Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 9, 2016 at 8:18 AM
    #861
    3X0088
    3X0088 Well-Known Member
    Eric
    Indiana
    2017 TRD Sport dcsb 4x4
    Grill bar light, Pop N Lock, Bed Mat, G4 Fold A Cover Bed lights from mattgecko
    After waiting almost 60 days finally got the techstream cable. Installed software and cable didn't work. Got cable working but, after starting techsteam I get to the Vehicle Connection Wizard which doesn't fill in automatically. In the drop down on Model Code, does anyone know which number to select? and then the other drop down windows? For the 2016 Tacoma I didn't see anything in the search function about this portion of it. Thanks
    Nevermind I got it.
  2. Mar 9, 2016 at 8:32 AM
    #862
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
  3. Mar 9, 2016 at 11:28 AM
    #863
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I am not sure if this is the right thread, but i'll go ahead and share for discussion.
    I have been told by receivers of my calls, that when I use the speaker phone (hands free) feature while the AC unit is on, there is a lot of background "wind" sound. I was able to figure out that it's mainly due to the front air ducts (not the window, not the feet ducts). So I guess my tip is when using hands free and AC, you have to manually make sure not to use the front ducts.
  4. Mar 9, 2016 at 12:25 PM
    #864
    3X0088
    Eric
    Indiana
    Finally got tech stream to work but the "vehicle wizard screen" didn't fill in with my vehicle. I went down the pull down list of options for the top list and found "GRN3##" in the second box if filled in "7GR-FKS" when I selected this it did bring up Tacoma. I didn't change anything cause I wasn't sure this is the correct one to use since mine show it as 2CR-FKS which isn't listed. Has anyone used 7GR-FKS to change the customized options or am I doing something wrong, that it wont list the 2CR-FKS.
    Nevermind GRN3## worked.
  5. Mar 9, 2016 at 12:45 PM
    #865
    Miko074
    Miko074 Member
    Miko
    Oahu, HI
    2016 magnetic grey SR5
    I have this clicking sound when i full stop and shift to P. Is this normal?
  6. Mar 9, 2016 at 3:29 PM
    #866
    Rvndall
    Rvndall Active Member
    Hawaii
    2016 MGM DCSB
    That is probably your door locks unlocking. If not, I have this too. Everytkme my windows are down and I shift it to park, there's a huge grind underneath the car.
    laylow909 and Miko074[QUOTED] like this.
  7. Mar 9, 2016 at 3:38 PM
    #867
    Miko074
    Miko074 Member
    Miko
    Oahu, HI
    It make sense, i will try to change my car settings again and see if the clicking sound comes out. Thank you
  8. Mar 11, 2016 at 5:18 AM
    #868
    DragNasty
    DragNasty Well-Known Member
    2016 Blazing Blue Pearl Limited V6 4X4
    If the sound is coming from the engine than it's injectors cleaning the engine. This is normal operation... Also when shifting into p and taking your foot off the brake it gets locked into place making a clicking noise.
    VangaSTL and Miko074[QUOTED] like this.
  9. Mar 11, 2016 at 7:08 AM
    #869
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    New owner here. I have most of the Entune stuff working ok though there's still a lot of learning. However the "Favorites" list (my Favorite contacts off my iPhone, I presume) is empty. Call History and the full Contacts list show just fine, and the Favorites button on the left can be picked, but nothing shows. Any ideas? I use this a lot on my phone ... I'm not a big Siri or voice recognition fan and really would like to use it in the truck. It's our first ever hands-free vehicle. Thanks.
  10. Mar 11, 2016 at 7:20 AM
    #870
    hey.moe
    hey.moe Active Member
    Stan
    NW Florida
    2016 White DCSB TRD Sport / Leer 100XQ
    The Favorites on the phone won't automatically carry over to Entune. If you pull up All Contacts on Entune you'll notice a star beside each one. Tap the stars of the contacts you want as favorites. They'll turn solid. Then go back and check your Entune Favorites list.
    dman100 likes this.
  11. Mar 11, 2016 at 7:22 AM
    #871
    dman100
    2016 TRD OR DCSB
    Thanks - will try this !
  12. Mar 11, 2016 at 8:26 AM
    #872
    Miko074
    Miko074 Member
    Miko
    Oahu, HI
    Thanks for answer
  13. Mar 11, 2016 at 8:45 AM
    #873
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Why do I feel like I read somewhere on here that the favorites and the Iphone 6 didn't work well together. Like if you start adding favorites it will mess something else up. Gonna have to see if I can find that somewhere.
  14. Mar 11, 2016 at 9:17 AM
    #874
    bill
    bill Active Member
    Silver Spring, MD
    2016 Tacoma TRD Off Road - DC, Inferno
    I believe it was the contact shortcuts, not the favorites, that were the problem.
  15. Mar 11, 2016 at 9:26 AM
    #875
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    gotcha, it was awhile ago, its possible apple released an update by now to fix that.
  16. Mar 11, 2016 at 10:59 AM
    #876
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Number 9 on the list of known problems lists that exact problem.
    Cuffs likes this.
  17. Mar 11, 2016 at 12:15 PM
    #877
    Ultrarunner7
    Ultrarunner7 Well-Known Member
    Northern Virginia
    2016 White Toyota Tacoma Sport 4 door
    Bilstein 5160s in rear with Toltec Progressive 3 leaf spring, Bilstein 6112s in the front
    Update on iPhone Entune issue:
    I went to the home screen and selected two way split instead of three way. This fixed it. So, you cannot receive messages with iPhone on 3 way home screen. Wtf? It shows how shitty this system is.
  18. Mar 11, 2016 at 12:20 PM
    #878
    bill
    bill Active Member
    Silver Spring, MD
    So I have set up the home screen with three screens, and I did one section for the phone with quick contacts, and I'm receiving messages. I guess I'll have to try it a few more times before I'm confident that it's working, but it seems to be fine right now.
  19. Mar 11, 2016 at 12:28 PM
    #879
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Any way to make it simply a single screen?
  20. Mar 11, 2016 at 1:27 PM
    #880
    bill
    bill Active Member
    Silver Spring, MD
    Which screen? For a single screen, you can just go to that screen... Turn off the feature that auto loads the home screen after a period of time.
