Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 19, 2019 at 11:44 AM
    #2841
    valeyellow46
    valeyellow46 Well-Known Member
    Christopher
    Tacoma SR5 Cavalry Blue
    less beverages before bed bro.
    Boghog1 likes this.
  2. Mar 22, 2019 at 11:28 AM
    #2842
    SteveB313
    SteveB313 Well-Known Member
    Detroit
    20 Tacoma TRD OR blackout/MGM, dbl-cab, AT3W’s
    After searching high and low for fancy holsters and mounts to store my pistol while driving I looked down and noticed the perfect spot.. no freeplay in any direction, fairly discreet, easy grab and go..
    ian2016, Huang618, nTg and 4 others like this.
  3. Mar 22, 2019 at 11:33 AM
    #2843
    valeyellow46
    Christopher
    that works but there's so many good mounts for cars and trucks now that allow quick draw.
  4. Mar 22, 2019 at 11:36 AM
    #2844
    SteveB313
    Detroit
    I've seen so many, magnets, bolt-ons, after using this spot for a short while I've found no need for an installed piece. Note: this happens to work for my 229 with a single clip IWB, not necessarily everyone else, just a suggestion if you've got a similar size
  5. Mar 22, 2019 at 12:16 PM
    #2845
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    thinky and czach like this.
  6. Mar 25, 2019 at 6:11 PM
    #2846
    BrokeDownSouth
    BrokeDownSouth Well-Known Member
    Chase
    2019 TRD Off Road Super White
    I double checked and did not see this listed:
    Cruise control on the 6-speed manual transmission does not disengage when you shift gears or depress the clutch. It will pause then resume when the clutch is released in-gear, up or down shift.
    I found this out the hard way while approaching a stop light. Pushed the clutch in and coasted for a few seconds, then down-shifted into 3rd. Truck lurched forward under its own will trying to resume the cruise speed I had set.
    Tachord likes this.
  7. Mar 25, 2019 at 6:28 PM
    #2847
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Hold up, that’s not true on mine.....if I take the truck out of gear or push the clutch or push the brake it pauses cruise control (meaning it remembers where I had it set but doesn’t power the truck until I tell it to resume)......which is the way it should be
    You sure you didn’t accidentally hit resume? Or accidentally let the clutch out too quick and half-stall? If you’re sure, you should get that checked out. That’s a safety issue that you shouldn’t be having.
    Cuffs likes this.
  8. Mar 25, 2019 at 6:47 PM
    #2848
    BrokeDownSouth
    Chase
    Yeah I'm pretty sure. I have repeated the effect but I will re-confirm tomorrow.
  9. Mar 25, 2019 at 6:48 PM
    #2849
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Definitely do a repeat.....it for sure should not be doing that
    I trust it wasn’t sloppy clutch work :thumbsup:
  10. Mar 26, 2019 at 7:57 AM
    #2850
    BrokeDownSouth
    Chase
    So I tested more diligently this morning on my commute.
    With the adaptive cruise control turned on, the truck will resume the previously set speed after shifting up or down. If the clutch is depressed or the transmission is in neutral for more than a few seconds, the computer will beep and cancel the cruise control. Not sure how long it takes to prompt a cancel exactly, 5 seconds at most.
    When the adaptive cruise is off, cruise control gets canceled immediately when shifting or pressing the clutch.
    I have a 2019 TRD OR. This appears to be a feature only on newer models with adaptive cruise.
    bonifacio_629, AKGSD and Tachord like this.
  11. Mar 26, 2019 at 8:21 AM
    #2851
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I think you hit the nail on the head.....it must be an adaptive cruise thing. My 17 doesn’t have adaptive cruise.
    I guess it makes sense the adaptive cruise wants to get the truck back up to speed, but it sounds like it’s a bit too anxious about it and tries to gun it to get there. You’d think Toyota would dampen the response.
  12. Mar 26, 2019 at 5:37 PM
    #2852
    BrokeDownSouth
    Chase
    I retested the scenario that startled me initially. Approaching a stoplight at 40mph, downshift from 5th to 3rd, truck was at about 35mph when I let out the clutch. The acceleration did not seem nearly as severe when I was expecting it.
    Yes, I am a cruise control fanatic and will use it at 40mph or even slower.
    doublethebass[QUOTED] likes this.
  13. Mar 26, 2019 at 5:43 PM
    #2853
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    I would think to use cruise control at 50 mph or above on an open road. 40 mph and below is just too much of a risk to wreck your vehicle.
  14. Mar 26, 2019 at 5:57 PM
    #2854
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    haha I use it at the very lowest it'll let me go.....23mph
    Some of the towns here have a really strict 25mph speed limit for quite a ways with cops out and about, so I put it on slow and let it ride
  15. Mar 26, 2019 at 7:25 PM
    #2855
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I do the same...
  16. Mar 27, 2019 at 8:17 AM
    #2856
    BrokeDownSouth
    Chase
    I like the adaptive cruise at low speed because I can shift down going uphill then coast downhill in 5 or 6 without having to reset the cruise control.
  17. Mar 27, 2019 at 6:57 PM
    #2857
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Perfect fitment
    You’re welcome.
    MontanaEric, nTg, Teaford and 10 others like this.
  18. Mar 27, 2019 at 7:08 PM
    #2858
    FireRoadFan
    FireRoadFan Well-Known Member
    New Mexico
    2018 Tacoma TRD Pro
    Options on the truck delivered to the dealer: All-Weather Floor Liners Door Sill Protector Door Edge Guard Mudguards Spare Tire Lock Wheel Locks Added by me: Diamondback HD Tonneau Cover Rigid Industries 2016-2017 Toyota Tacoma Bumper Mount (SKU: 46565) Rigid Industries SR-Series Pro 30" Spot/Drive Combo (SKU: 931314) LT235/85R16 DISCOVERER S/T MAXX
    Me too. How else is it humanly possible to drive so slow? Cruise control is the best tool for low speed zones.
    Cuffs, AKGSD, GSDLVR123 and 2 others like this.
  19. Mar 31, 2019 at 2:49 AM
    #2859
    s.e.charles
    s.e.charles Well-Known Member
    I always figured the cops should arrest the folks driving 5 mph below the speed limit. stoners 'n' all . . .
  20. Mar 31, 2019 at 5:13 AM
    #2860
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    Crawl control in Overdrive. lol
