Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 24, 2016 at 1:33 PM
    #1001
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    I have the tow package but not the hydraulic booster. The one big difference between the ORD and the ltd is the crawl control so my suspicion is that is part of the setup.
  2. Mar 24, 2016 at 3:36 PM
    #1002
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    After some searching I found this on the forum: https://www.tacomaworld.com/threads/2016-trd-sport-vs-offroad.380566/#post-10448087
    It would appear that the OR model with crawl control has the hydraulic booster. Now that is narrowed down, I have no idea what the bracket does. It is moveable? Meaning, can you pull it one direction or the other? If so, maybe it is used for diagnostics. If not, then chalk it up to a curiosity.
    wowc8 likes this.
  3. Mar 24, 2016 at 3:45 PM
    #1003
    wowc8
    wowc8 Well-Known Member
    Matthew
    San Jose, CA
    2016 BB Tacoma DCSB TRD OR 4x4
    Custom second row seat back protector, Door sill protectors, bed mat, exhaust chrome tip, dog
    I don't remember if it's movable. When I get off work I'll check it out.
  4. Mar 24, 2016 at 7:55 PM
    #1004
    4dimad
    4dimad Well-Known Member
    2016 Tacoma TRD Off-Road
    There was a separate post about Entune stereo turns itself on and off by itself. Anyone else got this problem? I have a moth old 2016 TRD off-road. Occasionally the GPS/audio turn itself off then back on again. Did it for the first week or so after I got the track, now everything is working fine. The iphone has been connected to the bluetooth from the beginning. When the system restarted it kicked-off the bluetooth connection as well. The only "change" after which the Entune is not turning off was NOT plugging the phone to the USB port for charging. Could USB connection potentially create the problem?
  5. Mar 25, 2016 at 2:53 AM
    #1005
    Tirikr
    Tirikr Member
    Tim
    JAX, FL
    2016 TACOMA TRD OFF ROAD LB 4X4 MGM
    Hey i saw the quick tip that states that you can have recycle and defrost. I tried it today and could not get to light up. I have OR with tech and tow.
  6. Mar 25, 2016 at 8:52 AM
    #1006
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Anyone know how to make the steering wheel controls go up and down SiriusXM stations rather than the presets? Very annoying
  7. Mar 25, 2016 at 12:22 PM
    #1007
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    Probably a rookie question here but what are some signs of low ATF fluid?
  8. Mar 25, 2016 at 12:40 PM
    #1008
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    Not sure if you can. I use the tuning knob on the right to navigate in XM
  9. Mar 25, 2016 at 1:26 PM
    #1009
    Fikse7
    Fikse7 Well-Known Member
    Oklahoma
    2016 SW Limited 4x2
    R to D delay, especially on cold start
    Slipping
    Hard Shifts
    Constant gear searching
  10. Mar 25, 2016 at 2:32 PM
    #1010
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    My theory is that because the TRD OR master cylinder assembly is so bad-ass, it's too heavy for assembly folks to install by hand. So they use some sort of lift assist and it needs some way to attach that doesn't interfere with alignment and mounting activities. Therefore (my theory goes) they added the hooks as a way of attaching the lift device.
    Prove me wrong.
    wowc8 and killthehippies like this.
  11. Mar 25, 2016 at 5:38 PM
    #1011
    TonyWhats
    TonyWhats Well-Known Member
    Anthony
    NYC
    2021 Powerwagon 75A
    Yes, if you hold the up or down, rather then click it once you will scan up or down, but only though the category stations.
  12. Mar 25, 2016 at 7:14 PM
    #1012
    HCTacoGuy
    HCTacoGuy Well-Known Member
    Homer City PA
    2025 Tacoma TRD Sport 4x4 Black
    Ready Lift SST 2.5 lift Method Black 703 17 x 8.5 +35
    I am seeing something different with mine. I have a 32 gig flash drive and have copied around 1500 .m4a music files to it. The MP3 player will only read the first 500. None are in folders. If I browse I can see all the songs but they will or play. When you choose one after the 500 it shows a / where the artist and song Should isplay. I have aaudials tunebite which allows you to convert music files to any format. The .m4a format is an excellent quality and it plays great for the first 500.
  13. Mar 25, 2016 at 9:16 PM
    #1013
    NWFTaco
    NWFTaco Well-Known Member
    2016 SR5 DCSB BRM
    Appearance Pkg-Tow Pkg
    You should have a folder for each artist with a folder for each of their albums under that, and then the songs in the album folder. This is pretty much the standard way of setting up music on a computer (which Entune is).
  14. Mar 25, 2016 at 10:08 PM
    #1014
    nomadtaco
    nomadtaco Well-Known Member
    Jeremy
    Tempe AZ
    ‘14 DCSB 4x4
    Camburg UCAs, Fox CO, fox rear resi, deaver 10 leaf
    top things i got out of this thread:
    turn off truck before opening door.
    all electronic settings and warnings accessible through entune apps->vehicle->vehicle settings/customization.
    also. no matter the topic people are going to find a way to be buttholes about something.
    thanks for the tips!
    :thumbsup:
    Boghog1, Hobbs, hirod and 4 others like this.
  15. Mar 26, 2016 at 8:05 AM
    #1015
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    You can, but don't use the defrost button. In the fan settings there is one setting for defrost/foot, that one will allow you to turn on recycle air. Not full defrost but works. Defrost button does not allow recycle air active.
  16. Mar 26, 2016 at 8:09 AM
    #1016
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    For this one I go into Audio, then pick Satellite, then List at bottom of screen, then List All, and use the screen to choose between stations. Not as handy as the steering wheel button but works good for me.
  17. Mar 26, 2016 at 1:07 PM
    #1017
    Tirikr
    Tirikr Member
    Tim
    JAX, FL
    For XM you hold the channel up and channel down and hold for approximate 1/2 second and should go to next XM station
  18. Mar 26, 2016 at 1:47 PM
    #1018
    harley100
    harley100 Well-Known Member
    Phil
    Colorado
    2016 tacoma off road dbl cab short bed white
    too many mods to count
    Check your owners manual. This the the phone charging button.
  19. Mar 26, 2016 at 8:40 PM
    #1019
    Tonkaman
    Tonkaman Well-Known Member
    Anyone know if we can access all of XM radio stations instead of just the very few in the menu?
  20. Mar 26, 2016 at 11:27 PM
    #1020
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    It's so much smoother when off roading at 20psi
