Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Feb 9, 2017 at 4:39 AM
    #2041
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Right. See my follow up post. The unconventional terminology threw me off:
    No worries. :thumbsup:
    Herniator likes this.
  2. Feb 9, 2017 at 7:49 AM
    #2042
    delgross
    delgross Member
    Edward
    2017 TRD Off Road
    Don't know if this qualifies as a tip. I use mostly use Alexa to listen to audio in my truck. When the source is not bluetooth I have been reaching over and pressing source and then picking my source. Pressing audio twice in a row brings you to the sources menu.
    JBL with Entune
    dilbert likes this.
  3. Feb 10, 2017 at 6:41 PM
    #2043
    Hotrod51
    Hotrod51 New Member
    Great info here. I am a first time owner of a 2016 Tacoma Offroad. I have approximately 6k miles on it now. May sound petty but every now and then when I start the truck the heater and heated seats are off instead of where they were when the truck was shut off. Dealer says is not happening often enough for them to trouble shoot. (only happens willy nilly no real pattern). Even though they witnessed it first hand twice. Has anyone else had this happen. Would like to get remotest art installed but if heater won't be on when starting truck kind of pointless.
  4. Feb 10, 2017 at 6:45 PM
    #2044
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Is the heater off or is it waiting for the truck to warm up before turning the fan on? It will warm up quicker that way.
    My heated seats stay on if I leave them on.
  5. Feb 10, 2017 at 6:52 PM
    #2045
    Hotrod51
    Hotrod51 New Member
    When I shut the truck off the heated seat is on and the fan is running. I always run it in the auto configuration. When I read start the truck the seats are off and the heater is off. You can turn it back on but it should return to the last setting when the truck was shut off.
  6. Feb 10, 2017 at 7:05 PM
    #2046
    Herniator
    Edmonton
    Is the auto light still on?
  7. Feb 10, 2017 at 7:42 PM
    #2047
    Hotrod51
    Hotrod51 New Member
    No it is not
  8. Feb 10, 2017 at 7:46 PM
    #2048
    Hotrod51
    Hotrod51 New Member
    No it is not
  9. Feb 10, 2017 at 8:07 PM
    #2049
    Herniator
    Edmonton
    Maybe you can get the dealer to check it by plugging in your truck to tech stream.
  10. Feb 10, 2017 at 8:28 PM
    #2050
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    The dealer is pushing you around and will do so until you instruct them what to do. It's your choice, not theirs. Call Toyota Corporate. This feature is not working the way Toyota intends it to, therefore it is malfunctioning. Call Toyota Corporate if needed to get dealer's attention.
    F#@&ing dealers.
    boynoyce likes this.
  11. Feb 10, 2017 at 8:57 PM
    #2051
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Damn gpb, you old.:rofl:
    As far as the blue tooth problem, I listen to audio books over blue tooth just fine. It may be a cell signal problem or an app problem. Try playing some audio that doesn't stream and see if it stops/interrupts.
    I thought rider was a typo for driver too.
    gpb[QUOTED] likes this.
  12. Feb 11, 2017 at 5:02 AM
    #2052
    bls82261
    bls82261 Well-Known Member
    Brian
    VA
    2017 TRD Sport AC Manual 4X4
    I know this is an old post but I had the same issue. My problem was the file name. Can only be 32 characters long
  13. Feb 16, 2017 at 6:39 AM
    #2053
    Lawn_mower
    Lawn_mower Well-Known Member
    Max
    17 TRD Off Road
    Wondering if anyone has had the same problem, pretty often when I start the truck it will connect to bluetooth right away and start streaming, but the audio is sped up, and cuts out every few seconds. If you turn off bluetooth on the phone and then turn it back on and allow it to reconnect it works fine.
  14. Feb 19, 2017 at 2:21 PM
    #2054
    dsnow
    dsnow New Member
    Black Tacoma TRD Sport 2016
    Yes i have had that multiple times - same steps to resolve - still annoyed by the autoplay when connecting via bluetooth
  15. Feb 19, 2017 at 8:50 PM
    #2055
    ToyLett
    ToyLett Well-Known Member
    Kitsap County, WA
    2017 Double Cab TRD Off-road
    So helpful!
  16. Feb 20, 2017 at 8:33 PM
    #2056
    BLK_TTAC
    BLK_TTAC New Member
    Bobby
    Pacific Wonderland Oregon
    2016 DCSB Ltd 4X4
    TRD factory exhaust, K&N intake
    Yes I am having the same issue, dealership tells me no problem found after updating the software. On the way home it cut out again after switching sources and then back to BT. Very annoying.
  17. Feb 20, 2017 at 9:27 PM
    #2057
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    This could be phone operating system and version dependent as I haven't experienced this issue myself. It could also be based on the version of entune you have currently installed on your head unit.
  18. Feb 20, 2017 at 9:31 PM
    #2058
    BLK_TTAC
    BLK_TTAC New Member
    Bobby
    2016 DCSB Ltd 4X4
    Possibly, more than likely the phone since the dealer updated the Entune system. There are 2 players on my phone and I thought it could be fighting for control. For now I am going to deal with it until I get a new Samsung phone soon so I have Qi charging, hopefully the problem will go away. Good to know it is not a common known issue.
  19. Feb 21, 2017 at 8:26 AM
    #2059
    gpb
    Atlanta
    TacoChief, EB Group and GPsevinSixx like this.
  20. Feb 21, 2017 at 4:22 PM
    #2060
    Istan
    Stan
    Vegas and Yuma
    I personally stopped using the QI charging since USB was much faster.
    iltdi likes this.
