Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 30, 2020 at 5:34 AM
    #3141
    keygrip
    keygrip Well-Known Member
    Greg
    Catskill Mountains, NY
    2020 Tacoma TRD offroad, DCLB, magnetic grey metallic
    2" Fox 2.5 performance elite dsc front lift, 33" KM3 (summer),265/75 r16 KO2s (winter), led bed lights, remote start, vhf/uhf radio, trailer brake controller, Jericho mid rise cap, US Offroad winch cradle, Warn Zeon 10k winch, Martin Offroad roof rack, Deaver stage 2 leafs, u bolt flip, Duro bumps front/rear, Overland Tailor tune, Cali-raised trail rock sliders, Cali-raised full skid plates, SPC UCAs.
    I think it's faster to just hit the brake and start the truck normally, then to wait 15 seconds holding the button...
    OilCapital2021 and jamesfishn09 like this.
  2. Mar 30, 2020 at 6:49 AM
    #3142
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Yes.. it's a pain waiting for the full 15 seconds. It would be absolutely fantastic if someone could find a TechStream setting to change this timeout to about 5 seconds . . .
  3. Mar 30, 2020 at 7:06 AM
    #3143
    allen993
    allen993 Well-Known Member
    Allen
    Alabama
    2019 TRD Off-Road, Access Cab, Cement
    Not sure what you mean by this. Did you just move the gear shifter from D to S and bump the shifter to 6?
  4. Mar 30, 2020 at 11:32 PM
    #3144
    micpib1
    micpib1 New Member
    2020 TRD Pro
    I moved the shifter to S and then into 5th Gear which in effect locks out 6th gear. The transmission will still downshift into lower gears, it just never goes past 5th when upshifting. JH
  5. Mar 31, 2020 at 8:19 AM
    #3145
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    my understanding is that the shift points are different in s-mode, so you may have achieved the same or better mpg results by setting it to 6th as well. there's about a million threads about mpg, shiftpoints, ect, and s-mode.
    Midnite2020Pro likes this.
  6. Apr 2, 2020 at 10:05 AM
    #3146
    Wheeler's Off-Road Inc
    Wheeler's Off-Road Inc Well-Known Member
    Grants Pass, OR
  7. Apr 2, 2020 at 4:27 PM
    #3147
    FirstTimeTaco2020
    FirstTimeTaco2020 I came here for the chemlight batteries
    Cameron
    2016 TRDOR
    Just checked the U-bolts on my recently purchased 2016. Good to go at 52 ft lbs. Thanks!
    20tacoma17 likes this.
  8. Apr 3, 2020 at 6:22 AM
    #3148
    dbole007
    dbole007 Well-Known Member
    Dennis
    Ashland, Ohio
    2017 Toyota Tacoma 4x4 DCSB
    So,
    I am looking at a 2017 TRD Off Road truck. Going to look at it today, at a dealer. Looks really clean and only has 25K miles on it. IS there anything I should look for and anything you guys can think of that would help me when I test drive it? . I have a 09 Tacoma, and love it, but I can get into this newer one.
    Kjpstorm73 and t@com@ like this.
  9. Apr 3, 2020 at 6:23 AM
    #3149
    FirstTimeTaco2020
    Cameron
    2016 TRDOR
    Crawl under and look for mud/rust. Probably a good truck though!
    t0nyvalenzuela likes this.
  10. Apr 3, 2020 at 6:25 AM
    #3150
    dbole007
    Dennis
    Ashland, Ohio
    Thanks, I planned on that, learned my lesson on the 4runners I bought. I also heard about the hood vibration issue. Otherwise, I think, this may have a new home.
    FirstTimeTaco2020 likes this.
  11. Apr 3, 2020 at 6:31 AM
    #3151
    FirstTimeTaco2020
    Cameron
    2016 TRDOR
    Within the first week of having mine (before first payment and before it had tags), I changed the front and rear diff fluid. Not because I thought the fluid was bad but because I wanted to see how much metal was in the fluid and attached to the magnet. Did the same for the transmission (just the pan, not a fluid swap).
    If I didn’t like what I saw then I was going to take it back to the dealership.
    Of course my truck had 40k miles on it when I bought it so it was almost time for that service anyways.
  12. Apr 3, 2020 at 6:35 AM
    #3152
    dbole007
    Dennis
    Ashland, Ohio
    Hmm, good idea.. I might have to also.. I will definitely be looking at checking the service records for this and keeping it up to date on those if I do pull the trigger.
  13. Apr 3, 2020 at 8:56 AM
    #3153
    quantumechanic
    quantumechanic Well-Known Member
    2022 Tacoma SR5 DCSB 4x4
    Study the CarFax for it. There is often a good amount of info (and possibly insight) there.
    dbole007[QUOTED] and oly51 like this.
  14. May 3, 2020 at 6:02 PM
    #3154
    Sliding West
    Sliding West Mad Props!
    Dave
    Vancouver
    20 AG Pro
    SPC UCA Westcott Design Front Icon Progressive Add a Leaf Greenlane Step Slider Retrax Pro Retractable Cover Weatertech Visors EGR Hood Deflector Meso Headlight Trim Plates Meso Red Start Button Meso Vent rings Meso Blackout Start and 4X4 ring Meso Total Tail Stage 1 Meso V5 Turn signals Meso Puddle Pods Meso Overhead Hexrack Meso door handle covers VLED Vanity, License, and Plate reverse lights Tacoma OEM bed step Raptor Lights Meso Ultimate Red/White Interior Lights KTJO Grab Handle KTJO Door Pocket Lights Ice Blue Durabump Front SCS SR8 17x8.5
    Is it attached by double sided tape? Or is the pressure from the cut enough to hold?
  15. May 3, 2020 at 6:06 PM
    #3155
    jamesfishn09
    jamesfishn09 Well-Known Member
    2003 Tundra
    I think all the Velcro tape has double sided tape. It is just a small piece , maybe size of nickel or slightly larger.
  16. May 3, 2020 at 6:08 PM
    #3156
    Sliding West
    Dave
    Vancouver
    20 AG Pro
    Like the idea. Thanks for sharing!
  17. May 10, 2020 at 3:51 PM
    #3157
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    Hey guys whats the best hose size to do the A/C drain trick? Thanks in advance
  18. May 10, 2020 at 3:52 PM
    #3158
    StayinStock
    StayinStock Pepsi > Coke
    Bob
    Missouri
    Yes I do
    Some
  19. May 10, 2020 at 3:56 PM
    #3159
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
  20. May 13, 2020 at 2:27 AM
    #3160
    dhectorg
    dhectorg Well-Known Member
    Don
    2020 Toyota Tacoma TRD OffRoad
    The 6 speed auto in my Tacoma hasn't learned shit. It's just as terrible after 4 months and nearly 7000 miles as it was on day 1. I don't know where people are getting this nonsense, but my assessment of the auto is that it's programmed to maximize fuel economy, but it doesn't seem to do much for real world mileage. Plus the 3.91 gears make it even worse, especially on even the slightest hilly terrain. Regearing to 4.88 or 5.29 is pretty much a necessity.
    Hot Taco sauce likes this.
