Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Nov 25, 2018 at 6:18 PM
    #2761
    krootz
    krootz Well-Known Member
    Justin
    Broadview Heights, OH
    2017 Tacoma DCSB Off Road
    OME 887, 5100s, Deaver single AAL, Spidertrax, 265/75R16 Duratracs
    Whatcha talking about there fella?
    :notsure:
  2. Nov 25, 2018 at 6:34 PM
    #2762
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Your hood shouldn't be shaking! Get it to the dealer ASAP before something comes loose and it flies up on your windshield or worse.
  3. Nov 25, 2018 at 10:16 PM
    #2763
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No aluminum, but there have been a few hoods that separate from the bracing, your warranty would cover the repair if your truck has that issue.
    Cuffs and tcjacado like this.
  4. Nov 26, 2018 at 1:47 PM
    #2764
    Airborne22
    Airborne22 It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    I notices that too. Its the flex in the hood. Not actually shaking per se. More like vibration...like it could use additional bracing under the hood. I'm not that concerned. Just noticeable.
  5. Nov 27, 2018 at 1:31 PM
    #2765
    krootz
    Justin
    I need to check my hood bracing before my warranty runs out
    :pccoffee:
    shakerhood likes this.
  6. Dec 27, 2018 at 7:38 AM
    #2766
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    After reading about the tranny TSB, I brought my new-to-me '17 Sport to my local dealer and told them I noticed a problem when I was driving around 40-45 mph. I said it felt "different", like the motor was misfiring or something. The service mgr said "Did it feel like it was surging?" (the TSB 'buzzword', LOL) I said yeah, that describes it. They applied that TSB that day.
    over60, Odi412, Norsemanvike and 2 others like this.
  7. Dec 27, 2018 at 8:03 AM
    #2767
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Does anyone have the maintenance checklist that someone did a check sheet on?
  8. Dec 27, 2018 at 8:54 PM
    #2768
    Oscar I
    Oscar I No longer a toyota driver
    On my 19 my u bolts had about 2 turns to hit torque spec. And the paint needed the hair dryer trick. Thanks for this thread they fixed it before I left.
  9. Jan 8, 2019 at 2:05 PM
    #2769
    TacomaStevie
    TacomaStevie Well-Known Member
    San Antonio, TX
    2019 White Tacoma TRD Sport
    About the Entune/XM Entertainment system
    So I had a 2015 Tundra and when I was on XM Radio the left "d-pad" on the steering wheel was for UP/Down moved between your saved Stations and Left/Right went to the next XM Station. This was so convenient for when I wanted to scroll/browse what was on on the satellite.
    However, I just got a 2019 Tacoma, and the left d-pad is UP/Down is for next programmed station and Left/Right is for volume, The only way (that I know of) to surf the next XM station is to use the "seek or tune" on the actual radio, which is fine but not as convient. is this just not an option in the Tacoma from the steering wheel. Sorry so long. I just want to surf while in traffic
    JAUNE likes this.
  10. Jan 8, 2019 at 5:20 PM
    #2770
    tcjacado
    tcjacado Well-Known Member
    I believe the steering wheel controls will only surf through preset stations on the head unit.
    t0nyvalenzuela likes this.
  11. Jan 8, 2019 at 5:26 PM
    #2771
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I was getting a howling noise coming from my side view mirrors,I ran a thin bead of silicone on the seam of the mirror housing and it went away for good!
    Cuffs and doublethebass like this.
  12. Jan 9, 2019 at 4:30 PM
    #2772
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    A quick press of the up or down button changes to your next preset station, as you have described.
    If you press and hold the up or down button a little longer (less than 2 seconds), you'll hear a beep and the radio will seek the next available station.
    If you press and hold even longer, your radio will quickly scroll through the channels until you let go of the button - nice if you're on XM and want to get from channel 8 to 80 quickly.
    This works on both AM/FM and XM.
    AKGSD, GSDLVR123, Cuffs and 5 others like this.
  13. Jan 10, 2019 at 10:50 AM
    #2773
    Jayro
    Jayro Well-Known Member
    Los Angeles
    2019 TRD Pro and 2019 TRD Off-road
    Great stuff!
  14. Jan 13, 2019 at 10:51 AM
    #2774
    Arashishozen
    Arashishozen Member
    Joseph
    2018 Tacoma TRD offroad 4x4 crew cab
    I would like to add, that you can in fact lock the doors with the key fob in it, as long as you lock it with another key fob.
    My wife left her key fob in my truck and if I tried to lock it with the outside door handle, it wouldnt let me. However if I locked it with the key fob, it would lock the doors.
    Then I gave her my key and told her to go inside. The door wouldn't unlock even though her key fob was in it, unless I had my key fob.
    Cuffs likes this.
  15. Jan 13, 2019 at 9:38 PM
    #2775
    Oscar I
    Or just disable the key.
    Hold lock and press unlock 3 times. Light will flash three times. Key is disabled. It will work again when you press any button.
  16. Jan 13, 2019 at 10:37 PM
    #2776
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    What about locking it while it’s running to warm it up?
  17. Jan 13, 2019 at 10:50 PM
    #2777
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    Just learned something new after over a year. The rear headrests click into the seats when folded down. There are holes ready for them. So. Remove headrests. Fold seats down. Insert headrests into the provided holes on the back of the seats. :eek:
    nTg, Cuffs, xenonsupra and 4 others like this.
  18. Jan 14, 2019 at 6:38 AM
    #2778
    Arashishozen
    Arashishozen Member
    Joseph
    I mean that works, but I dont want to be remembering to be disabling my wife's key when we ride together. Door locks just by hitting the lock button on the key fob and no key fob trickery stuff would be needed
    Only way I have seen to lock the door while running is to manually use the key to lock and unlock the doors.
  19. Jan 14, 2019 at 7:18 AM
    #2779
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    And of course a remote start such as the one from 12 Volt Solutions.
  20. Jan 16, 2019 at 12:45 PM
    #2780
    daleclough
    daleclough Well-Known Member
    Portland, OR
    18 TRD Off Road Double-Cab Short Bed
    None... yet
    Really? I didn't see this in my '18. Pictures?
