Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Jan 23, 2016 at 7:16 PM
    #41
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Yes PTS is push to start. In the middle of getting some of yalls stuff posted hang tight.
    stealthmode likes this.
  2. Jan 23, 2016 at 7:17 PM
    #42
    AAChaoshand
    Brandon
    Central Texas
    This is fantastic, it's one of the things I didn't even notice.
    Chromebroke, Crow52LA and Tacoma2GR like this.
  3. Jan 23, 2016 at 7:30 PM
    #43
    Shellshock
    Iowa
    If you are in accessory mode, everything will shut off after 15 minutes or so. The cluster display says "shutting down to conserve power". Found this out the other day while sitting in the truck waiting for a meeting.
    sorgon82 and Tacoma2GR like this.
  4. Jan 23, 2016 at 7:43 PM
    #44
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    can you show me the link of that howling noise fix link? Thanks a lot.
  5. Jan 23, 2016 at 7:46 PM
    #45
    joeshmo
    joeshmo Member
    Joe
    See #41, the link is posted in OP
  6. Jan 23, 2016 at 8:47 PM
    #46
    AAChaoshand
    Brandon
    Central Texas
    FirstTimeTaco2020 likes this.
  7. Jan 23, 2016 at 8:49 PM
    #47
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Lol " I think my transmission has a learning disability "
  8. Jan 23, 2016 at 10:06 PM
    #48
    mxwrench
    mxwrench Well-Known Member
    Brian
    Hi Desert, So Cal
    2016 DCSB TRDOR 4X4 JBL SW
    The Power outlet in the bed will supply 110vac up to 400watts during idle only (in neutral (MT) or park (AT)) and 110vac up to 100watts while the vehicle is being driven (or in gear), and it's mode must be toggled by the dash switch.
  9. Jan 23, 2016 at 10:53 PM
    #49
    AAChaoshand
    Brandon
    Central Texas
    Corrected with your text. Thanks man.
  10. Jan 23, 2016 at 10:54 PM
    #50
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    This should be a sticky, some good threads gets lost in the mix after awhile.
  11. Jan 23, 2016 at 11:23 PM
    #51
    AAChaoshand
    Brandon
    Central Texas
    I'm not sure how to request it.
  12. Jan 24, 2016 at 10:16 AM
    #52
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    When driving highway speed, move the shifter Left and Forward and it will shift into 5th instead of 4th like normal. You can then quickly tap to sixth or hold forward to get to sixth
    REDNECKTEX likes this.
  13. Jan 24, 2016 at 10:26 AM
    #53
    BuffaloScout
    BuffaloScout Well-Known Member
    Minnesota
    10 4x4 TRD
    Weathertech, Wet Oaks, Baby Car Seat, Flashlight Mod
    If you double your monthly payments, you will actually repay your loan in literally half the time!
  14. Jan 24, 2016 at 12:26 PM
    #54
    AAChaoshand
    Brandon
    Central Texas
    Ok, I've added everything that hasn't been on the list yet. What is the process to request a sticky?
  15. Jan 24, 2016 at 12:30 PM
    #55
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I would guess that pm'ing a staff member is your best best.
  16. Jan 24, 2016 at 1:08 PM
    #56
    bsacamano
    bsacamano Well-Known Member
    2016 Tacoma Sport DCLB V6 4x4
    This sentence is confusing.
    There is additional space behind the driver side rear passenger seat compared to the passenger rear.
    I think this is what you were going for
    There is additional space behind the driver's side rear seat compared to the rear seat on the passenger's side.
    1taco2motos, EB Group and REDNECKTEX like this.
  17. Jan 24, 2016 at 1:14 PM
    #57
    AAChaoshand
    Brandon
    Central Texas
    Corrected and contacted a site staff member for request a sticky.
    Soul Surfer and Tacoma2GR like this.
  18. Jan 24, 2016 at 2:31 PM
    #58
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    U can ask the dealership to reflash it and erase all "learning" data and start fresh.
  19. Jan 24, 2016 at 2:53 PM
    #59
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    Can't you just disconnect your battery for awhile and let it reset?
    Tacohotshot likes this.
  20. Jan 24, 2016 at 3:09 PM
    #60
    Shellshock
    Iowa
    On my IS250, you could reset it by pulling the fuse for the ECU and EFI for like a minute. This was easier cuz then you didn't have to reset everything else like the clock and power windows and personalization settings.
