Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Apr 18, 2016 at 3:34 PM
    #1201
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    Changing the number of presets displayed is probably the easiest way. Not really deleting but you don't see them.
    muld00n likes this.
  2. Apr 19, 2016 at 10:43 AM
    #1202
    R.Shaw
    R.Shaw Well-Known Member
    2016 Tacoma 4X4 TRD
    Ya, this would probably be best, thanks.
  3. Apr 20, 2016 at 11:01 AM
    #1203
    bigblackdodge
    bigblackdodge New Member
    Rick
    2016 dbl cab rockstar tacoma
    How can I spin my tires in my sr5 ? I turn traction control off and it still acts like its not letting the truck open up and spin or like if it does spin a little bit it stops.... Anyone else having issues trying to have some fun?
    Carlton.olivo and ExtraExtra like this.
  4. Apr 20, 2016 at 11:23 AM
    #1204
    joeshmo
    joeshmo Member
    Joe
    Push the traction control off button and hold for like 5 seconds and a few more lights light up on the dash and go play!! :-D
  5. Apr 20, 2016 at 2:02 PM
    #1205
    adeav28
    adeav28 Member
    Andrew
    2016 TRD Sport
    Press the gear top right. Then General. Scroll down. Clear all data. Only way to reset the presets to blank. You have to re-pair your phone though.
    R.Shaw likes this.
  6. Apr 20, 2016 at 5:53 PM
    #1206
    Corkys2016Taco4x4
    Corkys2016Taco4x4 Member
    Donald
    2016 Orange Tacoma TRD 4x4
    Siderails, mudflaps, truckbed mat
    Tips and Tricks on the 2016 Tacoma
    I tried a couple of cases in my '16 Taco. I have a Samsung S7 with a MOKO heavy duty case (the one that IS wireless compatible) and it works perfectly. The trick is your case should not have metal in the back of the phone (Like the belt clip or one of those plates for a magnetized holder - which I had on my older phone). It's just interference. Rubberized or silicone should be fine. If your phone is already wireless compatible just lay it inside and give it a second or two and the yellow light appears on the left side of the bottom of the box. Bluetooth works great, but I'm still trying to figure out how to upload other apps from my phone. Anyone got that figured out yet? I'm new in this forum and will post pics of my truck (and phone case) tomorrow. ps the phone case is great too 9 bucks on Amazon, has a kickstand, beats the crap out of an otterbox and fits in my pocket.
  7. Apr 20, 2016 at 8:47 PM
    #1207
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    Since my post, my sprigen case has not worked for the last 2months. iPhone says: device not recognized blah blah blah. So on to another device...
  8. Apr 21, 2016 at 5:35 AM
    #1208
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    If you put on larger tires you may have to make changes to your navigation setting. Page 251 of navigation manual. I did. My truck thought it was playing the ninth hole at my local golf course. FOUR!!
  9. Apr 25, 2016 at 2:04 PM
    #1209
    DragNasty
    DragNasty Well-Known Member
    2016 Blazing Blue Pearl Limited V6 4X4
    Resetting/Shutting off the Maintenance Minder Light. The maintenance reminder light looks like a Triangle with a exclamation point on the dash. The Reset option islocating in the Dash Display; On the Dash Mid display scroll to the last category with the right side steering wheel controls, cycle down the list and look for the maintenance reminder options..You'll have to shut your truck off and turn it back on for the light to go away.
  10. Apr 25, 2016 at 4:53 PM
    #1210
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Found a little safety feature today...
    One-touch up on the windows comes has a 'somethings in the way' sensor and stops the window from continuing up. It then rolls all the way down.
    (Or am I late to the party again?)
  11. Apr 25, 2016 at 5:22 PM
    #1211
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Well Shut The Front Door.... there is just no end to the technology on this new Tacoma...!! No wonder it cost so much, eh..??:rofl:
    CXYyuppie and Cuffs[QUOTED] like this.
  12. Apr 25, 2016 at 5:50 PM
    #1212
    Cuffs
    I traded in a 2015 4Runner Ltd and I don't think it was on that vehicle. But I didn't make it a habit of sticking my hand in the window while it was rolling up either. Until today, that is.
  13. Apr 26, 2016 at 2:07 AM
    #1213
    Mach428
    Mach428 Well-Known Member
    Tom
    Ocala, Florida
    2016 Tacoma Sport Barcelona Red DCSB
    Any vehicle with one-touch up windows has a safety sensor for obstructions
  14. Apr 26, 2016 at 6:43 AM
    #1214
    TravelChic13
    TravelChic13 Member
    Holly
    Cincinnati
    Inferno 2016 TRD Off Road 4x4
    none
    Hi AAChaoshand,
    Great post. Thanks for the info - some of the stuff I've discovered on my own. I do have one question and it maybe silly or very obvious, but is there a key hole for the key (in the key fob) that actually starts the vehicle? I'm not seeing one anywhere but I do recall the dealer saying something about it.
    Also, I have a humming sound (about the same tempo as heartbeat) that happens between 45-55mph. I can feel some vibration in the accelerator pedal. I don't think it is the driveline as the description of symptoms don't match. I thought it was different road textures but it is always around those speeds.
    Any help would be great.
    Cheers,
    Holly
  15. Apr 26, 2016 at 7:38 AM
    #1215
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    HEEEEEYYYYY got the Veepeak OBD2 and paid the $20 for the Carista app... no more seatbelt warning! best $40 I've ever spent. haha.
  16. Apr 26, 2016 at 10:16 AM
    #1216
    fishhooks
    fishhooks Well-Known Member
    Long Island, NY
    '16 Tacoma TRDOR AC QS
    does it turn the red light off too? or just no chime?
  17. Apr 26, 2016 at 11:20 AM
    #1217
    dimead0zen
    So Cal
    It just removes the chime... the red light is still there. (flashes for a minute or so then goes solid).
  18. Apr 26, 2016 at 12:40 PM
    #1218
    Lee_T
    Lee_T Member
    Lee
    2016 Tacoma 4X4 TRD Off Road Access Cab
    none
    Cheaper way to turn off the seatbelt warning - Ebay and Amazon sell little dummy seatbelt tangs for a few bucks, makes the vehicle think there's a seatbelt fastened. For a couple dollars more there's a 3" seatbelt extender, it stays in all the time, the seatbelt when you use it goes into it. Toyota also offers them for free. Only problem, when a passenger gets in you have to remove the extender and reinsert it or the passenger airbag is set to "off."
  19. Apr 26, 2016 at 1:11 PM
    #1219
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    wouldn't it be simpler to just.....wear your seatbelt?
  20. Apr 26, 2016 at 1:36 PM
    #1220
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Ever worked on a ranch with no cattle guards?
