Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. May 7, 2016 at 7:58 AM
    #1261
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    They won't be able to do that since there is no oil level sensor in the transmission. Perhaps they could, however, read and display the two temp sensors in the transmission so we could check the fluid level without getting in to temp check mode.
    Elmo[QUOTED] likes this.
  2. May 7, 2016 at 8:33 AM
    #1262
    jfresh_441
    jfresh_441 Active Member
    Port Elgin ON, Canada
    2016 White Tacoma Limited
    3" lift (Bilstein 5100’s with rear AAL) Differential drop kit TRD Pro rims on BFG KO2 TRD Pro grille HID and LED upgrades (every light interior and exterior; except turn signals)
    Does anyone know how to adjust the Nav system to allow you to enter data like an address etc while driving? It will only allow me to enter an address while the brake is applied. I want to change this ASAP if possible
    Cuffs and tpak like this.
  3. May 7, 2016 at 8:54 AM
    #1263
    SouthtownTaco
    SouthtownTaco Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    Although we've all found it to work great with our 2016 Tacomas, I haven't been able to get it to work with my friends 2012, 2013, and 2014 Tacos. Anyone know of an alternative app for older Tacos?
  4. May 7, 2016 at 9:11 AM
    #1264
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
  5. May 7, 2016 at 9:18 AM
    #1265
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    You can do this with the torque app. I saw a thread on it a while back. You have to do a couple of custom entries.
  6. May 7, 2016 at 10:39 AM
    #1266
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    You can do it with the torque app, but Toyota is so secretive with the PID codes you would think its instructions on building a hydrogen bomb. I and others have made numerous attempts to get the codes with no luck. If anybody has them please PM me.
  7. May 7, 2016 at 12:26 PM
    #1267
    Rock_Diamond
    Rock_Diamond Well-Known Member
    Entune nav eats dongs. Google maps/Bluetooth is the way.
    trk32, Takemehome678, erics and 2 others like this.
  8. May 7, 2016 at 1:11 PM
    #1268
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    I've never had a problem with the nav yet and it's been almost 6 months.
  9. May 7, 2016 at 1:48 PM
    #1269
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    You can message them on Facebook messenger about this issue.
  10. May 7, 2016 at 3:02 PM
    #1270
    sodaryl
    sodaryl Well-Known Member
    Daryl
    Vancouver, BC
    2016 Blazing Blue DCSB M/T Sport
    -Relentless Off-Road sliders -265/70r17 Wrangler Duratracs -Diamondback HD -CCG Mesh grill -Pop & Lock PL8535 -BPF Heavy-Duty Front Tow Hook
    I wish the nav would connect through Google to do voice-searches, I've found that trying to find a specific store, park, mall, etc. through voice commands is near to impossible. Even navigating to a city center can be a bit of a bitch sometimes.
    FireRoadFan and JoeyDel like this.
  11. May 7, 2016 at 3:40 PM
    #1271
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    I've done a search and can't find a thread for the Carista PIDs for 2016 trans temp. If you have time could you point me to one?
    Thanks!
  12. May 7, 2016 at 11:31 PM
    #1272
    TRDoverland
    TRDoverland Well-Known Member
    Kevin
    Petaluma, Ca.
    2016 Tacoma TRD Off Road - MGM
    +1
    Thanks for the heads up! I could of used the visor extension the last couple weeks to keep the sun out of my eyes on the way home from work (sun rise). This will definitely come in handy in the future
  13. May 8, 2016 at 2:51 AM
    #1273
    CRIMAR30
    CRIMAR30 2016 TRD SPORT
    MARK
    NORTH CAROLINA
    2016 TRD SPORT ACCESS CAB
    Anyone know of a way to see both the digital mph and the speed limit in the same view?
  14. May 8, 2016 at 10:48 AM
    #1274
    Rock_Diamond
    I have a question for the Carista ODB2 settings:
    I do not want my instrument lights to dim all the time under bridges tunnels and such during the day and come back on as fast as possible if they do dim. What do I need to set these at? Thanks.
    Instrument lights dimming sensitivity
    DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
    Instrument lights restoring sensitivity
  15. May 8, 2016 at 10:50 AM
    #1275
    Rock_Diamond
    I've found the voice command for etune nav worthless as well. I use Siri hands free if I need nav while driving. Entune and voice doesn't work.
  16. May 8, 2016 at 11:56 AM
    #1276
    robutt991
    robutt991 Member
    Entune recommends you train your voice to make it work well...if you haven't done that then it really is almost useless.
  17. May 8, 2016 at 12:23 PM
    #1277
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Set your light sensitivity to be less sensitive than you have now.
  18. May 8, 2016 at 12:23 PM
    #1278
    Rock_Diamond
    I did that twice. Doesn't help.
    Cows Have Claws and Cuffs like this.
  19. May 8, 2016 at 12:27 PM
    #1279
    Rock_Diamond
    I don't know what the settings mean is why I asked. Can you help? I don't want it to dim constantly during the day. Which of the options is best?
    To restore fast which option is best?
  20. May 8, 2016 at 5:16 PM
    #1280
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    Done that. It still sucks moose ballz.
    FireRoadFan and Cows Have Claws like this.
