Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Oct 17, 2018 at 9:37 AM
    #2681
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I believe the answer is no, it will still run. I heard my friends Mom got out of her car at the casino, she doesn't hear very well. Came out 3 hours later with it still running. This was a Jeep Cherokee. They only figured it out, because it was very hot outside and the car was nice and cool with the AC running. She locked it from the outside and everything. Someone should know how it works on the Tacoma however.
    burntcremebrulee likes this.
  2. Oct 17, 2018 at 9:38 AM
    #2682
    The Fuzz
    The Fuzz Member
    Stephen
    2018 White TRD OR 4x4
    Ah okay, anyone else know?
    Mine won't start with the keyfob far away, I'm not sure if it's smart enough to recognize it not running. Just something to pay attention too, I guess.
  3. Oct 17, 2018 at 9:38 AM
    #2683
    blackdogwanderrings
    blackdogwanderrings New Member
    2018 White Tacoma DCSB TRD OR 4x4
    CVT RTT, KB Voodoo bed rack
    Is this something the dealer needs to do or can I do it myself with the truck settings?
  4. Oct 17, 2018 at 9:47 AM
    #2684
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    It will keep running. They say it's a safety feature in case the key battery dies while you are driving. I'd prefer if it didn't allow you to shift out of park if the key isn't present. You also can't use the fob to lock/unlock the doors while it's running.
    rlj251 and burntcremebrulee like this.
  5. Oct 17, 2018 at 10:10 AM
    #2685
    tcjacado
    tcjacado Well-Known Member
    You can do it if you have techstream, or the dealer can do it also. I think you can also do it through carista.
    StayinStock likes this.
  6. Oct 17, 2018 at 10:37 AM
    #2686
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Yep, dealer or some other external programmer. It can not be changed from the multi-media system or the multi-information display settings.
  7. Oct 17, 2018 at 7:24 PM
    #2687
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Yup, I always get out of my truck with it running and lock it if I have to run back into the house for something I forgot. It starts beeping like crazy at you because it doesn't detect the fob. However, the big danger of doing this is if you don't lock it, someone could easily steal it and drive off.
    See my answer above and yes, the truck isn't designed to start unless the fob is inside the cab. There are ways to get around that, but it's a pain unless you have the remote starters that have an actual viable use in the snowy areas.
  8. Oct 18, 2018 at 6:04 AM
    #2688
    Ohiogarand
    Ohiogarand Member
    Dave
    2018 Tacoma TRD Sport
    Gentex Homelink Mirror
    Just got my first Tacoma in September. On those cold winter Saturday mornings, I like to leave the truck running when I run in to get bagels and coffee, locking the door with the fob. Can I do that with this truck?
  9. Oct 18, 2018 at 6:21 AM
    #2689
    mlr69
    South Carolina
    As long as you're outside the truck, you should be able to lock the doors with the fob while the engine is running.
    EDIT: My apologies, I'm pretty sure I got this to work at one point but now cannot seem to replicate. Seems you cannot use the fob to lock the truck if the engine is running.
  10. Oct 20, 2018 at 2:37 AM
    #2690
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    Does not work for me. I have to use the key to lock and unlock if truck is running.
  11. Oct 20, 2018 at 6:12 AM
    #2691
    Ohiogarand
    Ohiogarand Member
    Dave
    It likewise did not work for me either. Maybe there's a setting?
  12. Oct 20, 2018 at 6:52 AM
    #2692
    Fiatbreath
    Fiatbreath Well-Known Member
    Patrick
    2016 Toyota Tacoma TRD sport
    265/70/ tires hankook
    Got the TSB done for tranny gear hunting issue. Honestly, I didn’t really think it was that bad, till I had it done. What a difference!. The pedal now reacts when you push down on it. I actually burned out a couple times. Was not expecting that big of a difference.GET IT DONE.
    FlipDiver, StayinStock and 20tacoma17 like this.
  13. Oct 20, 2018 at 7:10 AM
    #2693
    mlr69
    South Carolina
  14. Oct 20, 2018 at 7:58 AM
    #2694
    drwx
    M'boro, TN
    This is true. I posted that earlier.
  15. Oct 20, 2018 at 12:12 PM
    #2695
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Try using the inside lock switch on the door...!!
  16. Oct 26, 2018 at 5:24 AM
    #2696
    hallux
    hallux Well-Known Member
    I just got my truck from the dealer yesterday, how can I be sure all the TSB’s were done?
  17. Oct 26, 2018 at 5:43 AM
    #2697
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
    If you're referring to TSB 58-18 or 62-18, find a code reader that will read your ECU calibration ID.
  18. Oct 26, 2018 at 5:47 AM
    #2698
    hallux
    Essentially I’m worried about any TSB’s, the dealership I got mine from gave me far too much for my trade in so their logic is confusing to me. So I want to ensure everything was done lol
    janis5151 likes this.
  19. Oct 26, 2018 at 6:12 AM
    #2699
    Fiatbreath
    Patrick
    I think there is a sticker under the hood that they put on.i have not checked yet, just feel it.
  20. Oct 26, 2018 at 9:36 AM
    #2700
    janis5151
    janis5151 Member
    I am in the same boat. How do I find out if my 18 TRD off road has had the TSB for gear hunting performed? Was it something that had been fixed prior to the 2018 year?
    DurtGrrl and hallux like this.
