Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. May 23, 2018 at 12:03 PM
    #2481
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Nope... the 16's have a separate key for TG..... Get one cut..
  2. May 23, 2018 at 12:09 PM
    #2482
    Snowtrooper17
    Snowtrooper17 Well-Known Member
    Colorado
    '17 White TRD OFFRD V6 4x4 ACLB
    That's strange because the physical key inside my FOB works for the tailgate on my '17. Toyota must have caught enough hell from the first owners of the 3rd gen to fix that the next model year.
    sierra141 and over60[QUOTED] like this.
  3. May 23, 2018 at 12:18 PM
    #2483
    jdr43
    jdr43 Well-Known Member
    Jim
    Hamelton Montana
    2016 Tacoma SR5
    I have a 2016 and my fob key works on everything including the tail gate
  4. May 23, 2018 at 12:20 PM
    #2484
    Eetee
    Eetee Member
    I called the dealership. The bottom line is (from what they told me): if you lose your key you will have to replace the barrel (~$250.00 cdn dollars (parts no labour) was the informal quote). When this is done, you will be able to not only have one key but a second one if you order it and obviously pay for it.
    So I said "to confirm what you are saying", if I want a second key I need to change the barrel. Answer: "yes".
    I now have my key on a high-viz paracord with a small carabiner and it will remain in the cab as an SOP. How long before one of my daughters or my wife lose the thing? I hope that one day, the fob gets to unlock the tailgate.
    Again, let me know if I am missing something here... This does not look to me as a "soldier proof" solution.
  5. May 23, 2018 at 12:20 PM
    #2485
    Snowtrooper17
    Colorado
    @over60 Maybe its a Canadian thing? :notsure:
  6. May 23, 2018 at 12:26 PM
    #2486
    over60
    Muskoka, Ontario
    Damed if I know.... all I know was I got a TG key separate from the others and had one cut for $2.50 at CTC.....I'm Ok now.
    Eetee.... Go get a 2nd ket cut like I did..
    shakerhood likes this.
  7. May 23, 2018 at 12:28 PM
    #2487
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My Ignition Key unlocks my Tailgate.
  8. May 23, 2018 at 12:29 PM
    #2488
    over60
    Muskoka, Ontario
    You have a "key Start" don't ya..?? ie: no push button start.
    tcjacado and shakerhood[QUOTED] like this.
  9. May 23, 2018 at 12:32 PM
    #2489
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Just pull the lock cylinder out of the tailgate and bring it to a locksmith to be rekeyed to work with your ignition key.
    Boghog1 likes this.
  10. May 23, 2018 at 4:14 PM
    #2490
    smdcbr
    smdcbr Well-Known Member
    Passaic county, NJ
    2016 Blue TRD Sport AC M/T
    Or Pop-n-Lock or diy electric actuator automatic unlock system
    BlasterJoe likes this.
  11. May 23, 2018 at 5:20 PM
    #2491
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    You have an sr5 that doesn't have push to start .You don't have the same fob. On 16s the tailgate has a different key than the one hidden inside the pts fob. Toyota fixed this for the 17s
  12. May 23, 2018 at 5:21 PM
    #2492
    drwx
    M'boro, TN
    It's not
  13. May 24, 2018 at 4:45 AM
    #2493
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I'm having an auto electric shop install an a power lock on my tailgate. They have done a few, only $80 installed with a year warranty.
    20tacoma17 likes this.
  14. May 24, 2018 at 6:31 AM
    #2494
    Eetee
    Eetee Member
    Not that easy it seems...
    Just stopped by Canadian Tire. As soon as I took out my key the guy said "Can't reproduce those. We can do smart keys but not those ones. You're not the first one to ask... Toyota right?".
    So, just to be clear. I have an '18 (Off Road) with push button start. It comes with two FOB (electronic access) and one single separate physical key for the bed. That second key is also somewhat "special" as it cannot be reproduced locally. Looks like it will remain inside the cab on that high viz paracord and carabiner for a while...
  15. May 24, 2018 at 6:47 AM
    #2495
    pinochle
    NNJ
    They're laser cut keys. Go to a locksmith.
  16. May 24, 2018 at 7:00 AM
    #2496
    Eetee
    Eetee Member
    Thanks for this. Just called two different locksmith. Answer(s): "Don't have anything for 2018 Toyota".
    The search continues...
  17. May 24, 2018 at 8:47 AM
    #2497
    jimmydinbc
    jimmydinbc New Member
    Interested in the type of keys your '18 has.. fob key and tailgate key. (I am a locksmith) there are a few variations depending on the trim level. If you could post an image of a similar key from google, or message me with a pic of your actual tailgate key, hopefully I can help you with it.
    xxTacocaTxx likes this.
  18. May 24, 2018 at 10:48 AM
    #2498
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    My 18 Off Road with the Technology Package came with a hidden FOB key and a "normal" key that also opens the tailgate and the driver's side door.
    Snowtrooper17 likes this.
  19. May 24, 2018 at 11:11 AM
    #2499
    drwx
    M'boro, TN
    only 17s and above have this. 16s did not.
  20. May 24, 2018 at 11:23 AM
    #2500
    dpippel
    Phoenix, AZ
    Yep, which is why I was responding to a question about the '18: "Interested in the type of keys your '18 has.. fob key and tailgate key." ;)
