9. Apr 4, 2018 at 5:36 PM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    What beach in jersey are you going to? i frequent Brigantine Beach all the time. I always air down to about 18psi, that way if i ever get stuck i can still air down a little more. Always carry a shovel, traction boards at minimum. Brigantine Beach wants you to have a fire exstinguisher, tow strap, jumper cables, 12x12 minimum 1 inch thick board if you need a jack, and some other stuff, i forget everything. Always bring a air compressor to air back up, sometimes the ones provided dont work or are not turned on.
  10. Apr 4, 2018 at 6:01 PM
    Dmwood1984
    New Jersey
    Island beach
    5Saints likes this.
  11. Apr 4, 2018 at 6:02 PM
    5Saints
    5Saints Active Member
    Sussex County, Delaware
    2019 Super White TRD Pro
    I air down tires to 20-15 lbs. depending on how soft the sand is in the area. In the winter when the beach is not rutted up I have driven on without airing down and in 2 wd. In Delaware there are some items you are required to have like a shovel, Jack with a board, recovery strap and must be driving on to be actively fishing. They actually offer a class about beach driving, Delawareonline.com, but I would guess most of the posts here would cover what you need to know. Also make sure to get a map of where you can and can't go for that time of year. I think 4 hi works better than 4 lo. Don't jam up the beach entrance while airing down. You can use tire deflators to speed up the airing down process. Don't get too close to the water.
  12. Apr 4, 2018 at 6:10 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Good advice so far but I would say a set of MaxTrax would be a solid investment as well. For the money, they're hard to beat and can really save your rear if you get stuck and there is nobody around to pull you out.
    cesar_taco and Running Board Man like this.
  13. Apr 4, 2018 at 6:24 PM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    In Hawaii, trucks don't like sand and saltwater....with all the electronics wired under truck it will be a bitch to clean out! It's fun as hell but you gotta flush bearing boots to frame or rust will haunt you....
    In the 70's we used to have races at the beach, and everybody was responsible of taking care of the beach, but now that a Billion people moved to Hawaii I don't know of a beach you can even drive on without getting cited or running over somebody, somebody would call the cops anyway......so it's mountains and mud....even there the greenies complain.
    But if you can where you are, have fun, it's a blast and just feels good to drive up to the waters edge and sit on tailgate while fishing!
    Oldman808 and Running Board Man like this.
  14. Apr 4, 2018 at 6:47 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Air down, and have a way to air up, that’s really it.
    If you want recovery gear, then straps (snatch if you know how to use them) or recovery tracks would be next.
    Hi lift is worthless on a stock Tacoma, and will not get you out of sand on it’s own anyway, you will need way more ie something to pack under the wheel.
  15. Apr 4, 2018 at 6:49 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Stay out of the salt water.
  16. Apr 4, 2018 at 7:20 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Last two trips to Padre Island National Seashore I didn’t even bother to air down. I went out to the 25 mile mark in 4hi with no problems. Airing down will help a lot if you’re traveling in fresh untraveled sand but as long as there are previous tracks and you stay on them, you’ll probably be fine without.
    But yeah, a compressor, a shovel, tow strap, a full tank of gas, and water will serve you well. Wouldn’t be a bad idea to have a sturdy piece of 2x2’ wood in case you need to jack it up and change a tire
    Biscuits and Running Board Man like this.
  17. Apr 4, 2018 at 9:57 PM
    District Dog
    District Dog DOGS LOVE TRUCKS
    Washington, D.C.
    2017 Quicksand Tacoma TRD Off Road
    Never use the brake. Let the truck “drift” to a stop (obviously, driving slowly is part of this). Getting sand in drum brakes and using them will quickly tear them up. Know EXACTLY where the “high water” line is on the beach. Best advice: go with someone who knows how to operate on the beach and learn from them first, don’t just “do it,” especially with a new truck.
  18. Apr 4, 2018 at 11:00 PM
    ls7alex
    ls7alex Well-Known Member
    Newark
    Taco gang
    Don’t drive into the water. Do what they said ^^. You’re good to go, have fun
    loveinyourmouth likes this.
  19. Apr 4, 2018 at 11:07 PM
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Wow. I don’t even know how to respond to that. I do donuts at least once a week in Arizona. Rip to your freedoms fellow east coast TWMember
  20. Apr 4, 2018 at 11:17 PM
    cesar_taco
    cesar_taco Well-Known Member
    Cesar
    2017 DCSB Off-Road Taco
    I enjoy beach driving in Carova / Corolla (NC). Besides what folks have said already, just be aware that if there are people around, don't assume they can hear you approaching. The ocean waves drown a lot of sound, so folks tend to wander through the line you are driving (especially little kids and parent's watching their kids).
    Also be aware of folks who prey on beach drivers by placing traps (they then offer to tow you out for a fee). I've had no problem in 4 high so far (although I have crawl control if needed). Bring traction boards just in case (can be used as a shovel too).
    Enjoy!
    Trips222 likes this.
