Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 31, 2016 at 10:31 AM
    #1061
    senayski
    senayski Well-Known Member
    Pittsburgh, PA
    Which is what i have, a manual. Hmm
  2. Mar 31, 2016 at 10:31 AM
    #1062
    senayski
    Pittsburgh, PA
    Still, opening the drivers door may do it. Ill have to check
  3. Mar 31, 2016 at 1:51 PM
    #1063
    3X0088
    3X0088 Well-Known Member
    Eric
    Indiana
    2017 TRD Sport dcsb 4x4
    Grill bar light, Pop N Lock, Bed Mat, G4 Fold A Cover Bed lights from mattgecko
    Only options I know of is
    1 lock/unlock when put in park/ taken out of park
    2. unlock when drivers door is open
    Believe you get to those settings in entunes setup.
  4. Mar 31, 2016 at 1:57 PM
    #1064
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    There is an option on the Carista app to unlock when the engine is turned off. If you don't have Carista you may have to have the dealer do it for a manual
  5. Mar 31, 2016 at 2:04 PM
    #1065
    senayski
    Pittsburgh, PA
    Drivers door setting is now turned on. How is the carista app?
  6. Mar 31, 2016 at 3:24 PM
    #1066
    Blazingbluesport
    The OC!
    One of my best mod purchases my opinion. I got the Carista OBD Bluetooth connector. It connects right up. Disregard in their info that the 2016 isn't compatible. It totally is. I like that I can make changes and if I don't like it I can change back or try a different options as often as I want. Turn signals, door locks, chimes, beeps, defrost A/C, interior lights, seatbelt chimes, for the money some of us spend doing expensive mods to our trucks this is a deal. There is a thread in the forum on it. You pay a one time $20 in app purchase unlimited changes and the cost of the OBD connector. Think it was under forty bucks. The cost of sitting at your dealer for three hours for him to do it.
    senayski[QUOTED] likes this.
  7. Mar 31, 2016 at 7:48 PM
    #1067
    bigblackdodge
    bigblackdodge New Member
    Rick
    2016 dbl cab rockstar tacoma
    Anyone know of a leveling kit specific to the 2016 Tacoma?? I just put on some 32s bfgs (255/75r17) and have no rubbing what so ever but want a little lift. Help?
  8. Apr 1, 2016 at 4:38 PM
    #1068
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    Anyone have any idea about the high idle on the 3.5? Sometimes the idle sits around 12-1300 rpm and other times around 5-600rpm. I give it plenty of time to warm up and the engine temp gauge agrees but the idle does not automatically kick down? On previous vehicles ive owned I could either tap the gas or shift from P to D to disengage high idle. I'm thinking shifting from P to D, R at 1000+ revs is going to cause excessive drive train wear over time?
  9. Apr 1, 2016 at 4:44 PM
    #1069
    Lord Humongous
    AZ
    Toytec has some kits that are tested and approved for the 2016. If youre looking for just "level" look into the boss 2.0 coilover setup they offer. It has plenty of adjustability to level it out and leave the rear stock. Allot folks are also using the bilstein 5100s with out issues.....yet. They are not approved for the 2016 yet.
    bigblackdodge[QUOTED] likes this.
  10. Apr 2, 2016 at 12:05 AM
    #1070
    Burn_Shark
    Burn_Shark Member
    I used to have an 04 n colorado and used to use cheap e85 gas on base and costco. But now that i have a new '16 Barcelona Red DCSB, I only use e0. Anyone else using pure gas, or am being a diva. Is increased fuel efficiency and engine preservation true? Or shud i give in to the corn industry? Thanks in advance, and if this is the wrong forum pls let me know.
  11. Apr 2, 2016 at 12:56 AM
    #1071
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I don't actually know... are '16 Tacomas e85 aka FlexFuel capable?
    Long story short unless you have a tune the makes use of e85, just run your normal unleaded gasoline. Better power and mileage.
  12. Apr 2, 2016 at 1:09 AM
    #1072
    Burn_Shark
    Burn_Shark Member
    If i remember correctly, the gas cap says nothing greater then e20 or 20% ethanol. Here in hawaii only about maybe 1 out of 10 gas stations on oahu have pure gas, so i can only fill up at 1 gas station by my house. But i think its worth it. Thanks for the input @memario1214!
  13. Apr 2, 2016 at 1:14 AM
    #1073
    Burn_Shark
    Burn_Shark Member
  14. Apr 2, 2016 at 1:15 AM
    #1074
    memario1214
    Colton
    Missoula, MT
    I knew it! Figured I'd ask
  15. Apr 2, 2016 at 10:19 PM
    #1075
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    My idle sits at 550 to 600 when warmed up. It jumps to 700 to 900 when the air conditioning compressor is turning. I have never had it go 1300 while idling. Have you tried hitting it into Neutral?
  16. Apr 3, 2016 at 8:16 AM
    #1076
    CoeurdTaco
    CoeurdTaco Well-Known Member
    Idaho
    2016 Limited Double Cab
    Revtek 3" lift, 20" Factory Limited Wheels, Bora 1.5" wheel spacers. More to come!!
    It's pretty easy to make work. Go to your iPhone and go to setting then Bluetooth. Once you can see where the Toyota Tacoma is connected just tap the little blue circle with a 'I' in it. It will change to the next page and all you have to is turn on the "show notification" . And that's it! Back out and your text will now appear when you are connects to the vehicle.
  17. Apr 3, 2016 at 8:41 AM
    #1077
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Pretty normal for mine to idle at 1300 at start up on a cold day. Nothing odd there, every vehicle I've owned including my Gen2 did the same thing. Maybe just warmer in SoCal compared to here in the morning. Once warmed rpm drops down to 600-700 rpm at idle.
    Herniator likes this.
  18. Apr 3, 2016 at 8:56 AM
    #1078
    Lord Humongous
    AZ
    Thanks, did a little research and it sounds like the norm. I live in Phoenix and know I'm giving simple warm up time. I just wish there was a manuel kick down.
    TheTruffleShuffle likes this.
  19. Apr 3, 2016 at 12:19 PM
    #1079
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Honestly, I haven't had a kick down since I had a carb with an auto choke. It's all in the ECU programming, reads temp and adjusts idle speeds accordingly, amongst all the other sensors.
  20. Apr 3, 2016 at 4:49 PM
    #1080
    Shenanigans613
    Shenanigans613 Well-Known Member
    Justin
    Crestview FL
    2016 Silver TRD OFF ROAD MT
    Tint, Bed mat, door sill protectors, others pending.
    I had a simliar issue that was more like the idle "sticking" in my 03 F150 that turned out to be the idle air control valve. I replaced it and was good to go. I can't imagine this being an issue on a new truck, but I figured I would throw it out there. I will say that I have limited knowledge on anything vehicle maintenance related, but since the symptoms sounded similar I figured I would share my experience.
