Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 20, 2016 at 3:11 PM
    #961
    fireberd350
    fireberd350 Well-Known Member
    West Chester, PA
    2016 TRD Sport
    I found that the SOUND setting (bass, mid, treble, etc) are source specific. So each source has it's own settings. If you, like me, maxed them all out for Radio and noticed Pandora is pretty lame sounding then check the Pandora SOUND and make adjustments. Repeat for other Audio sources as well.
    BTHawk, vuTron, Garyji and 3 others like this.
  2. Mar 20, 2016 at 3:56 PM
    #962
    DDog STaco
    DDog STaco Well-Known Member
    Darrin
    South Coast of Oregon
    2016 Silver Off Road Tacoma
    Thanks so much, got it. Must of been Vin # I input incorrectly?? Third time was all that was needed:ohsnap:
  3. Mar 20, 2016 at 5:06 PM
    #963
    Farmer_Ted
    Farmer_Ted I WANT A TACO!
    Mid West
    '16 Tacoma SR AC 4X4 MT
    Hardcore off road floor mats!
    Has anyone been able to put a custom image on their SR display screen for a 3rd gen? or third gen in general?
  4. Mar 20, 2016 at 6:16 PM
    #964
    shadowkhan
    shadowkhan Well-Known Member
    2016 Barcelona Red TRD Sport 4x4 Prem/Tech w/JBL DCSB
    For some reason that day mode button won't show up on mine. Was there anything specific you had to do for it to show up?
  5. Mar 20, 2016 at 6:37 PM
    #965
    old-timer
    old-timer Well-Known Member
    South Central Texas
    2016 Silver SR5, V6, 2WD, AT, DC, SB w/Tow
    With respect to the SR5, Entune system:
    Yes, if you mean "startup" or "screen off" images.
    No, if you mean "background image"
    Any custom startup image shows only for a few seconds.
    The "Screen off" image stays visible as long as the screen is ... err ... OFF, but the audio system is ON.
    To add custom images:
    1) make one or two folders (depending on which images you want) on an otherwise empty flash drive, using EXACTLY these folder names:
    DisplayOffImage
    StartupImage
    2) Put up to three JPGs of custom images in each folder.
    3) Insert the flash drive in the USB port of the truck
    4) Turn ON ignition
    5) Select SETUP > GENERAL
    6) Scroll down to the "customize startup [or, display off] image" section (I forgot the exact name)
    7) Tap TRANSFER
    8) Follow the displayed instructions
    Gravybird, Jaychef1, bigmw and 2 others like this.
  6. Mar 20, 2016 at 7:03 PM
    #966
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Make sure your screen is in night mode.
    shadowkhan[QUOTED] likes this.
  7. Mar 20, 2016 at 7:09 PM
    #967
    3X0088
    3X0088 Well-Known Member
    Eric
    Indiana
    2017 TRD Sport dcsb 4x4
    Grill bar light, Pop N Lock, Bed Mat, G4 Fold A Cover Bed lights from mattgecko
    Nope, I just turned on the headlights and it pops up after being in the setup. My truck is a SR5 4x4. Don't know if it's different with other models.
  8. Mar 20, 2016 at 8:01 PM
    #968
    shadowkhan
    Thanks guys got it to pop up and yes it has to be in night mode
  9. Mar 20, 2016 at 9:15 PM
    #969
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Awesome avatar. Jane doe, awesome record!!!!!
    Heavy rotation in my car when this came out.
  10. Mar 21, 2016 at 10:09 AM
    #970
    Torador
    Torador New Member
    Thanks, AAChaoshand, for starting such a useful thread.
    For your "known issues" list, let me make this suggestion:
    For owners who got the stock wheel locks as an accessory, they should know how poorly designed and faulty the "key" for the spare tire winch can be. The square end of one of the black shafts does not fit very snugly into the key, and can rotate within it if the winch is tight. This can strand you without access to your spare tire! (Happened to me, and I was lucky to have lots of tools along to kluge a solution.)
    I wrote to Toyota USA about it, and got a rather disrespectful dismissal of my concern. It seems to be a safety issue, if someone with a flat cannot get to their spare, stranding them unnecessarily or tempting them to drive on the rim, but Toyota didn't take it seriously. A simple fix they could do would be making available a key with a better design, such as a male square end to fit the female end of the black shaft. It's a vendor who supplies the wheels locks kit, and a demand for a fix could easily be pushed to them.
    Meanwhile, a preventative fix any owner can make is to drill two through-holes, through the key and shaft together, for cotter pins. Then pack ample cotter pins in the bag along with the key and shafts and jack handle. If ever you get a flat in the backcountry, you'll be glad you did this in advance.
    I'll also post this as a separate thread.
    TacoChief, 0210 and DDog STaco like this.
  11. Mar 21, 2016 at 2:24 PM
    #971
    492vs
    492vs New Member
    2016 Inferno TRD Off Road
    Bak flip vp, mudguards, and bed mat.
    Thx 4 the info on the factory neglects. U joints needed 3-4 pumps to purge on every zerk.
  12. Mar 21, 2016 at 3:19 PM
    #972
    Basicoffroad
    Basicoffroad Member
    16 Tacoma sr5
    #14 I just got my truck and it only came with the 2 key fobs. They both open the tail gate. Where do I find the extra key.
  13. Mar 21, 2016 at 3:22 PM
    #973
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    It looks like you got the SR5, correct? If so, your ignition key is the tailgate key. The trucks with push button start have a separate tailgate key.
  14. Mar 21, 2016 at 3:22 PM
    #974
    DDog STaco
    Darrin
    That makes no sense, key fob is remote that only works on doors.
  15. Mar 21, 2016 at 3:24 PM
    #975
    DDog STaco
    Darrin
    That would make sense.
  16. Mar 21, 2016 at 3:32 PM
    #976
    Basicoffroad
    Basicoffroad Member
    16 Tacoma sr5
    Oh okay makes sense now I wasn't aware that it was only for the push start models
  17. Mar 21, 2016 at 3:36 PM
    #977
    daddy_o
    Bossier City, La
    Yes, the push button start models(TRD and Limited) have a key stored in the fob, but it is a backup for the door. There will be a separate key for the tailgate. I know this because I had to inform my dealer of this when they got the first one on the lot. It was a sport and he was taking the regular key off the ring saying this doesn´t belong on here. I said hold on a minute, I do believe it does. After I showed him what it was for, he was a little embarrassed, but now he knows.
  18. Mar 21, 2016 at 3:36 PM
    #978
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Noted, I'll put it in the main post.
  19. Mar 21, 2016 at 4:16 PM
    #979
    Fikse7
    Fikse7 Well-Known Member
    Oklahoma
    2016 SW Limited 4x2
    Ok guys, need some assistance as I can't figure this out. Downloaded the Entune app to my phone and truck yesterday, all was working great. Now, this morning my Pandora app on my phone just shows loading all day and entune will not play Pandora. I have tried to update the Pandora app several times but it won't update.
    Also, my text messages will not read out loud, I can just ignore them now. Don't know what the heck happened over-night in the garage. :frusty:
    Any suggestions fellas?
    thanks much
  20. Mar 21, 2016 at 4:26 PM
    #980
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    Ahh good question. What are our trucks doing in our garages when we are not watching?! I would suggest deleting the pandora app then reinstall it.
    DjSamthrax likes this.
