Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Apr 9, 2016 at 6:17 AM
    #1121
    TacomaLimited13
    TacomaLimited13 Well-Known Member
    2013 Tacoma Limited
    Just got my TRD Sport and got a question. How do I keep the infotainment on while the engine is off?IMG_1563.jpg
  2. Apr 9, 2016 at 6:25 AM
    #1122
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Go back into accessory mode. Push the start button twice without your foot on the brake.
  3. Apr 9, 2016 at 6:50 AM
    #1123
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Do they dim? Or just look dimmer with the headlights on?
    If there is a way to keep them bright with the headlights on, i would also like to know if this possible.
    ebrisse likes this.
  4. Apr 9, 2016 at 7:35 AM
    #1124
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
    If you want the infotainment to stay on when you turn the engine off and its an automatic transmission turn the engine off with it in neutral then shift to park, accessory mode will stay on for a while after that (not sure exactly how long).
    Cuffs likes this.
  5. Apr 9, 2016 at 10:49 AM
    #1125
    WaldoJPL
    WaldoJPL Well-Known Member
    Bill
    ...looking to buy....
  6. Apr 9, 2016 at 3:30 PM
    #1126
    thors.hammer
    thors.hammer Well-Known Member
  7. Apr 9, 2016 at 10:35 PM
    #1127
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    yup. they dim... go check it out yourself
  8. Apr 10, 2016 at 9:45 PM
    #1128
    SeattleTacos
    SeattleTacos Member
    I tried looking but didn't see a similar thread. With push button start is it normal to be able to drive as far as I want without the key? I discovered that once you start the truck you can drive wherever you want without the key present. It does give a warning once in awhile but that's it.
    I don't want to do this on purpose but thought it was not normal and a security risk.
  9. Apr 11, 2016 at 5:16 AM
    #1129
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I made the stealership do it! It was 1.2 low, took 5 pumps grace for the ujoints and the ubolts were at like 30 ft/lb they cranked them to 52
  10. Apr 11, 2016 at 5:47 AM
    #1130
    Firedog10
    Firedog10 Well-Known Member
    2016 TRD sport
    Yeah if your in the vicinity of your fob when you start it you can drive until you shut it off or run out of gas. One thing to remember when storing your key on a hook near the truck in the garage. Learned this lesson with my motorcycle, don't store your key fobs near the vehicle in the garage..Not sure of the distance , but I think its like 5-10ft...
    FireRoadFan and Dusty19 like this.
  11. Apr 11, 2016 at 12:09 PM
    #1131
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    For the Toyota cargo net - where does it attach?
    If there were any instruction, they were tossed out with the packaging...
  12. Apr 11, 2016 at 12:16 PM
    #1132
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    it loops over the bed rail cleats. either parallel to the cab or you can run it lengthwise on the bedrail.
    opentang likes this.
  13. Apr 11, 2016 at 12:35 PM
    #1133
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    That is not normal.. Mine shift to 5th and 6th just by tapping it... You should definitely have it checked ASAP.
  14. Apr 11, 2016 at 12:40 PM
    #1134
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Short trips? Our trucks will not shift to 5 or 6 until a certain coolant temp has been reached.
  15. Apr 11, 2016 at 1:47 PM
    #1135
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Makes sense - thanks!:cheers:
  16. Apr 11, 2016 at 1:57 PM
    #1136
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    I don't believe it actually shifts into those gears when you shift the numbers up and down. IIRC it's a limiter, so if you have it in 4th it will only go up to 4th gear and no higher. Shift down to 3rd and it won't go higher than that. It can still downshift to 2nd or 1st though.
    It's not a true manual shift mode.
    RobPaul likes this.
  17. Apr 11, 2016 at 1:57 PM
    #1137
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    When you shift to S mode it goes into 4th gear....It will NOT go into a higher gear unless YOU push the handle forward into 5th gear, or 6th gear...
    The gear showing while in S mode is the HIGHEST gear it will go into.... This is what gives YOU the control of gears... understand..??
    When you go to S mode it ALWAYS goes into 4th... it will shift down and up, but will NOT go above what you have set....ie: 4th.. if you want higher .... push the handle forward to give you 5th...or 6th... your choice....
    It's a great tranny.... if it takes missing a hockey game and READING the manual then go for it......then try it out ..!!
    Hope this helps... All is normal..
  18. Apr 11, 2016 at 9:00 PM
    #1138
    slowlane
    AZ
    16 double cab MGM
    Is bad to keep the fob near the vehicle? My car is garaged over night and i just leave my keys in the center console. I did this with my altima and never had any issues. Thanks!
  19. Apr 12, 2016 at 11:51 AM
    #1139
    Firedog10
    2016 TRD sport
    Bad?!!! not unless someone breaks in and then they have full access to taking your vehicle without having to search out the key. Not sure about if this will run down your fob battery quicker because its always working...
  20. Apr 12, 2016 at 12:26 PM
    #1140
    Member1Zillion
    Member1Zillion Involuntary Kamikaze Co-Pilot
    Big Whiskey, WY
    '01 TRD, '17 Tundra, '07 FJ Cruiser, 94 PU, '18 T4R, '84 PU
    This, that, & the other thing
    Where do you live exactly? :rofl:
    YDCtaco, kgb136 and RobPaul like this.
