Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Feb 6, 2017 at 1:08 PM
    #2001
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    If you're not moving, they will. If you're moving, it will read them to you, but not display them. At least that's what mine does.
    JTennessee[QUOTED] likes this.
  2. Feb 6, 2017 at 4:10 PM
    #2002
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    That is the correct operation of the truck with an iPhone. I can't speak for other operating systems.
  3. Feb 6, 2017 at 4:34 PM
    #2003
    atdes_taco1
    atdes_taco1 Member
    Francis
    2016 Barcelona Red TRD Off Road
    N-Fab Adjustable steps, M-series ARC shell
    have you tried logging out of Entune on your phone, then log back in? I had issues of this sort came up. called Toyota, and adviced to log out and log in. solved the issue, but still happens every now and then. May have something to do with the phone being busy receiving emails and other stuff on the net while running Entune at the same time.
  4. Feb 6, 2017 at 6:48 PM
    #2004
    steelisreal
    steelisreal SteelisReal
    Dan
    Inferno TRD Sport AC M/T
    I have noticed my music will pause on its own when driving in and out of cell reception. There are a few dead zones on my drive to the mountains where this happens fairly predictably. I have an iPhone with Apple music via bluetooth. Strange thing is it still happens if I'm listening to a playlist that I have downloaded to the phone. It is a bit annoying but I'm used to just hitting play again. Hope an Entune update fixes this eventually...
  5. Feb 6, 2017 at 8:30 PM
    #2005
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Just tested my unit and I don't think it has anything to do with cell coverage. I turned off cellular data for both Spotify and Tidal and my offline library played fine. I never experienced music pause with Spotify Premium but did encounter a lot of times for it to not want to connect. I use Tidal now and it connects every time, not to mention is superior to Spotify in quality. Do you have background app refresh on? Hope you find the problem. Cheers
    SouthtownTaco likes this.
  6. Feb 7, 2017 at 3:41 AM
    #2006
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    Where do you have your phone sitting for Bluetooth playback?
  7. Feb 7, 2017 at 6:10 AM
    #2007
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    I too have experienced this problem and have found playing music from the Lightning cable (instead of Bluetooth) fixes this issue. Plug in your phone via the dash USB port and select "iPhone" from the audio menu instead of "Bluetooth".
  8. Feb 7, 2017 at 6:44 AM
    #2008
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    When I remote start my truck that's sitting in the driveway it'll grab my phone's bluetooth while I'm still in the kitchen getting my stuff together.
    Unless there's a hardware issue, bluetooth range is NOT going to be an issue.
    EB Group and sadmrhappy like this.
  9. Feb 7, 2017 at 6:47 AM
    #2009
    bcbrack
    bcbrack Well-Known Member
    what's the actual purpose of entune? Had the truck about 3 weeks now, can't figure out what its for. Bluetooth for music / podcasts all the time, that's pretty much all i need.
  10. Feb 7, 2017 at 6:52 AM
    #2010
    gpb
    Atlanta
    @bcbrack Are you talking about the Entune app on your phone? The phone app serves as the data conduit for the different apps on the Entune head unit in the truck. Fuel guide, Sports, Stocks, etc. as well as the Pandora, iHeartRadio, and Slacker Radio apps in the head unit. It can also serve as the data conduit for weather and traffic data if you don't have HD radio.
  11. Feb 7, 2017 at 6:54 AM
    #2011
    bcbrack
    Gotcha. I don't use any of that haha so i guess i'm good.
    I am curious as to how i get the 'dings' to stop when I open my door, as well as i wish when i turned the truck off the radio would stay on until I open the door.
  12. Feb 7, 2017 at 7:14 AM
    #2012
    gpb
    Atlanta
    @bcbrack As for the door, that should be configurable via TechStream -- meaning either get the dealer to do it or obtain the TechStream software plus a MiniVCI cable plus a laptop. I'll likely be playing with that later this week as it's kind of annoying to me as well. (pro tip: install a windows 7 virtual machine in VirtualBox and keep TS there so as to avoid any potential messing with your stuff)
    Radio I've never paid much attention to; I pull in and turn off and am ready to get out. I think it'll stay on if you shut off before shifting to Park, but you may have to press the button again to go from ACC to Off.
  13. Feb 7, 2017 at 7:15 AM
    #2013
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
    Turn the truck off before opening the door, the dinging won't happen.
    Keep the truck in gear, turn the truck off, then put in park - Radio will stray on
    melikeymy beer likes this.
  14. Feb 7, 2017 at 4:49 PM
    #2014
    drwx
    M'boro, TN
    Bluetooth range is about 300ft max. It will not penetrate liquid. What this means is that Bluetooth signal might suck if you have your phone in your back pocket while you drive. It does bounce off of hard surfaces, which is why Bluetooth headsets work better indoors than out. For example, my Bluetooth ear buds cut out if I have my phone in my left pocket since the BT antenna is in the right ear bud.
    My question about phone placement is about if the signal can get to the truck due to being unable to penetrate something... Not about range.
  15. Feb 7, 2017 at 5:23 PM
    #2015
    gpb
    Atlanta
    Range/sensitivity relates to bounce. Inside a vehicle, with tons of RF reflective surfaces, it is highly improbable that you'll have any bluetooth issues with your phone in your back pocket.
    What was your result when you tried it?
    Personally, I don't sit on a thin expensive electronics, so I never leave my phone in my back pocket when sitting down, so I've not personally tried that. Never had an issue with it in my left jacket pocket though, with my torso between the phone and the head unit.
  16. Feb 7, 2017 at 5:28 PM
    #2016
    drwx
    M'boro, TN
    It was a legit question and is certainly plausible. No need to be an ass about it, bro.
    Summary... Without asking, you never know exactly what anyone else is doing. This is a troubleshooting step. Hell, the dude may be dropping it inside a yeti cup.. You don't know unless you ask.
    A Salt Weapon likes this.
  17. Feb 7, 2017 at 5:36 PM
    #2017
    gpb
    Atlanta
    I added my thoughts to the discussion. I don't believe that to be a likely culprit given the closed, RF-reflective environment that is the inside of a truck cab.
    You're certainly welcome to your own opinion. There was nothing in what I wrote that was intended to cause offense.
    Cuffs likes this.
  18. Feb 7, 2017 at 5:40 PM
    #2018
    drwx
    M'boro, TN
    I have been in IT for 15 years and dealt with a lot of users and done a ton of troubleshooting. Never assume anything. Until you have a 100% clear picture of what a user is doing, how are you going to know all of the factors involved in troubleshooting?
  19. Feb 7, 2017 at 5:43 PM
    #2019
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Well then you should have been able to figure your shit out then, eh?
    Tcoma16 and Adamtaco like this.
  20. Feb 7, 2017 at 5:48 PM
    #2020
    drwx
    M'boro, TN
    Was trying to help the guy having Bluetooth issues. Refer them to GBP.... The great Bluetooth prophet. He knows all, apparently.
