Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Apr 18, 2017 at 7:12 AM
    #2161
    Texasbrons
    Texasbrons Well-Known Member
    Pleasant Hill, MO
    2016 Tacoma Off Road TRD Quicksand
    Changed my DisplayOff image ---Twice!!
    I went out and just tested mine. Made sure the doors were unlocked. Opened the back door. Pressed the lock button on the fob. The tone went off for 5 seconds, then stopped. I closed the door. Nothing locked. Okay, try it one more time. Same result. Tried closing the door while the beeper was still making the sound (within 5 seconds). It still didn't lock. I'm at work so I don't have time to go into the menu to see if there's something that I need to change, but it looks like on mine it won't lock if you push the lock button and a door is open. I'd be willing to bet there's an option I have to activate or deactivate though. My truck is the 2016 OR.
    Edit: I had a victim, er I mean vendor, that wanted to meet with me for lunch so I took the opportunity to play with this some more. I had it set to only unlock the driver side door. I switched it to unlock all four doors. No change. Apparently if you open the back door, the only way to lock the door is to push the lock button in the front door or push the button on the fob once all of the doors are closed. It still did the 5 second beep, went away, but it never locked the door when I close it. Sorry dude, you're either going to have to keep a finger available to push the fob or you're going to have to push the button in the front door to lock your doors (Or use the lock feature built into the driver's handle).
  2. Apr 18, 2017 at 1:24 PM
    #2162
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    Nice. I'm just happy that my sr5 has a feature that the TRD models don't. =D
    Texasbrons[QUOTED] likes this.
  3. Apr 18, 2017 at 1:25 PM
    #2163
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Wait till you get in the house and put your groceries down and...then hit the lock button on the FOB..!!
  4. Apr 18, 2017 at 1:33 PM
    #2164
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I can hit the lock button on my fob and then close the doors. Then the doors will lock and the beeper will sounds. TRD OR with prem&tech, but it's a manual transmission, so no proximity key.
  5. Apr 18, 2017 at 3:12 PM
    #2165
    drwx
    M'boro, TN
    Could be an h key thing.
  6. Apr 19, 2017 at 6:49 AM
    #2166
    Texasbrons
    Pleasant Hill, MO
    I think you're right. I tried doing it and walking way and the door still didn't lock. It didn't matter if the beep was active when I closed the door and walked away or if I waited until the beep stopped after 5 seconds, then closed the door and walked away. With the auto and remote sensing key fob, there is no apparent way to lock the door short of pushing the lock on the front door or pushing the lock on the key fob AFTER all of the vehicle doors are closed.
    Edit. I did one more check. You're going to have to open your driver door. Open the back door. Push the lock on the door panel, close the driver door. Then go around and pick up your arm load of goodies, then do your hip check, then when you close the door everything will lock up. No big deal, you've just got to push the lock button on your way out the door and remember to open back door before you close the driver door. Now if you have to open the passenger side of the vehicle, that'll suck a little more, but that's what you've got.
  7. Apr 19, 2017 at 12:58 PM
    #2167
    drwx
    M'boro, TN
    seems legit... but hey, at least you don't have to stick a key in to start the truck...amiright?
  8. Apr 19, 2017 at 7:18 PM
    #2168
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    My pro does the same as yours, can't lock it with door open, my tundra is the same. I always thought it was a Toyota thing, as all our others vehicles work the opposite way. Can lock with door open, and set re-arm when you shut the door.
  9. Apr 20, 2017 at 7:50 AM
    #2169
    Rock_Diamond
    Rock_Diamond Well-Known Member
    I'm trying to figure out how to lock the doors with my mind.
    Bama_fan01 and Blazingbluesport like this.
  10. Apr 21, 2017 at 1:20 PM
    #2170
    ctagz
    ctagz Well-Known Member
    Fountain Valley, CA
    2017 TRD Sport dcsb - Inferno
    Try waving your hand near driver side door handle while thinking about it locking... clicking your heels 3 times couldn't hurt either!
  11. Apr 21, 2017 at 3:28 PM
    #2171
    Rock_Diamond
    I tried praising the dark one in the deep forest but it only unlocked the driver side. I will give 3 clicks a try.
  12. Apr 21, 2017 at 9:45 PM
    #2172
    ctagz
    Fountain Valley, CA
    You can change the settings so all 4 open.
  13. Apr 22, 2017 at 6:24 AM
    #2173
    ICU1
    ICU1 Well-Known Member
    Don't do it! I tried it, iphone 5 got so hot the glass face popped out of the fram
  14. Apr 22, 2017 at 7:40 AM
    #2174
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    what did you use?
  15. Apr 22, 2017 at 11:18 AM
    #2175
    DodgeORama
    DodgeORama Well-Known Member
    Dodge
    Squamish, BC
    2017 MGM TRD Off Road DCSB
    Anyone have an idea if there's ffwd/rewind controls available when listening to podcasts? Using an iPhone over Bluetooth...?
    No entune app available, I'm in Canada
    TeecoTaco likes this.
  16. Apr 23, 2017 at 5:38 AM
    #2176
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    I didn't see this anywhere, but if I jump in, start up and then hit the defrost button, the cooling/heating panel comes on, and the fan comes on at 1 dash and increases to full speed by its self. If the system is already on when I hit the defrost button... the fan stays where it was already set.
    Normal?
  17. Apr 24, 2017 at 6:34 PM
    #2177
    knowonecares
    knowonecares Active Member
    Long Beach, CA
    98 PreRunner TRD
    No driving in the rain at night?
  18. Apr 25, 2017 at 5:02 AM
    #2178
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    This is referring to the feature in which the headlights will activate upon the wipers being on. Nothing is stopping you from turning them on yourself. Toyota simply skimped on features while adding others like auto headlights based on the amount of light outside.
    knowonecares likes this.
  19. Apr 25, 2017 at 5:09 AM
    #2179
    Rock_Diamond
    It's normal if Your using the Auto function. If you don't want that depress the auto button. What auto will do is bring up the temp to what you have it set at before the fan turns down. I don't like that mode.
    https://youtu.be/5D6t2Ldi8_4
  20. Apr 25, 2017 at 5:45 PM
    #2180
    Harvo
    That's not the case here. Auto is not on (not lit) and the entire cooling/heating system is off. The only button I touch is the defrost button (push button above the off button)
