Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 21, 2016 at 4:46 PM
    #981
    Fikse7
    Fikse7 Well-Known Member
    Oklahoma
    2016 SW Limited 4x2
    Tried but it won't let me delete the app. I hit the "x", then delete but the pandora icon still says loading like it has all darn day.
  2. Mar 21, 2016 at 4:55 PM
    #982
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    When in doubt restart. Turn your phone completely off. Wait 15 seconds. Turn it back on.
  3. Mar 21, 2016 at 4:57 PM
    #983
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Are you using the 4 quick slot screen on the main screen of the Entune? That is a known issue and you need to remove it and then delete your phone and re-pair it to the entire system. Do other apps work and just Pandora? Not sure what to tell you there, maybe remove Pandora then re-add it? I think Entune actually access Pandora via the web not the app on your phone though, I can't remember. When I have had issues with Entune I just relaunch the program after completely closing it but I'm also on an iPhone so I don't know what your situation is as far as hardware.
  4. Mar 21, 2016 at 5:30 PM
    #984
    Fikse7
    Oklahoma
    2016 SW Limited 4x2
    Appreciate the help, guys. After restarting, then downloading Pandora again, it appears all is working again. Just tested the other Enture Apps and they are working now too.
    Need to test the text "read" now.
  5. Mar 22, 2016 at 6:02 AM
    #985
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    The truck wont allow you to lock the door if its "accessory on" with the smart key. It makes a long tone sound
  6. Mar 22, 2016 at 7:33 AM
    #986
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Has anyone written about getting stuck in 4th gear going up a hill? We have a solution for it
  7. Mar 22, 2016 at 9:04 AM
    #987
    thechadd3
    thechadd3 Well-Known Member
    16 Inferno DCSB MT TRD Sport
    This might have been gone over already but you can't set a destination address through the touch screen while driving? All the other buttons are clickable but the address button is not. Am I doing something wrong? I get the whole safety idea, but what if my passenger wants to set the destination address.....
  8. Mar 22, 2016 at 9:07 AM
    #988
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    That seems to be a recurring issue since Toyota put in touch screen navigation. The wife's 2011 RAV4 is the same way. I wish there was a cheap way around it. Hell, I'll check a box accepting risks if they'll just let it be active when moving.
    Cuffs likes this.
  9. Mar 22, 2016 at 9:08 AM
    #989
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Yes, many times with a lot of complaints. Safety issue I guess, distracted driving.
  10. Mar 22, 2016 at 9:25 AM
    #990
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    This is not a problem. See the other post:
    https://www.tacomaworld.com/threads...ks-accessory-simple-fix.423084/#post-12082072
  11. Mar 22, 2016 at 10:35 AM
    #991
    007TRUCK
    007TRUCK Well-Known Member
    Hey guys,
    1) How do we clean under truck? Im seeing red dirt/salt on mine due to city winter road prep.
    2) Is anyone else have their right side temperature cold/hot knob stiff in early morning? It later turns fine. He funng thinis the driver side temp control knob is fine.
  12. Mar 24, 2016 at 5:15 AM
    #992
    senayski
    senayski Well-Known Member
    Pittsburgh, PA
    1) I did this with my jeep.
    I cleaned it once every 2-3 weeks depending on how bad it was:
    I pressure washed the underneath without full pressure
    then id take the green cleaning stuff (my mind is drawing a blank right now) and spray the underneath a good 3 passes
    let it soak for 30 seconds- 1 minute
    Pressure wash with full pressure
    I also do this to the engine bay when its really dirt and cover connectors with ziploc bags and zipties. And before every winter undercoat it with fluidfilm, or some undercoating (your choice)
    007TRUCK[QUOTED] likes this.
  13. Mar 24, 2016 at 5:23 AM
    #993
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Simple Green is great for cleaning the engine compartment. Spray it on cold, leave it for a few minutes then wash it off with a hose end sprayer. No pressure washing needed.
    senayski[QUOTED] likes this.
  14. Mar 24, 2016 at 5:26 AM
    #994
    jp5
    jp5 *jp5parkles*
    JP
    AZ
    '16 DCSB TRD sport
    One thing I have noticed is when im at home the phone is connected to wifi. When I leave home if i dont turn off wifi, the phone will still try to access through wifi, especially if an app was opened with wifi running. So i just remember to turn off wifi before starting the truck. :notsure:
  15. Mar 24, 2016 at 10:10 AM
    #995
    wowc8
    wowc8 Well-Known Member
    Matthew
    San Jose, CA
    2016 BB Tacoma DCSB TRD OR 4x4
    Custom second row seat back protector, Door sill protectors, bed mat, exhaust chrome tip, dog
    I'm thinking this might be a good thread to ask this. Does anyone know what this metal hook thing is next to the brake fluid reservoir?
  16. Mar 24, 2016 at 10:52 AM
    #996
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    My truck doesn't have this (4x4 Ltd 6 cyl) and the area around the master cyl looks entirely different. What model do you have?
  17. Mar 24, 2016 at 11:17 AM
    #997
    wowc8
    Matthew
    San Jose, CA
    TRD OR DCSB
  18. Mar 24, 2016 at 11:23 AM
    #998
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    My guess is the gear you have around the master cyl is related to the crawl control which is not on the limited.
    wowc8 likes this.
  19. Mar 24, 2016 at 11:34 AM
    #999
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    I found the part in the service manual. It's called a brake actuator bracket. I didn't go through all the related docs to find out its purpose, but feel free to do so.
    wowc8 likes this.
  20. Mar 24, 2016 at 12:44 PM
    #1000
    wowc8
    Matthew
    San Jose, CA
    The docs don't really say much in terms of what it is used for. I don't have a lot of mechanical experience, but I'm starting to think this has something to do with towing. Does that sounds likely?
