Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Sep 29, 2022 at 4:41 PM
    #3421
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, at times I wonder if the auto dimming feature is working on mine. I’ll have to try this to see if there is any difference. Mind boggling that the little centre headrest would cause any issues.
    TRDRed likes this.
  2. Oct 10, 2022 at 7:29 PM
    #3422
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    TRDRed, TOMRR, stftaco and 1 other person like this.
  3. Oct 11, 2022 at 2:15 PM
    #3423
    TheSpartan
    TheSpartan Well-Known Member
    Gorgo (22 Army Green TRD Sport DCSB)
    if that headrest is in just the right spot, it can cast a shadow over the sensor on the mirror, so the sensor thinks it's dark but the headlights still hit you off the glass.
  4. Dec 16, 2022 at 1:25 PM
    #3424
    mountain_medicine
    mountain_medicine Well-Known Member
    Abram
    2020 Cement Tacoma TRD Offroad
    Like others have said, if recirculate is off and you have temperature dial set to heat, this is normal. Interestingly, you cannot turn on recirculate when you have the dial set to window/defrost.
  5. Dec 17, 2022 at 6:41 AM
    #3425
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    The rear view mirror does more than tilt and pan. You can actually adjust the whole thing up and down. If you have trouble with the mirrors darkening, try pushing it up before taking the head rest out.
  6. Dec 17, 2022 at 2:17 PM
    #3426
    JakNY
    JakNY 30yr/360,000mi Plan
    Jack
    NNY
    21 TRD PRO DCSB SUPER WHITE
    I have my center dash display set to fixed compass which displays speed limit in bottom right corner when you have the NAV package. The compass red needle will point in direction of travel AND the compass dial cardinal direction indicator light intensity will increase. That is, if you are heading north, 'N" will be brighter, etc.
    Canadian Caber likes this.
  7. Jan 2, 2023 at 10:36 AM
    #3427
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    I normally never let it get below about 2/3 full in the winter here in BC...you never know when you might spend a few hours stuck in a storm. But, in the summer on a long road trip I have tried to stretch things out and can get to ~750 km on the trip odometer before the "warning low fuel" light comes on. That's pretty close to 470 miles, but that's on premium (91) fuel and keeping to the speed limits in BC (generally either 62 or 55 mph in your units) Given my slightly larger tires (235/85R16) that's more like a real 780 km/490 miles. Probably 95%+ of that in 6th gear on a manual.
    Edit: the summer trip referenced above was in my 2018 AC TRDOR, which had literally the same wheels and tires, but not the factory lift. Haven’t had the new one (modded as noted above) out on a long highway run yet.
    Kodiak420, Canadian Caber and fatz like this.
  8. Jan 10, 2023 at 8:48 AM
    #3428
    Barcelona Rahab
    Barcelona Rahab Member
    22 OR
    i think this may be OR only(my SR did not) but definitely will keep in lower gear on declines if you have held the brake for at least a second or two, and I believe you must depress it enough to engage the hold downshift function while in pure auto mode.
    jneutron[QUOTED] likes this.
  9. Jan 12, 2023 at 12:37 PM
    #3429
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Even when it's folded down?
  10. Jan 12, 2023 at 12:38 PM
    #3430
    Airborne22
    Airborne22 It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    Well that is just stupid.
  11. Jan 12, 2023 at 3:52 PM
    #3431
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
    No, if the seat is folded down, there is no shadow on the sensor which is located on the mirror. The problem only exists when the shadow from the lights behind cast onto the mirrors’ sensor. The mirror can be adjusted as high as it can go mechanically, and it will still happen if the headrest in the path.
    I didn’t engineer it, so I’ll agree, stupid.
  12. Jan 13, 2023 at 10:16 AM
    #3432
    Casey182
    Casey182 Well-Known Member
    Sacramento
    '20 TRD OR - '21 T4R ORP - '66 Chevy C10 SB
    This has to be the standard mirrors only. My factory homelink mirror doesnt do this.
  13. Jan 13, 2023 at 11:32 AM
    #3433
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    If you meant “doesn’t”, it does. There are instructions and pictures in the owners manual.
    Source: my homelink mirror has two points of articulation
    stftaco and Casey182[QUOTED] like this.
  14. Jan 13, 2023 at 12:09 PM
    #3434
    Casey182
    Sacramento
    Guess ill have to check it out then. I just saw the post and went out to try it and gave up quickly lol. The position its in doesnt really bother me. My back window tint is so dark its practically useless anyways :rofl:
    musicisevil[QUOTED] and stftaco like this.
  15. Jan 13, 2023 at 1:11 PM
    #3435
    musicisevil
    Alaska
    2019 TRD Sport
    It’s sort of stiff. Just check the manual for an idea of how it moves and be gentle. There’s a couple of posts here from people who supposedly cracked their windshields by torquing on the mirror too hard
    Casey182[QUOTED] likes this.
  16. Jan 13, 2023 at 5:45 PM
    #3436
    OldSaltyDog
    Hampton Roads VA.
    I mean when the center rear headrest is folded down not the seat! I own a 2022 and I keep the rear center seat headrest in the folded position, and this has never happened to me. In fact, when it is up it restricts your view which is precisely why Toyota designed it to fold for normal everyday operation when no one is sitting in the rear center position.
    BC Hunter likes this.
  17. Jan 17, 2023 at 2:47 PM
    #3437
    jneutron
    jneutron Well-Known Member
    Colorado
    2022 ORDCSB Cemint RIP-15 DCSB TRD MGM
    In your avatar - that was the same color as my 1st gen
  18. May 25, 2023 at 9:28 PM
    #3438
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    You are talking gibberish to me, but I'm interested...
    How does one set the center dash display to a fixed compass etc.
    I have a 2021 Sport with some sort of dash display that takes USB and blue tooth. I can't say much more. Most of the buttons on the right side just pop up a text message that says "what the heck are you doing here? You need additional authorization to proceed" ;-)
  19. May 26, 2023 at 6:28 PM
    #3439
    VTCAL
    2021 Sport
    Can anyone shed light on a small "issue" regarding iPod and iPod Shuffle?
    My classic iPod plugs into the USB port and works just fine.
    Today I plugged in my wife's Shuffle to the USB port and got a "Device not supported" message.
    Do I need to use the Apple Play feature for the Shuffle? The AA works fine for my iPod.
  20. Jul 17, 2023 at 3:10 AM
    #3440
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    The rear sensing blind spot monitors work and coincide with the large sensors in the corners of the bumpers, if one is disconnected the blind spot monitors do not work, i know when i lost half my bumper last year due to an accident.,
