Tips and tricks for prepairing trail armor for powder coat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by btu44, Jan 12, 2018.
  1. Jan 12, 2018 at 4:01 PM
    btu44
    btu44 [OP] Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    I have full trail armor and winch bumper arriving soon. The place I work will powder coat as long as I do all the prep.
    I have a angle die grinder with sanding disks. I figure I would round off all sharp edges and grind smooth visible welds. I also plan on sandpaper roughing all the surfaces for the powder coat to adhere well.
    Any ideas you guys have to save time and elbow grease?
  2. Jan 12, 2018 at 10:46 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    Save time and money by rattle canning it, easy touch ups.
  3. Jan 12, 2018 at 11:03 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    To maximize the durability and longevity of the powder coat, you want to sand blast the steel to "near-white metal clean" (SSPC SP-10), which basically takes all mill scale, dust, grease, etc. off of it and creates an angular profile in the metal surface for the powder to bond to. The next step down from that would be power cleaning (SSPC SP-3) with hand tools, but it will be difficult to get a uniform surface profile in interior corners, etc. on a bumper.
    If your work does powder coating, do they also do sand blasting? Usually they go together - see if they will show you how to operate the equipment yourself and do it after work some day. It's weirdly fun, like pressure washing dirty concrete.
    pepto90 likes this.
  4. Jan 12, 2018 at 11:26 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Sand blast or just spray can it. You won’t be able to eat in the right spots with a sanding disc.
  5. Jan 13, 2018 at 2:30 PM
    btu44
    Long Beach area, Ca
    Unfortunately our sandblaster at work is much too small to fit a bumper or sliders. But I could get a cheap HF sandblaster and blast the parts in the back field which I think is in air line range.
    Thanks, great idea. Way less work with better results.
    By the way...just finished fitting the All Pro tube rear bumper. I am amazed, fits perfect, the bumper is aligned with the tail gate and all the bolt holes line up. cheers All Pro :cheers:
  6. Jan 13, 2018 at 3:15 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Wow, you had better luck than I did lol. I had to re-drill 5 out of 9 mounting holes for my AP front plate bumper.
  7. Jan 13, 2018 at 3:33 PM
    Revco
    Revco Got that PMA
    Austin, TX
    '01 Reg Cab 4x4
    stock-ish
    I agree. Powdercoating is a waste of time and money. Its going to get scraped off anyway.
  8. Jan 13, 2018 at 6:04 PM
    btu44
    Long Beach area, Ca
    Ouch, that's my experience with most aftermarket parts. I even had my die grinder and BFH out for this fitting.
  9. Jan 13, 2018 at 6:06 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Youre gonna want to saw your hand off after grinding welds with a die grinder. Go to tractor supply or another hardware store, spend 30 bucks on a proper 4.5" angle grinder and about 5 flap disks. Trust me, I know from experience.
    jsi likes this.
  10. Jan 13, 2018 at 6:17 PM
    btu44
    Long Beach area, Ca
    I appreciate your opinions but I find rattle can to chip very easily and loose it's gloss quickly. Now this maybe because Cali has regulated paint into s**t.
    I figure prep is the same for powder coat and rattle can so I don't see a time savings.
    Were I work I we do parts for the Navy so I'll get a mil spec primer and powder coat for free. I my case powder coat is the way to go.
  11. Jan 13, 2018 at 6:20 PM
    btu44
    Long Beach area, Ca
    I have a nice Dewalt 5" with a course flap disk but I thought it would be to aggressive. I'll give it a try.
  12. Jan 13, 2018 at 6:28 PM
    jsi
    jsi Well-Known Member
    native earthling
    I've built 2 bumpers from scratch. The first I rattle canned, the second I had powder coated. Without a doubt the powder coated bumper held up and looked better. Even after being bashed on the rocks the powder coat was better. For those scratches that went clear through to the metal, I touched them up with paint. Because the rock rash was only on the bottom the paint touch ups were hard visible. The powder coat held up better to the trail pinstriping than the rattle can did. I'd never go with a rattle can for anything that I cared how it looked, and in your case of getting powder coat for free, well that's a no brainer.
    btu44[QUOTED][OP] and drr like this.
  13. Jan 14, 2018 at 3:32 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Thats perfect. Start with a 40 grit disc to get the bulk of the material, then go to an 80 grit to finish sand.
  14. Jan 15, 2018 at 8:46 PM
    btu44
    Long Beach area, Ca
    Damn, that was a lot of work yesterday and I still have a little more to go on just the rear bumper. I can now see why quotes for sand basting are so high.
    The HF spot sandblaster was not so good. It consumes grit fast and seems like half of it bounced right back into my face. Ended up using the blaster only for the welds and any place I could not reach with the angle die grinders. Mostly used flap sanding wheels and scotch bright disks. Used a deburring knife for the inside holes.
    Definitely not looking forward to the front bumper and sliders.
    I do have a question. Will powder coat stick to surface rust stains or does the metal surface need to be shiny clean?
  15. Jan 15, 2018 at 10:44 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Rust "shadows" are ok, as long as it isn't actually remaining corrosion. Try not to take off any more material than you have to with the power tools to get to a clean surface.
    btu44[QUOTED][OP] likes this.
  16. Jan 15, 2018 at 11:31 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I have found that the ACE Hardware brand "Rust Stop" paint to be my favorite rattle can to date.
    It's cheap like $5-$6 a can.
    It doesn't have that fast drying feature that all other name brand paints like to tout.
    It stays tacky much much longer allowing excellent bonding of each layer you apply.
    Then once it's fully dried and cured, it resist chipping way way better than the name brand paints.
    callmeammo likes this.
  17. Jan 16, 2018 at 5:46 PM
    btu44
    Long Beach area, Ca
    When spay canning I generally use Rust-Oleum Professional primer and paint. If you have tried this paint, does the ACE paint compare better in your opinion?
  18. Jan 16, 2018 at 5:56 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    My experience with Rust-Oleum rattle cans as well as PlastiCote, Hammerrite, and several other name brands is that they all are the fast drying paints. And this is fine for items that are porous/textured, don't move or won't have a likely chance of being scratched.
    The slower drying/curing time that the cheap ACE Rust Stop offers seems to hold up a lot better to abrasion without chipping.
  19. Jan 16, 2018 at 6:29 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I was taught in my high school collision class to buff the bare metal with a scotch brite pad. Sanding so that it is shiny is unnecessary. The primer just needs something to grip to, so the tiny scratches left by a scotch brite pad provide that.
  20. Jan 16, 2018 at 9:18 PM
    btu44
    Long Beach area, Ca
    Sounds good, I think I 'll give the ACE paint a try. Epoxies seem to act the same. The 5 minute set is much more brittle that 45 minute epoxy.
