Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Apr 7, 2016 at 7:08 AM
    #1101
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Stupid question time:
    This is my first real truck, it's getting towards rainy season here in Florida and there were some big puddles today I was going through at about 30mph, how worried do I need to be of sucking in water into the intake? These puddles aren't huge but on occasion some hit the windscreen.
    I know I know, noobish question but in my mind I'm in a truck and can go crazy without having to worry about hydrolocking my engine unless I'm going through a river.
  2. Apr 7, 2016 at 7:23 AM
    #1102
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Unless you are driving through water deep enough for a snorkel you shouldn't have a problem. "Puddles" in Florida and pretty much anywhere along the gulf coast can be deep enough to get to the differential breather. You might want to consider an extension to keep water out of it. These extensions are mentioned on other threads.
  3. Apr 7, 2016 at 7:32 AM
    #1103
    acemastr
    Aaron
    Tampa, FL
    OVTune
    It was more a worry about water splashing over the grill and into the intake, I'd not even consider water deep enough to cover axles. May look into the mod just as a preventative though
  4. Apr 7, 2016 at 8:48 AM
    #1104
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    confirmed. holy shit, i didn't think it would be that easy.
    mine took two full turns before tightening up enough to not bug me anymore.
    BrettsMac08 likes this.
  5. Apr 7, 2016 at 10:10 AM
    #1105
    teamlobash
    teamlobash Member
    2016 Double Cab Tacoma TRD Sport 4x4
    I read it here on the forum and just tested again during a road trip from Lexington, SC to Charoltte, NC. If iPhone is plugged via usb and connected with Bluetooth the Entune system will continually reset. If I charge phone via car charger And enable Bluetooth Entune performs as designed.
  6. Apr 7, 2016 at 2:35 PM
    #1106
    NoelTrebek
    NoelTrebek Active Member
    2016 Tacoma
    thanks im gonna have to try that other wise ill have to let it be.. im a bit on the OCD side so it will bother me for a bit.
  7. Apr 7, 2016 at 2:37 PM
    #1107
    NoelTrebek
    2016 Tacoma
    thank you very much for that. I will attempt this later on tonight.
  8. Apr 7, 2016 at 2:54 PM
    #1108
    Skorfab
    Skorfab Well-Known Member
    Adam
    1984 Toyota Pickup Truggy
    6.5" All Pro Lift, Hysteer, Got Propane Conversion Kit, 37x12.50x16.5 Trailworth Fab Recentered Hummer Rims
    Found this out the other day and don't remember seeing it here but it could just be buried.
    If you have keyless start, if you have just the ACC on and not the engine running and go to shift it out of park the engine will automatically start.
    LadyRed and LTacoman like this.
  9. Apr 7, 2016 at 2:57 PM
    #1109
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Did you have your foot on the brake when you did this?
  10. Apr 7, 2016 at 3:01 PM
    #1110
    Skorfab
    Adam
    Yes I did, tapped it once just to turn the truck on, then got distracted organizing some papers or my seat, then forgot the truck wasn't turned on and went to shift it into reverse and the engine started me.
    Burn_Shark likes this.
  11. Apr 7, 2016 at 3:05 PM
    #1111
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Ok, thanks. Just wondering on the safety side of things. Still, find it odd that Toyota would program it that way.
    I honestly can't think of a reason why, but I guess there may be a reason.
  12. Apr 7, 2016 at 3:27 PM
    #1112
    Skorfab
    Adam
    Well your shifter is interlocked with your brake pedal anyway so you're committing to moving once you start moving the shifter. Probably programmed like that for the exact reason of people not starting it then trying to shift.
  13. Apr 7, 2016 at 6:08 PM
    #1113
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    Mine does not do that but it does shutdown the audio on the phone while using Google Maps and also does not send the map guidance through the entune system.
  14. Apr 8, 2016 at 5:58 AM
    #1114
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    Any way to disable the LED (DRL) from dimming when headlights are on?
  15. Apr 8, 2016 at 6:24 PM
    #1115
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I didn't feel anything wrong with my truck and it was 1.2 Qt low
  16. Apr 8, 2016 at 7:18 PM
    #1116
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  17. Apr 8, 2016 at 7:41 PM
    #1117
    SOSHeloPilot
    2024 4Runner SR5
    This was a problem with my past Gen 2s.
    That was my main gripe on past Tacomas ... no way to check ATF levels without a bunch of "hocus pocus". :eek:
    How did you know that is was 1.2 quarts low :eek: without a dipstick ? :confused: Just curious :D
    Just got a 2016 SR5 V6 w/ Auto today and still can't check all fluid levels at delivery.
    I usually don't get a first model year, but I will try this year ... with hopefully not too many problems.
  18. Apr 8, 2016 at 10:00 PM
    #1118
    robutt991
    robutt991 Member
    Hey guys, just wanted to ask if its normal to be driving Highway speeds and then shifting into s mode and it only only going up to the 4th gear? I can shift up to 5th or 6th but it never automatically goes to those gears.Only have about 2000 miles on my dclb sport. But dont see it ever go above 4th... Normal? Not normal?
    I do notice that even at low speeds like 10-15 it shows 4th when I move to sport mode.
    I was an owner who had low atf and had this remedied at about 400 miles thanks to this forum.
    Had all the other fluids checked by toyota.
    It does seem to hunt for gears a bit less than it did brand new driving through the rockies here in colorado.
    I have not disconnected the battery to reset the learning part.
    Just wanted to know if it should be shifting to 5 or 6 at high speeds.
    Thanks so much!
  19. Apr 8, 2016 at 11:26 PM
    #1119
    alf
    alf Well-Known Member
    Alf
    Houston
    TRD OR 4x4
    Nah it always goes into 4th regardless of being in 6th or 5th. Since it's like a version of sport mode it'll go to the power gear. But should change gear when shifting.
    There's a video of your issue here: http://youtu.be/gv5t92hfZnw
  20. Apr 8, 2016 at 11:51 PM
    #1120
    eon_blue
    Azusa, CA
    You'll be fine. Your intake is well protected inside the engine bay. It takes more than even a large puddle splash to hydrolock an engine with the ground clearance a truck has; I've seen plenty of guys without snorkels haul through pools of water on trails and they get out just fine.
    If you're trying to cross a river then, well, that's a different story.
