Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 2, 2020 at 7:09 PM
    #3121
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    2x6 is a better fit. I use it regularly.
    Frank
    shane100700, Cuffs and oly51 like this.
  2. Mar 6, 2020 at 9:48 AM
    #3122
    Norsk
    Norsk Well-Known Member
    2024 Underground Gray Tacoma TRDOR Premium
    Where can i find the velcro?
  3. Mar 6, 2020 at 10:29 AM
    #3123
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
  4. Mar 6, 2020 at 10:29 AM
    #3124
    jamesfishn09
    jamesfishn09 Well-Known Member
    2003 Tundra
    Home Depot, Lowe’s, Rite Aid, Walgreens, Walmart, Target, Amazon, Michaels, Ace Hardware and pretty much anywhere else random crap is sold! C’mon bro, it’s a little piece of Velcro!
    shane100700 likes this.
  5. Mar 8, 2020 at 11:19 AM
    #3125
    mullett757
    mullett757 Well-Known Member
    Joe
    Virginia Beach
    2020 White TRD Sport DCLB
    I had this setup in my 4Runner and it fits perfectly in the taco as well. Much easier to access quickly. $35 gum creek holster mount that fits a bunch of different style holsters right under the steering column. I use that canvas one because sometimes i carry a compact or full size instead of my 43x so it holds them all
  6. Mar 8, 2020 at 9:09 PM
    #3126
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    you could find the wire and add a switch
  7. Mar 9, 2020 at 3:52 PM
    #3127
    Eric.KCMO
    Eric.KCMO Well-Known Member
    Eric
    Lee’s Summit, MO
    2017 Black Tacoma TRD Off Road
    Hows the leg room with that?
  8. Mar 9, 2020 at 3:53 PM
    #3128
    mullett757
    Joe
    Virginia Beach
    No issues, it sits right between the legs. It’s only as wide as the holster you put on it
  9. Mar 9, 2020 at 5:57 PM
    #3129
    quantumechanic
    quantumechanic Well-Known Member
    2022 Tacoma SR5 DCSB 4x4
    I think there may be an air bag behind that panel in case you would want to consider that.
  10. Mar 9, 2020 at 7:35 PM
    #3130
    mullett757
    Joe
    Virginia Beach
    Yeah I saw it earlier when I was doing a little armoralling to the inside. Kinda a buzz kill, but they have an alternate mount that goes on the side as well so might go that route. I just hate drilling into the trucks
  11. Mar 11, 2020 at 11:31 AM
    #3131
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    I’m sure this is in here somewhere but I wanted to add it because it was not easy to find an answer.
    Im assuming this applies to 2019 and older:
    In order to stream audio (such as Spotify) over usb from an iPhone you have to have at least 1 song downloaded and stored on the phone. You can pick any random song, I just found one on iTunes/Apple Music and bought it. After that plug in usb and everything works fine. This explains why when I was searching some folks said it worked fine for them and other people said you can’t.
    Bothered me for the first few days...Bluetooth really hurts the sound quality due to the compression/lack of bandwidth.
    Onemorodeo, dleriche and VB25 like this.
  12. Mar 12, 2020 at 5:54 AM
    #3132
    allen993
    allen993 Well-Known Member
    Allen
    Alabama
    2019 TRD Off-Road, Access Cab, Cement
    I don't guess there is one of these that has a clock on it...? One that is flush...don't want it sticking out.
  13. Mar 15, 2020 at 6:39 AM
    #3133
    mwaterous
    mwaterous Well-Member Known
    Mark
    Western Slope, CO
    2016 TRD OR
    Buy More Things
    How would you ever get it back out?
  14. Mar 15, 2020 at 2:16 PM
    #3134
    Sunsetsearider
    San Francisco
    You can replace the outlet with a flush mount usb plug with a display.
  15. Mar 15, 2020 at 4:07 PM
    #3135
    mwaterous
    Mark
    Western Slope, CO
    2016 TRD OR
    Buy More Things
    keygrip likes this.
  16. Mar 25, 2020 at 7:03 PM
    #3136
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Came across this one.
    I have the @N2DesignsInc remote start in a 2020. Tapping the door handle to lock the truck counts as one of the 3 times to press the lock button to start the truck. Small but, I was curious if the lock command had to come from the key or not.
    N2DesignsInc likes this.
  17. Mar 26, 2020 at 4:36 PM
    #3137
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    2x8s are an even better fit. You'll have to rasp off the lower corners but they will fit snug.
    Nomad26 likes this.
  18. Mar 28, 2020 at 10:49 PM
    #3138
    micpib1
    micpib1 New Member
    2020 TRD Pro
    I recently took a 1,670 mile trip in my 2020 Tacoma TRD Off Road with stock tires. I traveled all highway and speeds between 75-80 MPH and the Transmission cycled continually between 6th and 5th while I used the Cruise Control as much as possible and left the transmission in Drive. My first three tanks of fuel, I got 15-17 MPG. For the reminder of the trip I continued using the Cruise Control but locked out 6th (Overdrive), my mileage went to 19-20 MPG and no cycling of the transmission unless I was climbing or passing, etc. Anybody else experience this or any changes that I should do differently? JH
    DakotaSioux likes this.
  19. Mar 29, 2020 at 8:40 AM
    #3139
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    This common for 3rd Gens. Did it hesitate when you tried to gun/floor the gas pedal? Through '18s, it would pause first while it hunted for a gear, then took off.
    micpib1[QUOTED] likes this.
  20. Mar 29, 2020 at 9:42 PM
    #3140
    AZ_Tumbleweed
    Wilmington, NC
    The passenger seat can move and recline ridiculously far forward and backwards. Almost makes it feel like a full size truck when sitting in the back seat lol
