Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Nov 21, 2019 at 5:50 AM
    #3021
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    There is no slide adjustment. You are merely switching from just adjusting it on the mirror end to adjusting it on both the mirror and windshield ends.
  2. Nov 21, 2019 at 6:09 AM
    #3022
    TacoSportTRD
    TacoSportTRD Well-Known Member
    Michigan
    2017 TRD Sport AC 4x4 V6 Barcelona Red
    I found the adjustably using the dual ball joints within a week of buying my Tacoma.
    But just checked my past reading and see now that it was an adapter that someone made.
  3. Nov 22, 2019 at 12:43 PM
    #3023
    Denteen
    Denteen Well-Known Member
    D
    Central valley CA
    2018 TRD Sport 4x4 DCSB
    TRD Pro suspension-2nd Gen Frontrunner bed rack Tacowiede radio knobs! Best mod everrrr!!! DSM mount Wheel swap to OR’s. For now... Gone-2005 DC Icon Stage 2 with Rear Resis;ICON 3 leaf AAL installed! Gone-2001 xcab 4x4 4cyl 5spd. Best truck ever...
    My sons truck is a 19 with power tailgate lock. Has someone figured out how to disable the auto lock/unlock with the doors locking/unlocking? I cant imagine the tailgate lock will last very long, as it is a very pronounced mechanical noise every time. I would love to turn the feature off
  4. Nov 22, 2019 at 1:25 PM
    #3024
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    I don't believe that's going to an option/feature. Since the Taco doesn't come from the factory with a power tailgate lock, someone (previous owner / dealer) most likely installed a Pop & Lock. That P&L taps in to the trucks door lock wiring, usually behind the front passenger kick plate.
    It's loud because there no insulation or sound deadening material in the tailgate. I wouldn't be too concerned about it. If that actuator ever fails, it's really easy to get in to the tailgate and replace it.
    jamesfishn09 likes this.
  5. Nov 23, 2019 at 5:38 PM
    #3025
    Kings
    Kings Well-Known Member
    Cole
    Ontario, Canada
    2018 Tacoma TRD OR MGM
    17x8.5 SCS Ray 10s, 265/70/17 BFGoodrich KO2s, 2.5" ADS Ext. Travel coil-overs and shocks with compression adjusters, ICON tubular Delta Joint UCAs, Extended brake lines front and rear, OME medium duty Dakar leaf pack, Locked Offroad hydraulic rear bump stops
    W̶e̶l̶l̶ ̶s̶h̶i̶t̶,̶ ̶g̶o̶t̶ ̶e̶x̶c̶i̶t̶e̶d̶ ̶t̶h̶e̶r̶e̶ ̶f̶o̶r̶ ̶a̶ ̶m̶o̶m̶e̶n̶t̶.̶ ̶I̶'̶m̶ ̶6̶'̶2̶"̶ ̶a̶n̶d̶ ̶i̶t̶ ̶g̶e̶t̶s̶ ̶i̶n̶ ̶t̶h̶e̶ ̶w̶a̶y̶ ̶a̶n̶ ̶a̶w̶f̶u̶l̶ ̶l̶o̶t̶ ̶.
    Edit: Serves me right for not reading farther down!
    Cuffs and davidstacoma like this.
  6. Nov 23, 2019 at 6:12 PM
    #3026
    drwx
    M'boro, TN
    If you read the other messages, you can see that he was wrong and was thinking of some other mod. You can definitely push the mirror to the ceiling on all models. There's a ball joint on the windshield and on the mirror.
    payrow, CusterFan and Kings[QUOTED] like this.
  7. Nov 23, 2019 at 7:16 PM
    #3027
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Yeah and is is stiff so a man needs to grasp the mirror on each side and lift up with some steady force.:thumbsup:
    davidstacoma likes this.
  8. Nov 23, 2019 at 8:45 PM
    #3028
    drwx
    M'boro, TN
    But not use so much force that you rip your mirror off and break the windshield like that one guy did.
    Onemorodeo and davidstacoma like this.
  9. Nov 26, 2019 at 6:24 AM
    #3029
    Coronerrpm
    Coronerrpm Well-Known Member
    Bob
    2017 Tacoma sport
    My 2017 sport is not adjustable
  10. Nov 26, 2019 at 6:26 AM
    #3030
    Coronerrpm
    Bob
    2017 Tacoma sport
    Really? I will look again but what about the wire plastic piece?
  11. Nov 26, 2019 at 6:52 AM
    #3031
    Coronerrpm
    Bob
    2017 Tacoma sport
    Wow. It worked. I can now see out my front window. Thanks
  12. Nov 26, 2019 at 6:53 AM
    #3032
    Coronerrpm
    Bob
    2017 Tacoma sport
    You were correct. It worked:)
  13. Nov 26, 2019 at 8:28 AM
    #3033
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    This ya neither tip nor trick. I was out wasting time on a Sunday. Best day to cruise a dealership with no hassling sales people. Happened to notice this awesome green TRDPRO Tacoma.
    It had the markings under the headlamps.
    It also had the forward camera mounted in the grille. Anyone know if this is standard or optional equipment on the new trucks or maybe just the Pro?
  14. Nov 30, 2019 at 6:51 PM
    #3034
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    3rd gens get an optional power lock and the oem kit is a cheap and easy installation. I'm planning to add the popper to compliment the power lock. It's a clean kit, I'll link it if I can find it easily.
    Trd OR led headlights have something else, a cornering light or something in its place, but those are stock LED headlights on trd pro. (That have the trd/pro script.)
  15. Nov 30, 2019 at 8:07 PM
    #3035
    drwx
    M'boro, TN
    The forward camera may be that new feature that shows all around the truck on the radio screen. I think they call it panoramic view.
    Cuffs[QUOTED] likes this.
  16. Dec 3, 2019 at 5:19 PM
    #3036
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
    20191116_160032.jpg The front camera/clear plate in the grill of the 2020 TRD Pro is for the Adaptive Cruise Control Radar and part of the Terrain Monitoring System, here is mine...
  17. Dec 4, 2019 at 10:47 PM
    #3037
    Toyo901
    Toyo901 Well-Known Member
    Shaheen
    West Tennessee
    2019 White Tacoma TRD ORLB
    I’m not sure it’s been mentioned or not but if you swipe the door handle where those two bars are, the truck will lock. Basically reverse of the truck unlocking when you touch the handle.
    Harley05 and Grindstone like this.
  18. Dec 5, 2019 at 8:24 AM
    #3038
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    I've been trying this since I saw this post and sure enough, a swipe is far more effective than just placing your fingers on it.
  19. Dec 8, 2019 at 8:55 PM
    #3039
    Grindstone
    Grindstone Requires Adult Supervision
    Just found this, adjusted it, and now one minor complaint I had is gone. Thanks!
    Markings are Pro only.
    Camera is part of the Multi Terrain Monitor (MTM) available on the Pro and OR with Adv Tech package. The Sport can get the Panoramic View Monitor. I don't know the specifications of the PVM.
  20. Dec 8, 2019 at 9:06 PM
    #3040
    Cuffs
    Well yea. Since it says Pro, I would hope they only put that on that specific model...
