Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Nov 12, 2019 at 7:46 AM
    #3001
    Fat Tony
    Fat Tony Member
    north east jerzy
    Black TRD Pro
    Murdered + K&N Intake
    anyone here have the moon roof leak on them?
  2. Nov 12, 2019 at 1:21 PM
    #3002
    TacoSportTRD
    TacoSportTRD Well-Known Member
    Michigan
    2017 TRD Sport AC 4x4 V6 Barcelona Red
    Not sure if this was mentioned but I found out accidentally that if you push on the volume switch it not only mutes the volume but also brings up the input selection screen.
    JmsWms likes this.
  3. Nov 12, 2019 at 1:44 PM
    #3003
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Yea, pressing the PWR-VOL knob turns on/off the audio system. When off, the screen goes to the "AUDIO" mode screen where you can select different audio sources - same as if you press the "AUDIO" button.
    Related... if you press and hold the PWR-VOL knob for 3+ seconds, it'll restart the system, kinda like rebooting a computer.
    TacoSportTRD[QUOTED] and JmsWms like this.
  4. Nov 12, 2019 at 2:09 PM
    #3004
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    This is good to know!
    mlr69[QUOTED] likes this.
  5. Nov 12, 2019 at 3:11 PM
    #3005
    TacoSportTRD
    Michigan
    I meant lightly touching the knob will temporarily just mute the speakers without turning off the radio.
  6. Nov 12, 2019 at 9:02 PM
    #3006
    mlr69
    South Carolina
    I believe what you are describing is the audio system being turned on/off by the power knob push. The radio, aka head unit, doesn't get turned off, unless you shut off the truck.
  7. Nov 14, 2019 at 11:20 AM
    #3007
    TacoSportTRD
    Michigan
    I get it now, the button puts it into a standby mode and brings up the input selection.
    To change the input I was hitting the mode button on the steering wheel multiple times to change inputs.
  8. Nov 14, 2019 at 3:54 PM
    #3008
    mlr69
    South Carolina
    Pressing the AUDIO soft-touch button also brings up the source selection screen, without turning off the radio.
  9. Nov 17, 2019 at 5:34 PM
    #3009
    EightGodzillas
    EightGodzillas Scales of Justice
    Lake Norman
    2018 Tacoma TRD OffRoad
    Just saw this and wish I had known. I have almost hit 5 cars because of this. I'm 6'2" and for me, the mirror completely covers a car at a 4 way stop coming from the right. Like, they are hidden and at every stop I have to look around the mirror to make sure no one is there.
  10. Nov 17, 2019 at 8:47 PM
    #3010
    EightGodzillas
    Lake Norman
    This does not work for the 2018 OffRoad TRD. There is no adjustment other than the ball socket. The mirror will not go up and down and it's dangerous. It definitely covers the field of view.
  11. Nov 18, 2019 at 5:05 AM
    #3011
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    It works on my lowly SR. LOL!
    davidstacoma likes this.
  12. Nov 18, 2019 at 6:13 AM
    #3012
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    I just noticed that my 19 OR only had bed rails on the sides of the bed. The second gens also have a bed rail at the front of the bed. I had an extra set of rails (swapped out the second gen for unistrut) and the second gen front rail lines up perfectly with the third gen holes and bolts.
    JJ Diablo likes this.
  13. Nov 18, 2019 at 7:28 AM
    #3013
    Onemorodeo
    Onemorodeo Well-Known Member
    OC SoCal
    ‘18 dclb TRD Sport 4wd Cement
    The mirror on my 2018 Sport is adjustable. I’m 6’5” and couldn’t see sh** until I found this trick.
    CusterFan and 20tacoma17 like this.
  14. Nov 18, 2019 at 8:41 AM
    #3014
    EightGodzillas
    Lake Norman
    Do you have the GoPro mount beside your mirror?
  15. Nov 18, 2019 at 8:42 AM
    #3015
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    My mirror appears to be on a mounting rail. Looks like there is a locking set screw. This is based on a quick glance this AM . Will explore later.
  16. Nov 18, 2019 at 8:53 AM
    #3016
    Onemorodeo
    OC SoCal
    yes
  17. Nov 20, 2019 at 7:33 PM
    #3017
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    Sure it does. It's the same mirror as the off-road and it works fine in mine. It's ball joint on both ends of the piece that connects the mirror to the windshield.
    mlr69 and payrow like this.
  18. Nov 20, 2019 at 7:35 PM
    #3018
    drwx
    M'boro, TN
    None of the 3rd gens come with the front bed rail unless they added it in 2020 (I didn't check the new stuff for that). It was one of the first things I bought when I got my 16 and I transferred it over to my 17.
  19. Nov 21, 2019 at 4:30 AM
    #3019
    TacoSportTRD
    Michigan
    I seen the dual ball joints.
  20. Nov 21, 2019 at 5:29 AM
    #3020
    mlr69
    South Carolina
    What is the "slide" you speak of? All the adjusting (tilting, turning, raising, lowering) is done at the ball joints.
    Grindstone and davidstacoma like this.
